Question about LG Televison & Video
My LG DVD blue ray player has lost all power. Suggested trouble shooting did not work. How do I retrieve the DVD stuck in the player?
Unplugged, re-plugged, held power button 5 seconds, released, tried different out let. No power .
    Renaissance:
    An user who is expert in 3 categories / brands.
  • LG Master
  • 884 Answers
Hi
On most optical drives (CD, DVD, etc) associated with computers there is a small hole somewhere in the front cover. If, with the power off, and the unit unplugged, you push a straightened paper clip into this hole it will often release a catch and push the carrier out a few millimetres and it can then be pulled out completely and the disk recovered. This does not usually damage the disk or player in any way.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Jan 31, 2015
SOURCE: LG RH1999H DVD Recorder
I did try removing the Hard Disk from the recorder and did a diagnostic and fix-disk using Ontrack software. Ontrack showed no structural and physical defects on the hard disk. I replaced the hard disk in the recorded and guess what! Please wait, please wait, please wait, please wait...................................
Posted on Mar 12, 2008
  • 3 Answers
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Posted on Dec 29, 2008
  • 259 Answers
SOURCE: LG BD 300 blue ray player won't play dvds
have you tried more than one dvd ?? i have heard that even the slightest mark on a disc and they won't play hope this helps regards Jim
Posted on Apr 09, 2009
SOURCE: LG Blu-Ray BD-370 unlock codes
http://www.multi-region.net/lg_5931
Posted on May 01, 2009
SOURCE: I have a Sharp BD-HP24U
Hi...I also have a Sharp BD-HP24U. I was having trouble with my Netgear router as well. I wound up downloading the latest firmware update from the Sharp USA website onto a memory stick. Then putting into the USB port in the back of the player, and uploaded. I am now happily streaming Netflix. Hope this helps!
Posted on Sep 10, 2010
My lg blue ray player is powering up and all that isoniazid the screen is powering off
if you have basic knowledge in electronic repair then you can do a check in your player. first you will need to unplug the unit for safety. then unscrew to remove the cover now look for the power supply board which supply the main board and mechanism. try to find any unusual in the board like bulged component parts or any burnt parts, as will as in the main board. if none everything looks fine, at this time you will need a trouble shooting which need to used device like digital tester. you must check weather the supply dc voltages coming from the power supply board are stable if not it will not turn on properly.
Mar 02, 2014 | LG BD390 Blu-Ray Player
Lg 3d blu ray dvd player remote stopped working
The remote is covered y the warranty. If not 30 days have passed the store you bought it from may replace it.
Aug 08, 2017 | Televison & Video
Lg 670 stuck
I had the same problem with my LG bd670 blu ray. I fixed it. It was a failed firmware update. I went to the LG website and downloaded the update and copied it onto a flash drive. I unplugged my blu ray (hdmi cable too), put the flash drive into the usb port on front, and plugged in the power cord. It took a couple of minutes but it loaded the update from the flash drive and shut off. I plugged the in hdmi cable and turned on the blu ray and done. All was well in the world again. I hope this helps anyone with the "boot" error message on the LG bd670 blu ray player.
Mar 23, 2012 | LG BD670 Bluray 3D Player
I have a Sharp BD-HP24U blue ray with netflix ethernet streaming capabilities. I have purchased a netgear router. All connections are working. I know this because I unplugged the ethernet cable going to...
Aug 30, 2010 | Sharp AQUOS Blu-ray Disc Player
Connecting Linksys router with BD390 blueray player
I had a similiar problem with my BD390...Saw the SSID but not able to log on. I ended up performing a downgrade of firmware from LG's support page and corrected it. Afterwards upgraded firmware to current levels and works still ok.
Jan 01, 2010 | LG BD390 Blu-Ray Player
Blue ray won't play movies
look to see if you need a Firmware update. You will need ti plug the device to an ethernet port and also trouble shoot through the manual.
May 18, 2009 | Televison & Video
Dvd stuck in dvd/vcr dual player
I unplugged my system, waited plugged it back in and DVD ejected from the player.
Mar 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Stuck dvd in dvd player
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Feb 21, 2008 | LG LDA511 DVD Player
Televison & Video Logo
37 people viewed this question
