My magnavox model26mf605w/17 wont store any channels when scanning what do i do?
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Do a hard reset to this TV and check. If it do not help you, the main system control memory IC to this set is faulty, and should be replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 14, 2014
Magnavox converter box codes
There are no available codes for these, if you are using an universal remote, use the scan function. Typically when scanning you hold down setup on the remote, press SAT/Cable, then power. If it doesn't shut off the box, you press Channel up, and power again. Repeat the Ch. Up and power to keep going to the next code. When you do find the correct code the converter box will power off when you hit power. Press Enter on the remote to store that code for SAT/Cable. Enjoy
Dec 18, 2011 | Magnavox (TB100MG9) Video Converter
Can'y find where to put in channel
First check that when channels were stored that whatever channel you are trying to record is actually stored on the machine. If all other channels are there and the one you want is not I would re scan and re store
Feb 12, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ...
tv.manualsonline.com/manuals/mfg/philips/philips_flat_panel_televis... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
I cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
May 16, 2009 | Philips Televison & Video
Does Magnavox TV model 20MS2331/17 have a digital tuner or do you need a converter box?
Mine is a different model number but you can try this. Go to set-up and and channel set-up see if there is a setting called tv/dtv if so you have a tuner and can then scan till you find the stations.
May 16, 2009 | Televison & Video
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 20MF500T/17 will not interact w/NHENS DTV Converter box
The tv just needs to be set to channel 3 or 4 to pick the signal up from the converter box.
Jan 10, 2009 | Philips Magnavox 27MS343S 27" TV
Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
