Not function blue gun in crt - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Check all the solder terminals at the video output card [CRT base card]. any loose solder there can cause this fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 14, 2014
54cm CRT tv tube green
CRT color television have three color "guns"; red, green, and blue. This is where the term RGB comes from when discussing computer CRTs. If you are getting only green, something is preventing the red and blue guns from working.
Aug 08, 2016 | Televison & Video
The screen is green and the tint option in the menu cannot be adjusted.
This symptom usually indicates CRT failure. Projection TV's, especially older types use 3 CRT "guns" to project the image on the screen. One is Cyan or Red, one is Green and one is Blue. If the Red and Blue become weak or do not project, the Green gun overpowers the output of the other two. These three "guns" are aligned exactly on top of each other so when all three are correctly functioning, the correct colors are projected on the screen.
Oct 04, 2015 | Televison & Video
The picture looks like a 3d picture without the glasses.
hi,
If the tv is crt one then you have to check the base socket of the three crt gun, red gun, gree gun, blue gun . If the picture looks out of focus then there is problem with the crt base socket. After a long time of use the crt bases connectros will get corrode and it will not have proper conatct with the connection pins of crt guns. you can see this base sockets in the base board on the neck of crt guns. Remove the base board and remove the sockets and replace with a new one. This will give a good picture. The crt base socket will look like on in the picture
ajin_g_66.gif ok
Sep 23, 2011 | Hitachi Televison & Video
I replaced the crt coolant in my 62 inch phillips rear projection tv and the green and red are perfect but the blue is still out of focus when I go to the convergence the cross is perfect but the blue is...
hi,
try to change the crt base socket of blue gun and then try. i will suggest if you replace the base socket change all the three at the same time.
crt base
ok
Jan 20, 2011 | Televison & Video
See blue and red colours on screen on Sony rear projection tv
the green gun on the CRT does not functioning, possible cause maybe some open resistor or defective transistor that drives the green gun.
Aug 01, 2008 | Televison & Video
Blue color gun off line
Milt,
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Bill
Nov 23, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Blue Gun non-responsive
blue crt gun is dead... it has to be replaced. Check carefully the gun neck if theres a crack or damage, I'm suspecting  an overheating yoke ( a bunch of wires around or embracing the crt gun's neck), if theres a sign of overheating, you need to replace the yoke too, not doing it, your new gun will suffer the same fate of the old one, wasting your money.
Oct 29, 2007 | Mitsubishi WT-46809 46" Rear Projection...
I need a replacement part # and location for the "BAD-Blue Signal Video Output Transistor"???
Actually, your description indicates that the blue gun in the tube itself is shorting out. This happens when the set has been on for a while and the metal parts in the CRT guns have heated up and actually contact each other. If the video output transistor is bad then your screen would be blue right from the start. An easy way to prove it is to monitor the voltage of the blue pin on the picture tube socket. It should measure around 150 - 175 volts. When the screen starts going blue you will see that voltage drop dramatically. Quickly pull the CRT board off the picture tube while watching the voltage on the blue pin. If the voltage jumps back up the instant the socket is removed, your picture tube is bad. There are CRT rejuvinators that have the "remove short" function, but that has about a 50% chance of success and I usually find that the short will return a few months down the road.
Aug 05, 2007 | Toshiba 32A33 32" TV
Bad color .
Turn the set on without an antenna, so there is only snow on the screen. Measure the 3 cathode voltages at the CRT, red green and blue. If the 3 voltages are about the same, around 175 volts, then the CRT is bad (purple picture means bad green gun). If the red and blue are around 175 and the green is over 200 volts, then there is a chassis problem, usually the video output transistor itself has gone bad or come loose.
Oct 24, 2006 | Zenith A25A23W 25" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
