Question about Saws
When replacing blade spring for the safety cover fell out. Not surewhere it came from.
    Novelist:
  • 99 Answers
On most brands of circ saws, there will be a lug/tab on the back of the lower blade guard and also a hole or screw point on the upper inside of the main/fixed guard. The spring should have a hook at either end that will go on these fixing points.
Posted on Jan 03, 2015
How do I remove the rubber covering from the lower housing on craftsman 172.171800 recipricating saw?
James, you answered your own question. Remove the foot. The pull the pivot pin from the blade release mechanism. The lever will move to the inside of the housing. The spring is in a slot that is open-ended; you can push the spring out. Then remove the lever w/spring. The cover slides off, but not easily.
Jun 29, 2015 | Saws
Need to know where the clutch spring attaches to under the mower
You removed the engine??? You probably just needed to remove the blade. The only spring I can think of would be a tensioner spring for the belt pulley, which is up front if it's a front wheel drive mower.
Nov 09, 2011 | Garden
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
May 01, 2011 | Makita 10" Miter Saw LS1030N
How do I change the safety cover on the bosch 3912 part no. (2610990523) ?
Three screws need to be removed, one that holds the end of the lever to the guard, and the two inside the guard that holds the guard to the arm housing. Pay attention to which screw goes where as they are not all the same.
Once this comes off, you may have to remove the tab washer and spring and spring washer from the old safety cover, unless your replacement comes with this already attached to it. Pay attention to how the spring and tab washer are situated before you remove them so that you can put it back together properly.
Then reassemble the parts in reverse order. You may also need to switch the pivot in the center of the safety cover and the roller on the bottom edge if these parts are not with your replacement saftey cover.
Dec 03, 2009 | Bosch 12" Compound Miter Saw 3912
The spring for the blade cover has come off how do you fix it? my dad has given me his saw to fix the spring that brings the blade safety cover around, how do you fix it the the mounting post. When I do...
if it a Makita saw it will rub on the guard slightly, What is the model number or you can go to Makitatools.com and type in your model number to see a breakdown for this tool. The post is on the back side of the upper guard and there is a hole in the guard itself for the other end.
Oct 03, 2009 | Makita Saws
Oster Power Pro Cordless Clippers I took the blade off, sm. long black plastic piece fell off. Wanted to change blade to ceramic. Can't get it back together don't know where black piece goes. Don't know...
The plastic piece is a blade guide and has a slot down the length of it which the spring locates into. Simply slide the replacement ceramic cutter under the spring
Sep 29, 2009 | Oster 76076-010 Hair Trimmer
Replacing the saw blade
my husband had trouble replacing the spring that goes in the plastic safety cover....he just eliminated the spring and it works just fine...thankyou for responding....L Martinez
Sep 27, 2008 | Makita 10" Miter Saw LS1030N
How to put the spring in
are you saying the spring to the door fell out and this is the second time??? how was it replaced the first time as a spring should not just fallout unless its dropped and a boss is broken off. ( a boss is a small plastic piece that would hold the spring in place.) This is a hard call unless you get the mechanical diagram as I dont have and they are all made differantly.
Mar 24, 2006 | Panasonic SL-SX430 Personal CD Player
Saws Logo
135 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
