Question about HP Computers & Internet
I have a new HP Stream I set it up and shut it down when I tried to reboot I got into the page that required my password. After several attempts and research I created the Password Reset Wizard. Was able to put in all the information that was required but when I entered the message " There was an error trying to set your password to this account. How do I fix this?
  • 102 Answers
When you get to the password page, are you able to choose another account from anywhere on the screen? I don't understand how it can ask you for a password if you only set up one account on that PC and with no password...
Posted on Dec 15, 2014
  • 5 Answers
SOURCE: hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Posted on Nov 05, 2007
priyabrat
  • 123 Answers
SOURCE: Resetting Admin password
go to setup>and go to maintanance -->there is a option restore default>select that and after some time do power cycle>and rste me solved if its helps
or
go to your user accouny and change your password
Posted on Jan 28, 2008
worldvet
  • 859 Answers
SOURCE: Logon problem with Compaq notebook!
You're welcome, you can rate this now. Good Luck.
Posted on Oct 31, 2008
shredivya
  • 71 Answers
SOURCE: how to remove power on password on hp compaqnx6110?
You can try reseating the RTC battery:
http://h20464.www2.hp.com/index.html
Real-time clock battery removal Before you begin: Remove the battery and keyboard.
  1. Disconnect the RTC battery cable from the system board
  2. Use a small, flat-bladed, non-conductive tool to flip the RTC battery out of the socket on the top cover.
Real-time clock battery replacement
  1. With the positive (+) side facing up, insert and press the RTC battery into the socket on the top cover.
  2. Reconnect the RTC battery cable to the system board.
If this does not fix the issue, you may have to replace System board
Posted on Jul 06, 2009
  • 10 Answers
SOURCE: When I turn on my HP Mini 1000 it says
Err... Can't you just press enter WITHOUT a password. Please name your Windows Version.
Posted on Dec 29, 2009
Cannot log in or turn off tablet to reboot. Touch screen not working.
You should be able to press and hold the power on switch for several seconds and get the tablet to shut down. If it won't shut down with the power switch, leave it on until it shuts off due to low battery and then recharge and try rebooting the device. If it won't reboot after that, check your manual for the factory reset process. See if you can contact customer support for your unit and get the process for re-flashing the bios from them. That usually requires loading a specific set of files onto the external memory SD card and holding down a switch when restarting the tablet. All files and downloaded apps will be erased if you have to go that way.
Apr 25, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
I cant get into my facebook acount it keep saying that it isnt me i tried changing the password and it doesnt work how do i get my old page back it has pictures that i will not get back and they are i
Facebook has these problems often - sometimes it's fb & sometimes it means someone tried to get into your page with a wrong password several times so fb shut you down. The only thing you can do so you don't lose all your stuff is go into help - you may have to set up a new temporary account to get into it - then post the question & tell them you need your old page back. I checked fb & there is no :"Jesse Lopez Cruz" with a fb page so it looks like it's shut down - set up a new one & go thru "help". Good luck.
Apr 07, 2013 | Facebook Social Network
Hp Designjet 430 new black cartridge printing blank page
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Oct 22, 2012 | HP DesignJet 430 InkJet Printer
Wen i push the next button after completeing the wizard installation it brings up a page that says its connect then brings up another page that says page not found
You can configure router with below method. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 26, 2011 | NetGear WGR614 Wireless Router
How to reboot hp laptop?
From what i gather you're trying to restart you're HP Laptop,this can be done easily by going to the bottom left hand corner and clicking Shut down + restart.If you are locked you can attempt to force shut down the laptop by holding down the power button for a few seconds.
Hope this helps!
- AriGold.
Nov 04, 2010 | Computers & Internet
Mio digiwalker c220
hold the red button down for 15 seconds until it shuts down. then repeat to reboot. Reboot may require several attempts.
Aug 20, 2008 | Gomadic (RTC122921) Power Adapter, Power...
Have HP compaq presario F560us.Was changing password and creating password recovery disk. computer shut down and when tried to enter new password computer would not let me back in. Tried calling HP but...
Try the old password, the new one (again), and no password (blank field) and make sure to reboot in between attempts.
Please explain "Creating password recovery disk", unless you just meant "Recovery Disk Set"?
Post your results so that we may be able to offer more advice.
Thanks.
Jul 15, 2008 | HP Computers & Internet
Hp webcam
I had this problem myself. After a LONG talk with an HP technician we finally sorted it out.
It was actually down to several programs trying to use the camera at the same time, mainly instant messengers, so the first thing to do is to shut down all instant messengers. If possible, from their preferences stop them running when the machine starts.
Once you've done that, try the HP Quickplay (any of the little buttons) and go to the camera from there. It should work. Sometimes a reboot is required if a particularly obstinate instant messenger has activated the camera but not turned it on, and won't release it.
May 25, 2008 | HP Pavilion dv6000z Notebook
I am trying to find my computer password so I can down load a up date for MAC OSX 10.4.6. I thought I had wrote it down and I can't find it antwhere. The friend who down loaded the new system can't...
hi dear
The problem in OS X 10.4.6 - 8 where, despite selection the option "Require password to wake up this computer from sleep or screen saver", you are not prompted for a password when waking up can be solved by resetting you parameter RAM. This is done as follows: 1) reboot while holding down Command-Option-P-R
You will notice that as long as you hold down these 4 keys during reboot the computer will cycle though the initial steps of reboot, e.g. you hear the DC drive calibrate. One it cycled though the RAM is reset.
2) go to System Preferences and select the Security menu. You will notice that the "Require password..." option is not set. Set it and this should solve your problem.
oke
Mar 22, 2008 | Computers & Internet
T30 boot problem
Sorry, but probably your T30 (my favorite Thinkpad) has developed a problem with one of it's memory slots. It is an inherent problem with the Thinkpads. The way to tell is topress on the memory cover in a way that pushes the memory (or more to the point, the memory slots) into the motherboard. While keeping pressure on the memory, try to boot up. I use a T30, and have worked on several others, all have at least one slot with this problem. Also try taking out the memory which is closest to the front of the system, and pushing in on the remaining one. Hope this helps. If this is the problem, there are a couple of things you can do to keep it running, but probably with only one ram stick. Goood luck
Oct 07, 2007 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
