Question about Coffee Makers & Espresso Machines
When making a coffee the machine is pulsing! Any idea what is causing this?
  • 691 Answers
It depends on the make and model of the machine but this sounds like the one way valve in the pump is requiring more pressure for it open so the pump has to work a bit harder to push the water through resulting in the pulsing you experience.
allow the machine to cool, purge the steam and hot water then remove the pump assy.
Examine the NRV for free movement and check its operation. It may be scale causing it not to open properly.
Posted on Dec 14, 2014
2 Suggested Answers
projdoc
  • 2236 Answers
SOURCE: Coffee maker continues hot water flow even after
definitely clean out the sprayhead. also, you may need to reset the dispense time on the board behind the front panel. the instructions are on the panel itself. make sure the switch is on "lock" after you are done.
Posted on Feb 13, 2011
Rancilio Epoca S1 tank
Try editing brand and model number into your question.
Aug 03, 2015 | Coffee Makers & Espresso Machines
Bunn coffee maker ITCB-DV not pouring enough water
The pulse program does not result in lower volume. The control board adds time to account for the pulses. If you are encountering less water than before clean your spray head and spray head fitting. 75% of low volume service calls are from calcified spray heads.
Mar 29, 2013 | Bunn Infusion ITCB DV Coffee Maker
My Coffee Gaggia Vision is grinding and the coffee is coming out very weak. The billet coming out is very wet and small. Any solutions or ideas?
see this matter causes:
Make sure there's water in the unit's water tank.
  • 2 Unscrew the shower disk from the top of the unit and rinse it. Dry the disk and screw it back in place.
  • 3 Replace the coffee grounds with properly ground beans. Coffee beans that are either too finely or too coarsely ground will adversely affect the flow of coffee from the machine.
  • 4 Make sure the coffee in the filter is not packed too firmly if the coffee isn't flowing at all. If the flow is too fast, tamp the coffee down a bit more with the tamper.
  • God bless you
    Jul 18, 2012 | Gaggia 90950 Platinum Vision Espresso...
    I have problems with my jura capresso f60, it no longer makes coffee, it grinds the beans, but no liquid comes out. On the screen it says open tap, we have no idea how to fix this.
    Machine thinks that there is no water getting to the machine. Majority of the time, this is caused by blockages of coffee in the brew group due to improper cleaning. I'm not saying that you haven't been cleaning it but that is usually the cause. How old is the machine? And has there been a cleaning tablet been put through it every day? Advise removing the brew group and check all pipes are clear, clean all loose coffee and check if you can blow through all of the pipes if you can loosen them. Clean coffee outlet/spout also. If the machines water is fed from a tank, It could also be a small bit of dirt has been pulled through. Hope this helps.
    Mar 30, 2011 | Jura Capresso Jura-Capresso Impressa F60...
    Coffee maker continues hot water flow even after making 2.5l of coffee. Randomly some days it makes the correct amount and other days it makes anywhere from 6oz to 30oz more causing the airpot to overflow...
    Jan 27, 2011 | Bunn CDBCF 15 APS Coffee Maker
    My Bunn is taking forever to brew and the coffee
    It sounds like the thermostat might be allowing the water to boil and cause the grounds to be scorched and making your coffee bitter. It also could be caused by the machine needing to be cleaned and delimed. I would recommend you do this first-and if you don't have the use and care manual, you may call Customer Service to have one sent out or access one at www.bunn.com @ home, then products.
    Apr 09, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
    Saeco magic machine, all the lights are blinking. Turning the machine off makes no difference. Can't make coffee. occasionally if we run a cup of coffee it will stop the blinking, but now that does not...
    If all the lights are blinking in a row then you have a Main electronic board problem. Most common issue is that boiler has leaked water on board and caused it to fail.
    Mar 23, 2010 | Saeco Magic De Luxe Espresso Machine
    Our Saeco Vienna Deluxe will not stop grinding. Any ideas?
    Hi
    3 things
    1. Grind is too fine. Move to a very coarse grind, say 16.
    2. Move the small knob to the - side and try again.
    3. If that didn't work your going to have to clean you grinder.
    Need instructions? email me.
    Jan 05, 2010 | Saeco Vienna De Luxe Espresso Machine
    Repeat error message
    I've been through this with my Dacor coffee machine. I believe there is NO fix! Dacor replaced my entire plunger assembly and now it keeps sticking. The too much coffee error has gone but now I'm getting a persistent group error because of it getting stuck. I agree with "lilyfish" I wouldn't have purchased it either and to boot they have stopped making coffee machines!!! I'm looking at a Miele now.
    Mar 21, 2008 | Dacor CM24P-1 Coffee Maker
    Coffee Makers & Espresso Machines Logo
    60 people viewed this question
    Top Coffee Makers & Espresso Machines Experts
    Kolbrun...
    Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
