Question about Motorcraft 1997 Mercury Mountaineer 97 Rear, Passenger Side Window Regulator
How do i know which are speaker wires i put power to all of the wires coming out of the 16 wire plug and still no sound
Ok so i got a wire harness but it only worked for the stereo not the speakers so i pulled off drivers door and the passenger door panels and found grey and yellow tan and drivers is orange and green and blue and white but they are not the colors coming out of the factory stereo plug so i tried puting power off my stereo i hooked up with a box speaker so i know that it would send out sound when hooked up to speaker wire and still nothing
  • 1,249 Answers
I suspect you have a factory amplifier somewhere. Now would be a good time to find a tech.
Posted on Dec 14, 2014
  • jese
    jese Dec 14, 2014
    yes i did after looking found 2 bow looking things with wires coming out but i pulled one ansd i guess an alarm or the horn went off so i pulled the positive off the bat wont do that again
I plugged in my aftermarket radio in my 98 ford expedition but i still get no power
According to ford truck forums online, the constant battery wire may be lite green and purple, the switched power may be pink and lite green, and the ground is black and lite green.
The battery wire is for memory.
Is that what you need to know ?
Jul 21, 2012 | 1998 Ford Expedition
I have a 2005 pontiac grand am and cant seem to hook it up. the wire installation kit that advance auto parts sold me Metra autoworks stereo wire harness. the wire harness number is AT-WHGM3. The clarion...
Ok, relax. The purpose of the harness is to wire you radio to it, then be able to plug into the factory harness without cutting wires. Let's start from scratch. The harness you have should have all the wires you need IF you told the retailer all the specifications of your vehicle. Basically the harness should have a positive, negative, switched power, and speakers (4 sets). Speaker wires are generally grey, green, white, and purple. Constant power is red, switched power is yellow, and ground is black. However, you unit may have other wires coming off of it, such as remote turn on (usually blue), RCA outputs, and will have an antenna jack that you may need an adaptor for. Sometimes factory harnesses have two plugs. Sometimes they are not required for the radio to be functional (it may be the output and return for an external amplifier that you are currently bypassing). So follow the instructions on the package. Don't feel like you have to be stuck in your car to hook your radio to the harness either. Hope this helps.
Sep 03, 2011 | Clarion Car Audio & Video
I need a color coding of the wiring for the harness i was given for my kenwood dpx308u. i just need to know which colors belong to which wires
Ok, you should have a wiring harness that plugs into the radio. That comes with the radio. You will need a wiring harness that is specific to your vehicle, this will plug into the vehicle harness. The wiring harness will have the correct colors to attach your radio to it. All aftermarket radios have standardized wiring. I recommend not attempting to hardwire your radio due to the risk of frying your entire electrical system. I hope this helps.
Aug 19, 2011 | Car Audio & Video
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I am replacinng the factory stereo with a JVC unit. The harness for the original has two orange wires, one plain the other with a black stripe, and the JVC one doesn't. What are these for and are they...
the orange wire in the #8 cavity is your key on power wire, so yes you need it the yellow wire in the #1 cavity is the 12 volt alwise wire so you need it as well the orange wire in the #10 cavity is the right rear speaker wire + you also need it hear is the wire list.
wire #1. yellow 12 power with key on
wire #2. gray interior lights
wire #3. green right rear speaker -
wire #4. red right front speaker +
wire #5 black left front speaker -
wire #6 brown left rear speaker -
wire #7 gray power antenna
wire #8 orange 12 volt power hot all times
wire #9 pink interior lights
wire #10 orange right front speaker +
wire#11 blue right front speaker + ( door )
wire #12 empty
wire #13 empty
wire #14 yellow left front speaker + (door)
wire #15 white left rear speaker +
wire #16 black/orange ground
Apr 17, 2011 | 2004 Kia Optima
I have a JVC head unit for my car its the 720 unit anyways i have bought to wiring harness for my 2005 gmc sierra slt and the one it powers on but no sound comes out this is made by pac the other one is...
if you keep guessing you are going to fry the head unit.there is 3 plug ins on most wiring harnesses,they are made for two fit different yr gm cars.one plug for power supply and a second for speakers the 3rd is not used.they will only plug in one way.speakers should be wired the speaker wire,one has a line on it ,use that wire on each speaker for ground and the solid colored wire it a plus or poss.wire,on each speaker the same way.also make sure the head unit is grounded good.take your time the harness comes with the instructions.follow them to a T.i have a feeling that the wiring is not being matched up right.it is not in the harness your buying.triple check all wiring connections.hope it helps.PS IF YOU CAN SMELL ANY BURNT SMELL COMING FROM REAR OF HEAD UNIT ITS COOKED.HOPE I COULD HELP.
Dec 22, 2010 | JVC Car Audio & Video
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Cqdf903u powering on but no sound in 2001 vw jetta
Puede que las bocinas sean amplificadas si es asi tienes que buscar un cable que trae el sistema del automovil para que funcionen si son las originales del carro
Mar 28, 2008 | Panasonic CQ-DF903U CD Player
No sound
It could be that the wires in the harness that go to speaker from stereo are not connecting to the leads on the stereo. If this is the case the wires to speakers are not connecting, but the wires from the power source are still good. Try taking the harness out of the back of the stereo that connects all the wires to the leads. Hopefully your wiring is labeled from the factory. If it is it might say "Left front speaker". Isolate this wire and wiggle it inside the harness back and forth. If it moves even a 1/16 of an inch it may be that the leads are not connecting. You can try jerryrigging it by shoving something in their in hopes that it will hold it in place. You may need to replace the harness.
Nov 07, 2007 | Jensen MP5720 CD Player
Motorcraft 1997 Mercury Mountaineer 97 Rear, Passenger Side Window Regulator Logo
574 people viewed this question
Top Motorcraft Scuba Diving & Snorkeling Experts
Jesse Garza
jeff5may32
bobalix
Are you a Motorcraft Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
