Question about Fisher Dishwashers
How do I fix EG flooding on a fisher & Paykel DW60CE or DW60CC model dishwasher?
Dishwasher DW60CC or DW60CE
jsrock516
  • 5911 Answers
SOURCE: dishwasher f1 problem on fisher paykel
All the information that I have found about this particular problem indicates that the "F1" error is a flood or overflow alarm. It's generally caused by a clog in the drain line and/or tub not sealing properly when closed.
If this is a drawer style dishwasher there is a lid in the equipment cabinet that must seat properly on the drawer when it is closed. If you place items in the dishwasher that are too tall for the drawer lid to seat properly, it will not seal and water will splash over the sides of the tub during the wash cycle.
Another common problem is a clogged or kinked drain line. Remove the drain hose and make sure it is not plugged. Check it at BOTH ends.
The alarm is activated by a float switch in the bottom tray of the dishwasher. Look to see if this is any standing water in the bottom tray. If there is any water, or signs of wetness, the alarm will not clear until it is dried out. I found a couple of recommendations to clear the alarm. The first involved removing the dishwasher from where it is installed and tilting it at a 45 degree angle to pour any standing water out. Another method is to dry the bottom out with towels as best you can, and then use a hair dryer to dry any residual water. I hope I'm on the right track with this and I hope this solves your problem. Post back if you have any further questions.
CAUTION: UNPLUG the dishwasher or turn off the breaker BEFORE servicing inside the cabinet.
Posted on Feb 20, 2008
  • 351 Answers
SOURCE: How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Posted on Mar 20, 2008
SOURCE: I have a Fisher Paykel
just had the same F1 error message. I figured the drain lines were clogged so i hooked my compressor up to them and blew air in the lines for about 5 seconds at 60 psi. It is not giving me the error message anymore and seems to be running fine.
dOX
Posted on May 09, 2008
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
Can you please tell me how to reset the machine after the F^ code appears and I have fixed the flooding problem it is model DW60CE
The dishwasher should reset when the power is turned back on. Make sure the water is turned on also. Sometimes pressing the keylock button and holding for 4 or 5 seconds will allow you to continue. What is the actual F code you are seeing?
Mar 27, 2015 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher and paykel dishwasher pump constantly runs
Please clarify model of dishwasher. It is likely the motor compartment has flooded and it is shorting the power system. Turn off mains power to dishwasher to avoid damage to dishwasher. The source of flooding has to be found.
Jan 16, 2013 | Fisher and Paykel Dishwashers
What does the fault E9 mean on our Fisher & Paykel DW60CC dishwasher mean and how do we fix it?
The fault E9 means the controller has a problem. Obviously it is not a complete fault as you are still getting the fault codes. Some key circuit in the controller has become faulty and this prevents dishwasher from working. Usually the controller needs to be replaced. But first try to turn the mains power off and back on after a short delay. This might reset the controller (boot up).
Dec 09, 2012 | Fisher and Paykel Dishwashers
DW60CE dishwasher - E6 fault flood switch activated. Unit has not been use
After tipping the dishwasher on its side & it releasing its water from its tray, the fault cleared. I removed the bottom cover & inspected its internals for traces of a leak or evidence of leaking.
I could follow the calcium or detergent trail from the rear water duct connection near the top feeding sprayer arm, down the back of the dishwasher & into the tray. The lock nut on the duct where it enters through the inside S/S skin had become loose & simply needed to be tightened.
Jun 09, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
The dishwasher will start for two sec and then they both stop and a red light comes on and starts beeping with motors running.
This indicates the flood switch has been tripped. The video in the link below explains how to access and repair single and double drawer fisher and paykel dishwashers. Its a really good Fisher Paykel dishwasher repair video it really helped me.
Fisher Paykel Dishwasher Repair Video Link
Mar 09, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Disher washer is giving a signal F1 for repairs Model DD603SS
F1 means flood. Below is a link to a video that will show you how to fix the issue if you want to download the video.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Good luck
Mar 01, 2011 | Fisher and Paykel DD24DCFX6 Dishwasher
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Dishwashers Logo
62 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
isaac johny
isaac johny
noel
noel
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
