Question about Sony Audio Players & Recorders
I own a Sony LBT-D705 which had a problem with the volume knob blinking continueously after I power it on. I solved the problem by replacing one of the main sound IC attached to the black heat zinc in
I replaced the sound IC attached to the black heat zinc with a new IC, but there's still no sound output from the speakers.
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
  • 54 Answers
SOURCE: Power LED blinking - no sound
Check windings on input and output of main power transformer.
Make shure no open windings.
Good Luck
Big Red
Posted on Nov 03, 2007
SOURCE: Sony CMT CP1 Right hand speaker output very noisy, humming, crackling
It sounds to me like you both are having a problem with a capacitor going bad. some capacitors act as a noise filter and it sounds like you both have a bad one. If you are any good with a volt-ohm meter that reads capacitors you should check them to make sure they are at their proper values which will be posted on the capacitor. then replace it. if you dont know how to use a v-o meter then take it to a shop and have them replace it
Posted on Jan 23, 2008
  • 7 Answers
SOURCE: Sony green power/standby led blinks picture goes out
I had this same problem and after doing some research, I removed the lamp, cleaned it and plugged it back in. It fixed my problem completely.
Posted on Mar 30, 2008
Open SKy
  • 620 Answers
SOURCE: very very low sound/output
Helle there!
First!
1) check your setting for sound to (2 way speakers)
2) Setting for Volume in control panel.
3) connector may be you need a little expantion from radio shack gold ext.
4) be sure you got sound from headphones !! **
Go it!
Posted on Jul 31, 2008
My sony hi-fi lbt-sh2000 component sound volume does not increase after long hours playing
example you play music high base and thin you give a high volume.have a automatic sensor inside the player to low the high base.
Feb 06, 2013 | Sony Main Body Of Lbt-Sh2000
LBT-ZX99I Shelf System i have a Sony lbtzx991 and the controls on the system not working besides the volume but all the functions working when i use the remote i would like to know what causing that...
The fault is with the front panel IC, a connecctor to the front panel or a crack in the front board. You need to check well and DO NOT ATTEMPT to repair if you are not equipped as a false move can damage the unit.
Oct 28, 2011 | Sony LBT-ZX99I Shelf System
Why does my Sony Muteki XROSSFADE LBT-DJ2i system shut itself off when the volume get turned up?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 28, 2011 | Sony Muteki XROSSFADE LBT-DJ2i Theater...
I have sony LBT-XG900Av. The volume knob wont adjust volume. Even when using remote you cant adjust volume. Its just on loud
I think the problem will be somekind of audio IC that controls volume and other aspects of the sound has failed. Not a job for an amateur to fix as it will almost certainly involve the desoldering and refitting of multi-pin microchip. I would take it to your nearest Sony Service center.
Jan 31, 2011 | Sony LBT-XG500 Shelf System
Lbt-w900av is stuck in demo mode will not power on or change modes its just stuck on the demo,unplugged overnight and nothing changed,thanks.
hello, try this You need to enter MENU mode. To do this you press the little search button next to the volume knob. What you do is hold that button for about 1-2 seconds. It will then come up with menu demo on. I think you press the volume knob and it will go off smile.gif
regards
shaun
Nov 28, 2010 | Sony LBT-W900AV Shelf System
Sony LBT W5000
According to Page 46 of the LBT-W5000 Operating Instructions:
"The display stars flashing as soon as you plug in the power cord even though you haven't turned on the system (demonstration mode).
Press DISPLAY (for LBT-W5000 / W300 / XB700 / XB500) or DEMO (STANDBY) (for other models) while the system is off. If the system is in the Power Saving mode, press POWER SAVE / DEMO (STANDBY) (for LBT-W5000 / W300 / XB700 / XB500). The demonstration appears automatically the first time you plug in the power cord, or if there is a power outage lasting longer than half a day."
I tested this today, as my LBT-W5000 was in Demonstration Mode. It definitely works. The only catch is (at least on the W5000), and it's a minor one, you have to reset your clock afterwards.
May 29, 2009 | Sony LBT-W5000 Shelf System
Finding an Instruction Manual for Sony stereo system
How do I remove the protect mode from my Sony LBT-LX5 Stereo?
Dec 04, 2007 | Audio Players & Recorders
Sony LBT W5000
when the hi-fi is off and there is the sony demo push "display" on your remote.. yep yep. peace
Oct 06, 2007 | Sony LBT-W5000 Shelf System
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
