Hi have just fitted a Bauhn ACE-014 car entertainmet system to my car but have had to take it back and get another unit but it has the same fault,the screen is ghosting the last screen you are on is still in back ground of the next screen, is there a fix as i like the unit, thanks Mal.
    New Friend:
Just go into settings and do a factory reset. This will get rid of the ghosting
Posted on Jul 06, 2015
Hi I have a Bauhn AC42 F22 which the remote has been broken and have bought a new remote but can not find the code for the new remote . Appreciate your assistance . David
Better to buy a facsimile remote
bauhn - Remote Control Warehouse
https://www.remotecontrolwarehouse.com.au/bauhn-c185
Add to Compare. REPLACEMENT BAUHN REMOTE CONTROL - ATV185-014 AT215D-0216 ATV32-715 ATV32H-014 ATV32H-1215 ATV40-014 ATV50-014 ATV50-715 ATV50F-415 ATVU65-0916 LCD TV. Generic BAUHN REMOTE CONTROL Unit: ATV-32HDC1N Suitable for BAUHN Models: .. $38.50. Ex Tax: $35.00.
REPLACEMENT BAUHN REMOTE CONTROL - ATV185-014 AT215D ...
https://www.remotecontrolwarehouse.com.au/replacement-bauhn-remote-control-atv1... Generic BAUHN REMOTE CONTROL Unit: ATV-32HDC1N. Suitable for BAUHN Models: ATV-32HDC1N ATV-24LEC3 AS-39FHD1 ATV-50FHD5. ATV185-014 AT215D-0216 ATV32-715 ATV32H-014 ATV32H-1215 ATV40-014 ATV50-014 ATV50-715 ATV50F-415. ATV40-1014 ATV40-1015 ATVU65-0916 ATVUHD55- ...
Or their own Universal Remote
http://winplus.com.au/links/UR39677%20Bauhn%20Universal%20Remote%20Manual.pdf
The Codes are in the PDF File
http://winplus.com.au/links/UR39677%20Bauhn%20Universal%20Remote%20Code%20Book.pdf
Mar 14, 2018 | Televison & Video
I keep losing channels on bauhn pvr and can't get them back should i reset factory settings
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Nov 16, 2016 | Televison & Video
Will a sansei urc-501a remote have a code for a bauhn tv model actios fullhd/led/lcd atv40-014
One way to find out is to use the code search function in your Sansui (?) remote to find something that will handle your Bauhn TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Sep 16, 2016 | Televison & Video
Hi Ace 2L diesel van. What is the valve clearance warm and cold?
Cold: Intake 0.30mm, Exhaust 0.50mm.
Hot: Intake 0.20mm, Exhaust 0.040mm.
The 2L Toyota engine runs an overhead cam with bucket lifters, and requires removing and replacing of shims to adjust clearances...
Feb 13, 2016 | Toyota Cars & Trucks
I have a 2.0Tb Seagate external hard drive that will not record from my Bauhn TV. I have transfered SQ files to it and they play, but requests formatting to record.
To use the PVR record function on Bauhn TV's you MUST "Format" your Hard Drive or USB device as "FAT32" using the formatting options built into and supplied with the said Bauhn TV. There have been relatively recent changes made to the FAT32 formatting system which now allows you to format very large drives to FAT32. These changes were made after requests from manufacturers like Bauhn so that they could incorporate PVR functions into the TV set itself. I run a 1.5 Terabyte Drive with my Bauhn and it performs beautifully. I won't say that I hope this helps because "I know it will" :) Cheers.......
PS: The resultant files will have the extension SQ rather then MGP of FLV etc etc. I can't get these SQ files to play back on my PC albeit that they do play back perfectly on the Bauhn TV. If anyone knows of a program/player that will allow playback of SQ files on PC's then it would be great if you could post it up here.
Aug 10, 2011 | Televison & Video
E001 e014 e051
E-001.check the thmistor.if it is o.k.DC controler or IP board has a fault.
E 014 faulty rotation of heater unit .correct it.else dc board has a fault.
E 051 horizontal registration sensor not sensing home position.might be mechanical problem or motor might be faulty.
Aug 07, 2011 | Canon imageRUNNER 400S Copier
Everytime I try to turn on my HP Pavilion Entertainmet PC it always says that a disk error occured and it keeps restarting and never turns on.
Your hard disk cable not fit tightly .switch off the power cable .
open cover.fit the hdd tightly .if it same as before plese change the hdd cable .
same problem >go bios (press dell/f2/f10) set your bios as by default
>f10 for save
hope it will help you
please vote me
Nov 24, 2010 | Computers & Internet
Ace light stays on amber and since this come on the alarm is going off any tell me why the light is on and why the alarm is going off it is a discovery 2003
The amber light indicates that the ACE ECU has found a fault with the ACE system, you need to take it to a dealer to get the fault codes read. Could be anything from low fluid to a faulty pressure sensor.
Jan 18, 2010 | 2003 Land Rover Discovery
Word parental at bottom of screen
hi there, its a setup control problem at the remote, do some test. ty
Jan 01, 2008 | Televison & Video
Televison & Video Logo
414 people viewed this question
Top Televison & Video Experts
