Question about Maytag Washing Machines
My washer will not respond to pressing the button pads. I cannot change the settings. It beeps 3 times when i push the buttons. I replace the control board with no change. I also cannot put it into te
Model: MAH5500BWW
  • 641 Answers
SOURCE: Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Posted on Jul 23, 2007
IFIXALL
  • 868 Answers
SOURCE: Beeping Neptune washer...
Replace control board
Posted on May 25, 2008
tzweeb
  • 318 Answers
SOURCE: Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Posted on Jan 06, 2009
SOURCE: Washer model wbvh6240fww will not
press and hold the button for at least 5 seconds and it should work.....hope that helps
Posted on May 03, 2009
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune TL electronics problem
I’m not sure what machine model you have your in the FAV6800AW forum. I got Maytag CSV to send me a Control Board for my FAV6800AW. Had to do some arm twisting it is under warranty for 5 years. If you think your Control Board or console is under warranty give it a try. They wanted a Cert Svr Tech to diag the problem. I told them my neighbor was a Svr Tech (me) he had diag the problem and would install the part. They sent me the Control Board, it might be worth a try. I have a number spare parts not under warranty and ebay is my 1st choice, Second Choice . I use this for parts look up Sears Parts Direct.
What is your model type? It sounds like you have Service Manual for your machine and you are troubleshooting in the right direction. Do you have surge protection on the 120VAC outlet powering your machine. Good Luck Rich.
Posted on Jun 21, 2009
3 beeps on any button press, machine will not start, and will not go into service mode
Try unplugging and plugging it back in, carefully. The control panel most likely has gone out. These panels are generally readily accessible, so it is not a big deal to replace a circuit board or component. Be sure to unpower the machine if someone is to try this that is not a licensed technician. If you have a warranty it may be time to call someone out.
Aug 31, 2017 | Maytag Neptune FAV6800AW Top Load Washer
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a AW60448W stopwatch that I can't get the alarms to turn off.
AW60448W Stopwatch
Okay, now you have an excellent Stopwatch but don't know how to set it up. Well, I had the same problem but a friend of mine wanted one also and after I bought it for him, he being an old guy, could not read the small print that came with the Stopwatch. I have gone to the trouble of typing it up and you can benefit from this.
Now I don't expect you will send me any donation/money but if the mood strikes you, I will accept no more than $3.00 cash.
Ron Gray
9540 C.R. 13 North
St. Augustine, FL
32092-2602
E-Mail: NowPrinting@BellSouth.Net if you have questions.
Your Welcome
S1-Button: LAP/RESET
S2-Button: START/STOP
S3-Button: MODE
LIGHT BUTTON: Needs no explanation
LIGHT BUTTON:
The watch is equipped with an electroluminescence (EL) backlight, which can be activated by pressing the EL button. The LCD will light up for three (3) seconds.
CONTROL OF WATCHES:
Normal Display: Hour, Minute, Second and Day of week.
Push of S1-Button: Display shows alarm time in Hour and Minute.
Push of S2-Button: Month, Date and Day of week.
Push of S3-Button: For change of Function.
ALARM OF CHIME ON/OFF:
In normal time: Hold S1-Button and Display shows alarm time in Hour and Minute.
Hourly Chime: While holding S1-Button down, press S3-Button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Alarm: While holding S1-Button down, press S2-Button. Alarm icon will display when alarm is on. Icon will disappear when alarm is off. Release S1-Button and Display changes to normal time immediately.
CHRONOGRAPH MODE:
In normal time, Push S3-Button, chronograph Function will be set.
Start/Stop: Push S2-Button, it operated in cumulative counting up to 1/100 second.
Split Time: Change to Split Time from chronograph time display is performed by pressing S1-Button while chronograph is counting.
Chronograph keeps counting while Split Time is displayed. Push S1-Button again to return to Chronograph Time display.
Reset: Push S2-Button to stop counting and then push S1-Button.
ALARM TIME SETTING:
In normal time, push S3-Button twice to get into Alarm Setting Mode. Monday flag + Hour digits will flash, which is advanced through depression of S2-Button.
1 x Push of S1-Button: Monday flag + Minute digits of the Alarm Time will flash, which is advanced as above.
Push of S3-Button: Display change to normal time again.
NORMAL TIME SETTING:
In normal time, push S3-Button three (3) times. Tuesday flag + second digits will flash. Push S2-Button and Second will be reset to zero (0).
1 x Push of S1-Button: Minute digits flash and advance by depression of S2-Button.
