Question about Hitachi 42HDS69 42 in. Plasma Television
Why does my Hitachi 42HDS69 42 inch Plasma TV have horizontal green lines across the screen? I have checked all connections and tried to tweek the color settings but nothing has helped. I went thru th
Why does my Hitachi 42HDS69 42 inch Plasma TV have horizontal green lines across the screen? I have checked all connections and tried to tweek the color settings but nothing has helped. I went thru the trouble shooting guide to no avail. I know the firmware has never been updated because it was my son's TV. Could that be the problem with the green lines?
    Top Expert:
  • Hitachi Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 14, 2014
  • 11 Answers
SOURCE: hitachi 50v500a high definition tv
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
  • 223 Answers
SOURCE: neon green line down right side of screen
I think you are developing a problem on the line output stage of the television. The first thing to do is LIGHTLY tap the side of the tv and see if this cures the problem. If you tap it say ten times and it comes and goes then the problem is dry solder joints. Otherwise I would suspect a faulty component on the line output stage probably the transistor or the transformer. If you can check these faults for yourself otherwise find a competant technician. Hope this helps.
Posted on Oct 04, 2008
  • 223 Answers
SOURCE: Hitachi 42HDS69 42 in. Plasma with red lines
I think you have dry solder joints on the tv. Either on the chroma board, the vertical scan board, the line output board, or on the focus board. If you are going to do this yourself please take all necessary precautions against electric shock and discharge all capacitors that you can as a stray spark from one can cause damage to your tv and yourself. If you are not able to do this find a competant technician. Good luck.
Posted on Oct 05, 2008
  • 225 Answers
SOURCE: Floating Horizontal Line
Sounds like a bad component on the video board. These days, TV techs just swap out boards for whole new ones.
Posted on Nov 17, 2008
Hitachi-mex
  • 26 Answers
SOURCE: vertical lines on plasma tv
Maybe is a lose contact in the conectors of the screen.
You need disconect the conectors, clean with isopropilic alcohol, and reconect the conectors.
Posted on Jul 18, 2009
There is a horizontal line halfway 3/4 across the screen, it's not black it's just a different color.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 14, 2016 | Vizio E500i-B1 50-Inch 1080p Smart LED...
A horizontal band of green and red lines across the screen
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Why does my Hitachi 42HDS69 have horizontal green lines all the way across the screen? The sound is fine. The lines are not solid, they dotted-like, like snowy and are not thin. It started all at once when...
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 13, 2014 | Hitachi 42HDS69 42 in. Plasma Television
I have a 50 inch plasma tv. The other day when turned it on it sounded lke popcorn poping, now it has green lines and static lines across the screen.
I used to be involved with Currys Repair Service for flat screen tvs. It sounds like a video card has blown.
Sep 19, 2012 | Hitachi Televison & Video
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Hitachi Plasma very thin bleeding horizontal lines
very possible the YSUS board is going bad .If YSUS is going bad .I would also replace XSUS board since they are same age..Also whenYSUS is replaced make sure you make pot ajdustments as old YSUS and also with XSUS board
Aug 26, 2009 | Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Horizontal line or seam going from bottom to top of screen
Sounds like you have AC leakage somewhere. If you have cable TV, disconnect it from the TV and see if the line dissapears. If it does then most likely it is a faulty cable box or a bad ground on the cable system.
Feb 21, 2007 | Hitachi 42HDM12 42 in. Plasma Television
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Hitachi 42HDS69 42 in. Plasma Television Logo
125 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
