Question about RCA Televison & Video
My 52 has a distorted picture that seems to be concave and is out of focus. Any Help?
Unplugged for 5 minutes. tightened connections
  • 273 Answers
Id suspect a convergence circuit failure a model number is always important just like going to get a part for your car you need information so you can be assisted with correct information and parts .but il take a guess its a HD52W ?? ON THE DEFLECTION BOARD that's the board on the left side when the back of the set is off . id check connections on the fly back transformer and see if there are a couple cracked they need to be re-soldered . and its possible that a pico fuse is open there on the source . that will need to be replaced . also at the right side of that board are two chemical ribbons that come over from the main signal board there are connectors there if there white they need to be changed to a new part that is black that was a problem that often went unnoticed . the pico fuse sits to the right side of the fly back transformer there three little red squares its the middle on you will need to check with a meter on OHMS scale to determine if its open .
Posted on Jan 07, 2015
The picture and colors went out of focus.
Blowed Fuse there is 3 of them on the right hand side of the FBT flyback Transfomer they Look like small brown rectrangler caps But are Fuses .06amps
it will be the one in the Middle FL231
PartStore.com has them 1-866-925-7278
May 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
Concave picture
the convergence power supply module has failed
if you go into the menu you will not find convergence adjustments in the menu
the power supply module can be repaired
or you may want to get local help
if you want to try to repair you can get parts at mcm or encompas or tvrepairworld.com
Oct 26, 2009 | RCA P52937 52" Rear Projection Television
52 inch RCA Home theater-Sound is distorted/scratchy
I unplugged the tv for 5 minutes. When I turned it back on, I had sound!
Aug 01, 2009 | RCA 32V420T 32" TV
My RCA projection TV - the picture only shows red green and yellow and the picture is distorted almost concaved. It overlaps and nothing is clear. All 3 bulbs seem to be working. No idea what is wrong.
Sounds like convergence problems. This TV may not have the standard "STK.." modules. These sets are bad to lose voltage feeding the convergence amplifiers.
Mar 31, 2009 | RCA P52926 52" Rear Projection Television
RCA-picture discolors, goes concaved
Sounds like a capacitor in the power supply is beginning to fail.Unless your good at this type of repair, I would call a tech to have it serviced. And I would also not use the set until the problem is corrected, or it could get real expensive to fix.
Feb 02, 2009 | RCA HD52W58 52" TV
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
RCA P52937SG
ch over the power supply for the conv this is the stk730-020 that run your conv
Apr 15, 2008 | RCA P52937 52" Rear Projection Television
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
