Question about Chevrolet 1993 Chevrolet Suburban 2500 Radio
The peddle sticks when i first step on it. i replaced the cable already.
Replacing the gas pedel cable and the problem is still their can the gas pedel mount (block) be changed
    Master:
  • Chevrolet Master
  • 401 Answers
Lube the cable and make sure the return spring is good, it could be weak
Posted on Jan 12, 2015
  • Chevrolet Master
  • 637 Answers
I believe your linkage is sticking. Could be the cruise control also.
A thumbs up would be greatly appreciated if this answer is helpful to you.
Posted on Dec 14, 2014
Where is the idle air control valve on a Olds Brevada and the throttle position sensor
You need to put the year of your vehicle in your question, that would be helpful,
look under your hood for a cable or cables at the intake manifold that move when you step on the gas peddle, if you find them, they are moving a throttle plate inside the throttle body or air intake and also the throttle position sensor which is mounted on the other end of the shaft that the cables are turning, if you do not find the cables and there are none, look at the gas peddle its self, it is what you are going to be replacing, the sensor is part of the gas peddle assembly, you most likely will find the best price at http://www.cheapestgmparts.com/ , I don't work for them, I'm just a loyal customer...
IACV, go the autozone or a parts store of your choice and have them show you what this valve looks like so you know what you are looking for, (something like a small motor) it is located very near the air intake or throttle body, (it is used to govern the idle speed)
Mar 23, 2015 | Cars & Trucks
How do you replace a brake lamp switch on a 2007 Hyundai Entourage
I hope you have a good back.You can get on your knees and look under the dash and steering column.
Find the gas and brake peddle. Follow up from the bottom of the brake peddle, Look at the back side. The brake peddle bracket depresses a switch( brake lamp switch). it is very simple to remove. As usual with all work...disconnect the negative battery cable. unplug the brake switch. remove the retaining nut (if it has one) and unscrew the switch from the bracket behind the brake peddle bracket. Take note how far it is sticking out for the reinstallation. Replacing it is just as easy
Jul 13, 2014 | 2007 Hyundai Entourage GLS
2003silverado reduced engine power comes on . no power at all ,cant go over 30mph.i have replaced throttle body, and accelerator peddle sensor ,(no cure) what could it be ?any help is appreciated. thanks
Neither the Throttle Body or the APP (Gas Pedel -that never fails)
was the problem
Who diagnosed & replaced all that?
Do you have cylinder misfires (bad coils)?
What codes were there when whatever happened
first started?
Nov 30, 2012 | Cars & Trucks
Why does my gas pedal sticks, even if it's only pressed half an inch?
Thorttle body could be dirty causing it to bind. Or cable to foot pedel is binding up.
Jun 13, 2012 | Chrysler Sebring Cars & Trucks
2007 grand caravan , gas peddle sticks really bad upon depressing . it is not constant but quite often
make sure that the floor mat is not causing the problem,i know it sounds not possible but it has happened, then check to see if at the intake were the cable is hooked to the throttle valve if something is causing the cable to stick(something rubbed through outer sheath causing it to bind) make sure nothing is pushing on the cable to cause it to kink and bind,then check the throttle valve to see if it is the cause of the sticking,unhook the cables and move the throttle by hand slowly through the arc and see if you feel binding or catching.if it feels like it`s binding then the throttle plate area needs to be thoroughly cleaned and rechecked.check the motion of the gas pedal slowly for binding.if nothing is noticed then it is possible that the throttle cable is worn and needs to be replaced
Mar 04, 2011 | 2007 Dodge Grand Caravan SXT Minivan
The clutch peddle will not come up it stays on the floor
Check on the upper part of the pedel to see if the clip that connects the pedel to the clutch master cylinder has poped off If the clutch pedel is on the floor this is a likely sulition and relitively easy repair you just reattach the clip
Nov 06, 2010 | 1992 Honda Accord
I need to replace the throttle cable. The car will not accelerate because the connection is frayed.
THIS IS NOT HARD TO DO AND INEXPENSIVE TO YOU DON;T REALLY NEED TOOLS THE CABLE IS ABOUT 20 $LOOK AT WHERE IT HOCKS TO THE THROTTLE BODY TURN THROTLE TO OPEN PISITION SO THE CABLE HAS LOTS OF SLACK AND SLIDE IT OUT THE SIDE NEXT REMOVE GROMUET WHERE CABLE GOS THROUGH LOWER FIRE WALL A LITTLE WD 40 HELPS JUST FOLLOW THE CABLE THEN YOU NEED TO OPEN DRIVERS DOOR AND LOOK AT THE GAS PEDEL IT HOOKS IN A SIMULAIR WAY THERE IS LOTS OF SLACK REINSTALL IN OPPISITE ORDER YOU NEED TO FIX THIS PROBLEM BECAUSE YOUR GAS PEDEL CAN STICK IF IT DOSE PUT YOUR FOOT UNDER GAS PEDEL PULL BACK
Oct 10, 2010 | Mercury Cougar Cars & Trucks
Gas peddle sticks
Most gas pedal is connected to the carburetor by a 1/8 or 1/16 inch cable to control the gas entering the combustion chamber of the engine. When this get stucked due to wear, it is high time to get a replacement Accelerator Cable for Toyota 1992 4 Runner. Get this done, and send your e-mail comments.
Oct 05, 2009 | 1992 Toyota 4Runner
Gas Peddle sticking
Remove the cable from the engine side and feel if it is free , if not lube .Check your engine earth cable is tightened and fitted properly , the engine could be earthing on this cable causing it to sieze.
Nov 16, 2008 | 1998 Isuzu Trooper
My gas pedal is sticking
Check the bushes at the top of the pedel. Also check the cable and replace the cable if it is not serviceable. Adjust as recommeded by VW.
Oct 30, 2008 | 2002 Volkswagen Passat
Chevrolet 1993 Chevrolet Suburban 2500 Radio Logo
53 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
CrisO
Lawrence Oravetz
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
