Question about Toshiba Televison & Video
I can't get back onto TV mode after accidentally switching it to Radio on the remote for Toshiba CT-90283
I have pressed all of the buttons as well as turning the TV on and off with no luck
    Top Expert:
  • Toshiba Master
  • 74,251 Answers
Just try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 14, 2014
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
Toshiba model 36A43 a Universal remote, a HD Digital Antenna the TV's settings menu no antenna as a auto ch. program search. Has TV/CABLE, I tryed cable didn't set.
I've checked the specs: of your TV. Its original remote control number is "Toshiba CT-90157". This remote control have a slide switch by the left side of it, [a selector switch]; that selects inputs TV, CBL/Sat, VCR, and DVD. You have to select the slide up position to select the TV, to select the TV function by its buttons. Just have to slide one step down to select the input to CBL/SAT; to select the CBL/SAT function by its buttons.
But, without a remote control, you can seect the TV/Video function by its front panel controls. There is press button switch, just right side of its Menu button. For each press of it, the set's input selection will change from TV to Video and vice versa.
Just press this button to select the TV as the input. Then only, the antenna socket at its back will turn effective. If you can't select input by this way, the input selector switch; specified above, has the fault, or the input selector IC inside the circuit board is faulty. Just try this after a Hard Reset to this set, and then check. If it do not help you, contact any service technician, or the authorized service center for Toshiba.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jul 22, 2016 | Toshiba Televison & Video
Need codes for toshiba tv
Here are the codes for a Toshiba TV and DISH remote:
617,631, or 744AddressRemote to TV
  1. While at the device location (TV, etc), point the remote at the device. Press and hold the device button on the remote (TV, Aux, etc). - All four mode buttons should light up
  2. Enter the three-digit remote control code - The mode button (TV, Aux, etc.)you selected should light up
  3. Press the Pound (#) button - The mode button you are programming should flash three times
  4. Press the large, red POWER button - The device should turn off
Jan 06, 2012 | Radio Shack 15-2142 Remote Control
Codigo para television panasonic
Here are the codes for the Panasonic TV: 700, 644, 734, 512, 689, 510, or 662.
I have provided the instructions for programming your DISH remote to your TV.
These are the codes I show for your Sylvania TV: 632, 569, 733, 660, 664, 666, 600, 654, or 556.
I have provided the instructions on how to program your DISH remote to your TV.
Address Remote to TV
Thanks.
Dec 27, 2011 | Toshiba Ct-90276 Remote Control
Hi I have a Toshiba CT-90326 Television. How do I disable the Audio Description on it? Thank you
Hello Clare,
CT-90326 is actually the model number of the remote control rather than the TV. It doesn't really matter as the correct button on the remote is more relevant than the actual TV.
The Audio description is a feature of the closed-caption/subtitle settings on your TV. You should be able to switch off the audio description by pressing the "SUBTITLE" button on the top row of the remote control. Each time you press this button it will cycle between ON and OFF.
If this doesn't work, it's probably because you are using a cable/satellite/digital receiver. If this is the case, look for a button on your cable/satellite/digital receiver remote control marked "CC" "CCD", "SUBTITLE".
Please try the above and then reply to me from within this page. Please state the model number of the TV and any cable/satellite/digital receiver you are using if/when replying.
Thanks,
BElectric
Jan 28, 2011 | Toshiba Televison & Video
CT-13R38SG
Parental Lock Feature
Combo's
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Toshiba Remote CT-877 problem
I contacted Toshiba. Take out the batteries. Press every button on the remote. But the batteries back in. The remote will work because you just reset it.
Jan 10, 2008 | Jensen SC-340A Remote Control
Televison & Video Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
