Question about Sharp Aquos Televison & Video
TV goes fuzzy after a while, with no signal
Changing the TV input back every time it goes out.
  • 637 Answers
Make and model please.
A thumbs up would be greatly appreciated if this answer is helpful to you.
Posted on Dec 14, 2014
  • Shelly
    Shelly Dec 14, 2014
    Sharp Aquos LC60E69U
Lost signal
You have changed channels and now it's on the air. If your box is providing a signal on the 3rd or 4th channel you have to get back to those.
Aug 29, 2017 | Televison & Video
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Ge antenna 24700
Hi Patrick,
A fuzzy signal on a plasma TV is not common anymore as with the lack of analog TV transmission the signal is either there or it is not.
A amplified HD TV antenna is not always a solution and often times to get a good HD type reception a good outside antenna is required. I have two $100 antennas high up on my roof and still you can get a loss of data stream when the weather is bad. I also use distribution amplifiers to feed several TV's
In the case that the picture is fuzzy but still there it might be a resolution setting that is wrong so hit the menu button on the remote and see if that display is clear- if it is then try setting a different resolution for the input that you are getting fuzzy signal on.
Aug 10, 2012 | Televison & Video
Today my tv's video iss flickering some times it goes to the static but mostly its lines going up the tv screen changing the colors to black and white sepia or looks like and old VHS vido thats way old...
It could be a loose connection on one of the input lines. try a dvd player plugged right into the tv. If the problem still is there then it is not the signal its the TV itself. if the dvd player looks ok then the bad signal could be from the converter box or something else on the line infront of the input signal
Jun 21, 2011 | Televison & Video
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Not being able to change inputs
Change the input setting on the tv not the remote.
If you are using a universal remote it may not be programmed correctly.
When you push the input button on the remote it is changing it to the Over The Air Antenna, it is not recieving a signal and there is no channel label added for the station it is set to.
If you do have an antenna connected, from the menu do a channel search and see if it can find any signal.
Let me know how it goes, I can assist further.
lone99star
Jan 09, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Dec 30, 2008 | Panasonic TH-42PX60U Television
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
Fuzzy picture
You might want to try a new cable, otherwise it might be a loose jack that if your daring enough, you could fix yourself
Jan 09, 2008 | Zenith D65W25 TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
