Question about Video Game Consoles & Games
My 2002 summit 800 bawgs down when I punch the throttle just after it warms up, is it my reeds? or is it the clutch? dirty fuel line? help
Cleaned jets in the carbs
  • 637 Answers
Whens the last time you cleaned out the carb? The fuel filter swapped out? How old is your fuel?
A thumbs up would be greatly appreciated if this answer is helpful to you.
Posted on Dec 14, 2014
Whats wrong with my 2002 summit 800, it baugs down when I hit theottle
sounds like it's not getting the fuel. change the fuel filter first.(cheapest and most common cause)
hope this helps
gord
Dec 14, 2014 | Cars & Trucks
My 2002 summit 800 baugs down after it warms up?
Swapthefuel filter as well. Sounds like yourcarb needs a good soaking.
Dec 14, 2014 | Winter Sports
What causes 2002 Dodge Neon engine stalls
Obviously-- you have to do some vehicle testing,
to find problems
No list of items you go to & pick from & guess at
Jul 22, 2014 | 2002 Dodge Neon
Why does my 800 sxr jet ski engine runs full throttle and keeps running even after I pulled the spark plug caps?
dirty carbs !
reeds broken will spit back through the carbs !
crank seals worn can let engine run away !
Jul 07, 2014 | Boating
2007 Gilera DNA 50 loses power when hot
Hi, Dratmanl9 and the usual suspects are:
1. Faulty ignition coil.
2. Faulty spark plug cables.
3. Faulty temperature sensor.
4. Faulty starter motor.
5. Valves adjusted too tight.
6. Spark plug gap too wide.
7. Fuel has vapor lock.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
GILERA DNA 50CC BOGGING DOWN SOMETIMES WHEN RIDING HELP
The MotorBike Forum
Gilera DNA 50 Workshop Manual
Gilera DNA 50 2002 Parts
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Oct 18, 2017 | 2007 Gilera DNA 50
Polaris 2 stroke jetski bogs down if more than 1/4 throttle, have cleaned carb,new plugs, reeds are not missing, still get some back draft
This is typical fuel starvation.
Possible causes:
1. Clogged Fuel filter
2. Dirty fuel tank fuel pick up screen or tank outlet hole
3. Cracked fuel line
4. Fuel mainfold screen clogged on the side of the carb. Plastic screen is inside of the manifold where the mounting bolt is
5. Pinched fuel line
One other thing it can be is a severely clogged clogged air filter. Usually if the air filter is clogged the plugs will foul often and fuel consumption will be high with low engine power.
Thanks for using FixYa.
Kelly
May 04, 2010 | Boating
1986 YF 60 4-Zinger. carb settings
The air/fuel screws won't have any effect on the top end. That would be governed by the main jet. Did you install the Boyseen Reeds? If this is a new addition it could be the problem. Another thing could be the fuel level in the carburetor bowl. When you tore down the carb it is possible the float got out of adjustment. You could drop the bowl and see if the fuel level is correct. If not, bend the tab on the float to adjust it.
Oct 03, 2009 | Yamaha XS 400 L Maxim Motorcycles
95 Summit 1.5L Mitsubishi engine miss /lack of power
Somewhere along the the line you may have a fuel blockage or a good dose of water in your fuel tank.Check the water in tank 1st.Add 1 litre of metholated spirits to every 20 litres of fuel.This will allow the water to break down and be burnt through the motor over time.Do this twice.If this does not work,there may be a glob of **** in the fuel tank that blocks the pickup.If this is the problem,the tank needs to be taken out and cleaned.I hope this is a start to get you back on the road.
Aug 18, 2009 | 1995 Eagle Summit
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
