Question about LG Audio Players & Recorders
Instructions for setting up LG remote mkj61841801
Can you give me the codes for the lg tv so I can program my remote to my new tv or a diffent way with out the codes please
hi Tammy.
this is all i could find.
4 & 5 Digit Universal Remote Control Codes For LG TVs
  • DirecTV (directv - direct tv) Remote Codes For LG TV: LG 5 Digit TV codes: 11423, 10178, 11178. ..
    PRESS IN THIS ORDER:
    "Menu" - "Settings" - "Remote" - "Program Remote" - "TV"
    Slide mode switch at top to "TV" - enter LG - press and hold "select" & "mute" buttons
    Wait for light to blink 4 times
    Enter 10178.
    Follow instructions.
    If volume does not work then repeat and enter code 11178.
    RCA universal remote codes for LG tv:
    LG TV codes: 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097,
    1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1149, 1171, 1205.
Dec 15, 2017 | LG Televison & Video
Need instructions lg sound bar remote control akb74815321
  1. Turn on your Sound Bar.
  2. Select LG TV function by using FUNC on the remote control or F on the unit until the correct function is selected.
  3. Set up LG Sound Sync (Wireless) on the TV. Refer to your TV's instruction manual for detailed steps
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 11, 2016 | LG Televison & Video
Hello guys, I have a LG flatron Tv LG m2362dp and an ASDA remote Urc220-D4f, & need help setting up the remote for this device, could please help and advise on how to do this.. many Thanks..
The remote instructions show codes to use to set-up the remote. There is an extensive number of these codes and usually indexed according to TV's identity. It is easily done with that list provided by the remote manufacturer. Check their website, perhaps there is a PDF of the user guide with the codes.
Jun 22, 2016 | LG M2362D 23 in. LCD TV
Cannot set remote control with myLG tv
Some codes to check with LG brand TVs are 0168 0181 0182 0195 0235 0250 0303. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 20, 2014 | none CHUNGHOP RM-139EX Universal Remote...
Tiger Jumbo remote on LG tv and Virgin media
Set-up instructions are so much to type in here, and is not possible too. If you wish to get more details, check the sites linked here. It has set-up code list and set-up procedure to most popular remote controls. http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide / Mosaic option.
Jul 13, 2013 | Brookstone 538744 Remote Control
Bought LG tv need to set up my universal rx450 remote
Setup codes to check with LG brand TVs are 0734,0722,0711,0000,0793. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 11, 2013 | Universal Remote Control 6-Device...
HAD REMOTE2 set to turn on/off LG TV. trying to reprogram and it wont take code nor scan to find. Sat works tv does not.
dmmcgregor
I'm sorry you are having problems reprogramming your TV 2 remote to your LG TV. Have you replaced your batteries? If so, I have provided a link on how to reprogram the remote and how to perform a power scan. I will also give you several codes that should work with the LG TV. This is the link with the instructions for programming the remote to your TV. It begins with step 6.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
If you have any other questions or problems, please respond to this site.
Ray Calo DISH Network
Jan 22, 2011 | DISH Network IR Remote Control
I want to adjust my LG remote control to my Sony tv
I found the DVD LG DVS-8575N manual in spanish on http://safemanuals.com/user-guide-instructions-owner-manual/LG/DVS-8575N-_S
To set a Sony TV just press at the same time POWER TV and number 8 or 9
Jul 10, 2009 | Sony Televison & Video
NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
May 09, 2009 | Televison & Video
71 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
