Question about Jet Air Tools & Compressors
How do I clean my SATA Jet NR2000?
I have a very lop sided pattern coming from my spray gun.
  • 100 Answers
Take apart the spray nozzle and needle and soak in laquer thinner overnight take a gun brush clean all parts and reassemble try spraying some clean thinner through it and check your pattern
Posted on Jan 21, 2015
Campbell Hausfeld HD4200 spray gun. Will not spray plain water. no siphon effect at feeder tube. What to check?
Check for air leaks above the top of the feeder tube. If it leaks air there, then no suction. Bad gaskets often cause this.
Oct 28, 2016 | Campbell Hausfeld Air Tools & Compressors
How do i fix spray pattern from being heavy on both ends on a binks m1g
I simply stumbled upon this article about spray patterns. Also, the tip, seat and spray cap MAY simply need a good cleaning.
I usually soak all related parts in lacquer thinner overnight to help loosen any build up, then wipe with a good, lint free cloth.
The article: Spray pattern problems solutions
Hope this helps.
Jun 27, 2014 | Binks M1G HVLP Gravity Feed Paint Spray...
Paint gun not shooting correctly
Seeing how you have really stated what the problem is (spitting, clogged, won't shut off, fan pattern wont adjust Etc) and there could be several different things wrong- lets go over some basic spraying A B C'S- always strain the paint through a strainer bag or cone this will remove any debri that might clog the tip, *THINNING when you spray or atomize paint it should always be thinned it will actually cover much better if you thin it with the appropriate solvent water for latex thinner for oil base you want to stay in the 15% range alittle bit more on hot days. The shape of the spray that comes out of the tip is called "fan pattern" or "tip fan" "fan size" you can adjust the fan pattern from 9:00 - 3::00 or sideways to straight up and down or to a small circle this is done by moving the "tip housing retainer" keep a piece of cardboard to practice and see. IMPORTANT:When you have finished spraying you need to clean the entire gun by running the right solvent through the gun untill nothing but clean solvent is coming out dissemble the gun remove and clean needle and needle housing this is not very complicated and is paramount to maintaining any spray equipment for sure the gun....
Perry Tradesman
Dec 29, 2013 | GRACO INC 3900 Handheld Paint Sprayer...
Can not adjust fan on sata jet 3000 hvlp
mine did the same thing,there was a plastic part in the body that was broken,my paint store said they had never taken that part out,i sent mine to sata they fixed it for free.
Oct 30, 2013 | Sata 133223 SATAjet 3000 HVLP Digital...
Iwata eclipse G6 airbrush gun - no paint flow, bubbles forming in gravity feed bottle.
it is rather large (usually 0.6mm nozzle) airbrushing gun,
symptom indicate that needle is closing the nozzle and not retracting, gun need cleaning! or adjustment - seem like both...
remove paint from the feeder, remove feeder bottle from the gun body, clean it well with paint stripper and then solvent/water allow it to dry
remove front casing from the gun and check for any physical debris around the needle or in the chamber, carefully clean without damaging the needle. needle is stainless should be nearly mirror finish.wash with solvent and use toothbrush - DO NOT USE METAL BRUSH!
put it back together and check if it works correctly, if you have any flow from the front - fill about 1/3 of the tank with paint stripper and then spray it to the sink or whatever other safe place. do not forget to wear safety mask, goggles and gloves! paint stripper will eat through your skin! if you splash yourself, have few spoon of vinegar mixed with 2pints (1 liter) of water and this solution will deactivate paint stripper! SAFETY FIRST!
if gun still do not work - you need to strip needle assembly and clean it correctly, put your gun on the table on butcher paper, remove screw holding needle on the back (watch for the spring!) put whole assembly on the paper in the order in which you removed it,
clean needle and needle seat, lightly grease it with vaseline and in reverse order put it back together.
regulations:
very bottom screw - this close to the airhose, it regulates volume of the air to the gun, you very rarely need to adjust that one, you increase volume with haevy paint and decrease it with light paints
needle screw - it regulates volume of the paint itself, closing it clockwise will decrease amount of paint, anticlockwise will increase volume of paint
top screw - it regulates the spray pattern, totally closed - round pattern as there will be no flow to side vents, more open, more flat the spray pattern,
i would suggest fill the bottle with water and put some butchers paper on the wall and experiment what is what and what pattern is most suitable for your use.
hope this little info will help you solve your problem, it is good you give the model, it will be better if you provide as well what medium you use, was it acrylic, oil, water based? all of them behave little bit differently in airgun...
please do not hesitate to leave your opinion and points... thanx!
Oct 04, 2013 | Air Tools & Compressors
Bad air flow. it doesnet seem to be spraying out of the fan correctly. In fact, i don't even get a noticable fan spray. it just sprays a round pattern no matter what i do.
Check none of the air holes int he cap are blocked. Also there is a small wheel adjuster on the left side of the gun, or perhaps even on the top which will adjust fan spray shape.
Of course you need about 30-40 PSI pressure at the gun end for it to spray properly, as well as a compressor with about 12-15cfm air flow rating to use a HVLP gun efficiently.
Apr 16, 2010 | Sharpe Manufacturing FX300 HVLP Spray Gun...
Wagner power painter 325 not spraying right-comes out in clumps and spatters even when trying with water
You should be able to adjust the spray pattern to clear this up. You may also give it a good cleaning with mineral spirits as well as making sure that the paint is thinned enough
Mar 12, 2010 | Wagner Power Products 0154842 Medium Spray...
Gravity feed gun has bubbles in the cup
I was in desperate need of getting on with lacquering a guitar and it seemed everywhere I looked on the net just gave actual spray pattern issues.
There was a small article that suggested tightening the nozzle up. I had only finger-tightened it.
Problem now solved!!!
Dec 07, 2009 | Air Tools & Compressors
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
I bought they display set/floor model including this touch-up spray gun,which did not include the owners/instruction manual. A little help with knob/control functions would be most appreciated. Thanks
well there are two basic setups. one has two knobs on back side of gun and the other has two on back and a third on side. the first , the top knob will adjust your spray pattern while the bottom adjust needle in/out which controls how much material is allowed through. if there is a side knob, it controls spray pattern, while top back adjusts flow and bottom needle position
Jun 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
111 people viewed this question
Top Jet Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Jet Air Tool and Compressor Expert? Answer questions, earn points and help others
