Question about Ovens
Main Oven temperature drops after it has reached temperature. Temperature Light comes on again once temp has been reached but temp continues to fall.
When the oven gets up to temp the light goes off, then comes on again a few minutes later (I expect this as the temp is still settling) but the temp drops significantly from this point until we adjust the temp to get it to kick in again. This cycle (rise and fall) happens continously. Have changed main oven thermostat and element.
  • 106 Answers
Your Oven is electric and not gas if you have changed element and thermostart then you alo need to check high limit switch wich usually opparates like thermoastart. It only goes off when thermostart fails but if its faulty it could present such as you say.
Posted on May 17, 2015
  • 3,506 Answers
Seems all there is left to check is the switch
Posted on Dec 14, 2014
  • 1462 Answers
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Posted on Jun 25, 2008
  • 139 Answers
SOURCE: Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Posted on Aug 28, 2008
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
heatman101
  • 43501 Answers
SOURCE: oven not getting to proper temperature
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
SOURCE: Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Posted on Nov 10, 2012
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
Erratic temperature on Viking oven
What is the complete model number of your unit?
Feb 18, 2013 | Ovens
Flashing Locked light. Cannot open the oven door
The oven is locked because the temperature inside the oven has not dropped below the locking temperature. Press Clear/Off button and allow the oven to cool. Oven door should open once it has been cooled below the locking temp.
Feb 17, 2011 | GE Profile JKP18 Electric Single Oven
Whirlpool Model# SF315PEMB1 - Oven takes a little while to ignite, once it does, the temperature is not accurate. If set to 350, it only heats to 275 (per oven thermometer) and when you adjust the temp to...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 21, 2010 | Whirlpool Ovens
Mar 14, 2009 | Ovens
Oven Temperature Probe
It could be your ignitor, if weak it might not be good enough to draw ampage.I would suggest to change both ignitor and temp probe to be in a safer side. part number for ignitor is 12872 $56.0+, Part # for your oven temp. sensor 833085, it should not be more than $28. other part from www.repairclinic.com.
Jul 25, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
108 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
