Question about Sylvania DV220SL8 DVD Player/VCR
I am trying to transfer VCR tapes to DVD. The DVD side is not accepting any of the -RW discs that it would before. Ive tried -R and -RW---the screen just says error--this disc will not playback. Ive tried 3 different brands. HELP!
  • rocnrios Jul 06, 2009
    Sylvania DVD-R/-RW Recorder and VHS Hi-Fi Stereo VCR is the unit Im having issues with.
    Put the wrong unit to start my complaint.
    Sorry
  • 10,865 Answers
Hello. It indicates here that you have a DVD player. A player will not record, only a DVD recorder will record.
Posted on Jul 06, 2009
SOURCE:
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
I get a tracking error code when trying to write to a CD. I don't have the code number with me, but it ends with 1h. The program I'm using is Cakewalk Pyro and I'm converting a tape to a CD. ...
so what CD??? CD-R recordable, CD-RW?
No PC stated. NO OS stated ,wow.
just DC3000 and some kind of VHS tape?
My guess bad media. (CD-r)
or the drive it self is bad.
or as all XP are , virus infected,
the spec says
Transfer, edit and burn home videos with this all-in-one external HP DVD movie writer. The built-in analog video capture lets you quickly and easily transfer home video directly from tape to DVD via your camcorder or VCR, while the included suite of software lets you add special effects, music and more to video and photos. Also great for creating music CDs, it writes and reads CD-R and CD-RW discs in addition to DVD-R and DVD-RW discs. Includes software CD, electronic user's guide, USB cable, composite video/audio cable, 1 blank DVD-RW disc and 1 blank DVD-R 4x hi-speed disc. Requires a PC with Microsoft Windows XP or 2000 Professional SP2 and USB connectivity.
Nov 05, 2017 | HP DVD Movie Writer Dc3000 DVD+RW Burner
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I transferred some pictures from my computer on a Maxell RW disc. When I played the disc on my Funai DVD/VHS Dual recorder model DRV-2737 no picture appeared on TV screen. What could be the problem? On the...
sorry...it seem like your dvd/vhs player is outdated...(do the rw disc plays in pc?) are you using Nero software? this will curve the problem...or try another DVD RW brand that funai is compatible with...dvd players, dvd recorder and pc dvd burners do roll back...all must be a year or less apart to work with each other....
May 26, 2010 | Funai PY90VG DVD Player/VCR
Recording from vhs to dvd
As long as you've got the DVD recorder set to the correct "channel" I can't see why it won't work. Why don't you just try it out on a DVD-RW first ? Use RCA cables from the VCR "OUT",  to the DVD recorders "IN" sockets and you'll be okay. If for some unknown reason it doesn't copy you haven't used a good disc. Probably won't copy anything with Macrovision(or other copy protection) though.
Sep 05, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Copying disc of videocanea
With a combo machine you are usually stuck making another disk from your VHS tape-unless yours has a hard drive. Or you could make a copy with your computer DVD recorder-much faster by the way.
I don't know about adding music and naration it all depends on what your manual says your machine can do.
Jun 21, 2008 | Samsung DVD-VR357
Sylvania DV220SL8 DVD Player/VCR Logo
155 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