2 x Push of S1-Button: Hour digits flash and advance as above.
3 x Push of S1-Button: Date digits flash and advance as above.
4 x Push of S1-Button: Month digits flash and advance as above.
5 x Push of S1-Button: Flag of weekday flashes and advance as above.
Push of S1-Button and second will start for setting again.
If S3-Button is pushed during anytime change Normal Time will resume on display.
12/24 HOURS REVERSAL OPTION:
You have the possibility to change from 12 to 24 hour system, when adjusting the hours of the normal time (description please see above) one after the other the hours are displayed in the 12 hour system, then in the 24 hour system and then again the 12 hour system, i.e. please push S2-Button so many times, that the hour is displayed in the required system. In the 12 hour system hours are identified by "A" from 24:00-12:00 and with "P" for 12:00-24:00 whereas in the 24 hour system all hours are identified with "H".
ALARM TEST:
Hold S1-Button and then hold S2-Button together. Alarm will "Beep" and Alarm sounded.
ALARM SOUND OFF:
To turn off beeping when Alarm goes off press S1-Button or S2-Button.
For some model, press Light Button also can turn off beeping when Alarm goes off.
Alarm function with 4 to 5 minutes snooze by press S2-Button.
Lifetime Limited Warranty
The Geneva Watch Group warranties that it will repair any failure due to defects in material and/or workmanship free of charge. This warranty is by Geneva Watch Group, not by the dealer from whom it was purchased. This limited warranty does not cover replacement of crystal, battery, band, strap or case. Geneva Watch Group reserves the right to replace any and all inside components in lieu of repair. This warranty does not cover any failure to function properly due to misuse such as water immersion or sever shock. If your watch ever needs service, wrap it carefully in tissue paper or a similar soft material and pack it in a mailing carton. Send it via insured Parcel Post to:
47440 Michigan Ave.
Suite 130
Canton, Michigan 48188
U.S.A.
Include a brief note explaining what is wrong. Be sure to print your name and address clearly. Enclose $7.00 to cover the cost of return postage and handling.
"Do Not send cash or checks. Only Money Orders, Master Card or Visa are accepted."
Card Holder Name: _________________________________________
M. C. ___________Visa______________________________________
Account Number: ___________________________________________
Expiration Date: _____________________________________________
visit us at www.advantagegroupinc.com
AG9936-00
To set Time:
1) Press "MODE" button until Time is displayed.
2) Press and hold "LAP/RESET" button until seconds display starts flashing.
3) Press "START/STOP" button to change selected entry.
4) Press "MODE" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "LAP/RESET" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "LAP/RESET" button until minutes display starts flashing.
4) Press "MODE" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "LAP/RESET" once you are done to set the alarm.
To toggle Alarm Sounds ON and OFF:
1) Press "MODE" button until ALM is displayed
2) Press "START/STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "START/STOP" button on the watch.
How do I turn off the hourly chime on a Wal-Mart Athletic Works stopwatch?
The way to do it is push the "light" button, then the "set" button. If the hourly chime is active, the days indicators will all be highlighted, if it's disabled, they will be turned off too. Basically it's the same as turning the alarm on/off, but instead of using the "start/stop" button, you use the "set button".
Dec 28, 2010 | Watches
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The electronic control beeps and changes settings on it's own and doesn't always respond to buttons being pushed. Do I need a new control or can this be repaired.
Remove and replug all connections to the electronic control board paying careful attention to the ribbon cable connecting the touch pad to the board.
Jan 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a kenmore elite calypso that does not respond to most key presses, except when pressing "normal" the "whitest whites" button lites, and when you press "wool/silk", the "jeans/colors" lights, "buly...
Is the panel lock on??
Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off.
If this reset does not work - unplug for 15 minutes and re-try.
If unplugging for 15 minutes does not reset the controller -
your Main Controller board or touchpad has Failed.
Upon inspection you may have a visible sign one or the other has a burned component on it.
CLICK HERE to see the controller board.
The touchpanel is available in white, graphite, or bisque. CLICK HERE
The Touchpanel is the culprit on 95% of these machines in my experience.
I believe (hard to remember without having the machine right in front of me) there is a fuse you should check on the Motor Controller board that may have popped when the touchpad started acting up too.
Choose wisely - grasshopper - as purchasing and installing the Touch panel will equate to almost 1/2 of a new appliance with a warranty :D
Thanks for using FixYa!!
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
Sep 10, 2008 | Cables Unlimited InterAct Racing Wheel V3...
Washing Machines Logo
140 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
