Question about LaCie Computers & Internet
Power not working on Lacie 3TB. It isn't the adapter or plug.
Plugged it in, no power or light
  • LaCie Master
  • 805 Answers
Firstly you can change the data cable then retry it. If not working then the problem is power problem then need to professional technician and repair. Thanks
Posted on Dec 14, 2014
No power to tv red light is out and it's plugged in it just shut off
If the TV is plugged into an active outlet, and the power indicator isn't working, most likely you are dealing with a power supply failure. There is a chance you could have a main board failure as well. I would recommend getting a proper diagnoses before buying parts !!!
Sep 06, 2012 | Emerson LC320EM8 32 in. LCD TV
Dell Vostro Battery charging problems
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jul 12, 2012 | Dell Vostro V13 Laptop Computer (Intel...
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
My 32 inch Sharp Aquos acts like it isn't plugged in..The power light doesn't even come on...
Can you take the back off the set and check the fuse? Located to where the AC plug wire goes into the set. Can be checked with a ohmmeter for continuity. If bad do not exceed the amps of the original fuse when replacing because there may be a short in the circuit that will blow the new fuse and a higher amp may damage the set to a worse condition. Inspect the power supply for charred components across the AC line and replace.
Nov 03, 2011 | Televison & Video
I think I've plugged in the wrong power adapter. Now, once connected, my Lacie makes one whirring noise and fizzles out.
If the wrong power adapter was plugged in the electronic circuitry has been damaged. The only option is to replace the whole hard drive system.
Sep 18, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
My sony vaio vgn-nw320f was totally dead.i had pulled up the battery cause it could not log off.please help me.....
Most sony laptop power supplies have a power LED that indicates if the device is A) plugged in {ok it happens!}, or B) fried and not providing power to the laptop. Check this first. If the power supply is plugged in and the LED is on (usually green or red) then see if you have ANY lights on the laptop itself. Its possible that your LCD display went bad but that the laptop is otherwise running. You may see a power, hard drive or wireless network light on if the laptop works but the LCD went bad. You can also connect an external monitor to the laptop and power it up to check the LCD.
I've also seen where the battery goes bad and it keeps the laptop from booting. Try removing the battery and power up (with the ac adapter plugged in) again.
If neither of these helps, you may be looking at some kind of internal short on the motherboard which is big money. Hopefully that isn't the case.
Hope this helps!!
Jun 20, 2011 | Sony VAIO VGN-NW320F/B Notebook
I have Acer Aspire 3680-2022 notebook. I still have power instability after buying a new a/c adapter & new battery. When a/c plugged in, battery can randomly & rapidly drop...I get a lot of...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 03, 2011 | Acer ASPIRE 3680-2022 Notebook
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
My Mac suddenly cannot find my Lacie external storage device. I have turned off, unplugged, restarted... etc. and it is still not finding it. The Lacie seems to be on, at least the blue light is...
A continuous flashing light on a Lacie drive is a notification of a problem. I do wonder if the light is flashing the same if the drive is plugged in to the Mac or unplugged.
Lacie external drives tend to have power-supplies which become weak/bad. Most users replace the supply and it will work again for awhile until the supply dies again. Try bringing the drive to a retail dealer with Lacie drives -ask them if you can just test your drive with another power-supply (if you do not have another). You can also try calling Lacie, it's always slightly possible they will be aware of this problem.
Alternately, IF the light is only flashing when the drive is plugged-in to the computer, try using a different USB or Firewire cable.
Aug 31, 2009 | LaCie Computers & Internet
Computers & Internet Logo
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
