Question about Fujitsu Heating & Cooling
I have a fujitsu inverter asta 24jcc every eight seconds the red and green light flashes about five times
i have a fujitsu inverter asta 24jcc every eight seconds the red and green light flashes about five times
    New Friend:
  • 10 Answers
The problem with the electronic ones is they usually need repairing by a service centre or aircon guy and if it's not under warranty they'll be able to recommend their repairer. We had a similar fault where there was just some random code error. It happened during a heat wave and it turned out the fan motor seized and the board got burnt out. They had to replace they board so that may be what you're up for.
Posted on Dec 14, 2014
5 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Posted on Jan 07, 2008
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
hvac1960
  • 2133 Answers
SOURCE: We have a fujitsu inverter
E3 Outdoor activation of high pressure switch.
Check condenser coil. If blocked, clean it. If out door fan rpm less replace capacitor. Helpful?
Posted on Jan 02, 2011
SOURCE: fujitsu asya09lcc wallmount split lights flashing indoors
just happen to me, call the service guy........... he told me to cut power for 30 minutes cause it erase memory inside machine. I did and its working........ So happy
Posted on Jan 05, 2012
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
Hi Ken,
I hope the following link will help you?
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Dec 13, 2014 | Fujitsu Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
We have a fujitsu inverter that is wall mounted - model ASTA 09LCC. The fan is working but the air is not cooling. There is a green timer light that periodically flashes 3 times. Any suggestions?
Jan 02, 2011 | Fujitsu Heating & Cooling
My sony KP-57ws500 flashes green then turns off.
YOU HAVE A BAD GREEN CRT. UNIT IS NOT WORTH REPAIRING SINCE YOU WOULD HAVE TO REPLACE ALL 3 CRTS FOR THE UNIT TO SET UP PROPERLY.
Jan 12, 2009 | Sony KP-57WS500 57" Rear Projection...
Flashing lights on system
Jan 07, 2008 | Heating & Cooling
Heating & Cooling Logo
91 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
