Question about Samsung Televison & Video
TV keeps stopping and going to radio station why
Called and went to reset, did not work Model: US50ES6900FXZA
    Top Expert:
  • Samsung Master
  • 75,591 Answers
Do a reset to this TV and check. If it do not help you, contact the authorized service centre for Samsung. It software is corrupted. A software update will be necessary.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 14, 2014
Ho can i get sound working on makita radio
OK, I do not know which model of radio you have but if it is similar to DMR105, try doing a "factory reset".
It is also possible that one of the following has happened:
The station you were listening to had a break in transmission. - Try another station.
You have lost the radio signal. - Try another station.
Your battery has run flat. Change battery/power source.
May 12, 2016 | Makita Drills
Why can i only get radio stations from our humax freesat and not tv channels
There is a button on the remote labelled 'TV/Radio' which was probably knocked when the remote was dropped.
Sep 15, 2014 | Humax Televison & Video
How do I Get all radio stations on my remote .
That depends on how your TV is set up for radio reception.
Some TVs have a dedicated FM/AM radio tuner. This requires signals from both forms of radio antenna.
More commonly now though, digital TV includes a wide range of radio stations broadcast as part of the TV range. In the UK, the radio stations are grouped in the 700+ channel range. e.g. 701 is BBC Radio 1.
Sep 09, 2014 | Televison & Video
Tuning-suddenly stopped. knob turns, yet does not move station indicator bar and i cannot change station. all else works fine. options?
TAKE THE KNOB FO AND SEE IF IT WILL TURN BUY HAND IF SO JUST PUT A BIT OF PAPER ROUND IT AND PUSH THE KNOB BACK ON AND IT SHUOD GO
May 19, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Stock radio won't tune into an FM radio station.
check you attenna connection otherwise it has lost it's ability to seek and stop
Aug 11, 2009 | Hyundai Electronics Hyundai Elantra 2004...
Car battery disconnected over 4 hrs now car radio is useless
just reset the sations by chosing 1 then go 2 the desired sation then holding the 1 button until an audible chime is heard or the station number flashes then see if it stays there when you change station and then go back to 1
Mar 08, 2009 | Blaupunkt Heidelberg CD50 CD Player
My Panasonic TV model TH42PX500U, operating on cable through a cable card, suddenly stopped giving me any cable stations higher than 26! The first 25 work great and then nothing. Sny ideas?
I reset the TV by pressing the on/off and "OK" button at the same time after unplugging and replugging the TV. I also called comcast for a signal to be sent to my card ( I had done that yesterday with no result), so I don't know which of these worked, but I am good to go again.
Nov 29, 2008 | Televison & Video
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
Televison & Video Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
