Question about SMC Computers & Internet
When you updated firmware for smc tigerswitch 8624t ware electricity outages and then tried to enter the setting by serial port but did not respond to me What is the solution
  • SMC Master
  • 2,219 Answers
This is a switch not a router.
You can find your answer here to reset the settings via a serial port.
rescue Password reset on SMC TigerSwitch 8624T
Posted on Jan 23, 2015
3 Suggested Answers
  • 25 Answers
SOURCE: Can I use SMCWBR14-G2 firmware to update my SMCWBR14-G's firmware
SMCWBR14-G Firmware V1.00.28
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_HUN&productCategory=1&modelNumber=1386&partNumber=3083&downloadType=2&knowsPartNumber=false
Posted on Jun 17, 2010
  • 515 Answers
SOURCE: I have a problem with
You can take a look at the installation guide and check the guideline about optic connection there if you didn't. If LED light up then you might need to check something on the second document on troubleshooting part.
http://www.smc.com/files/AB/MN_6724AL2_INS.pdf
http://www.smc.com/files/AU/MN_6724AL2_MAN.pdf
Posted on Jan 05, 2011
Error frime ware
If you had a power failure during a firmware update, the only thing that you can do is get a new router. I am sorry
Feb 22, 2014 | SMC Barricade g Router/ADSL2 Modem, 54Mbps...
HOW DO I RESET A SMC 10/100 TO FACTORY DEFULT
Remove the power cord from the back of the switch.
Remove all cables from the front panel ports.
Connect port 1 to port 2 on the front panel using a standard patch cable.
Reconnect power to the switch.
Wait at least 40 seconds before disconnecting the patch cable between port 1 and port 2.
After the above is completed, the password will be "smcadmin" and the switch IP will revert to 192.168.2.10
Mar 01, 2013 | SMC Tigerswitch 24-port 10/100 Switch...
Everyday I need to reboot SMC8024L as systems not getting IP address from stand alone DHCP server could you please suggest what needs to be done here ??
The lease time on DHCP IPs is usaully set for 24 hrs. Try assigning a static IP or changing the lease time. These settinbg are located in router.
Dec 21, 2012 | SMC8024L2 TigerSwitch Standalone 24-Port...
Connect two tigerswitch 6724AL2 via fiber port
How do I open ports in the Virtual Server? pix.gif pix.gif pix.gif You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows.
  1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter.
  2. Click on Login, Advanced Setup, NAT, Virtual Server.
  3. Enter the port details and enable it as follows:
Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows:
  2. Click on Login, Advanced Setup, NAT, Special Application.
Trigger Port Trigger Type Public Port Public Type Enabled 3724 TCP 3724 TCP Y 6112 TCP 6112 TCP Y 6881 TCP 6881-6999 TCP Y
* The port numbers given are just an example. You need to open the ports depending on the application you are using and should get the information from the application provider.
Jan 05, 2011 | SMC TigerSwitch SMC8612T
I have a problem with 2 smc tigerswitch 6724Al2 to connect them via fiber port
Jan 05, 2011 | Computers & Internet
How Can I reset the SMC 8612XL3 switch to default factory mode?
hi there Ramesh -- please rate me
i believe i have what you asked for .. read on
i found the following information
a 2 page overview for this item
http://www.smc.com/files/AR/ds_8612XL3.pdf
home page for this item
http://www.smc.com/index.cfm?event=viewProduct&cid=8&scid=44&localeCode=EN%5FUSA&pid=1179
**MOTHERLOAD**
manual http://www.smc.com/files/AQ/MN_8612XL3_MAN.pdf
command.
Default Setting
None
Command Mode
Privileged Exec
Command Usage
This command resets the entire system.
Example
This example shows how to reset the switch:
Console#reload
System will be restarted, continue ? y
i hope this helps you
Nov 05, 2010 | SMC 8612XL3 101001000Mbps TigerSwitch 1000...
Jan 02, 2009 | SMC Barricade g SMCWBR14-G (662698582192)...
At-8624t
How to Configure the Switch
Some configuration is necessary to enable the switch’s advanced switching
capabilities. This is achieved via the Command Line Interface (CLI). On the
AT-8624T/2M, you can also use the Graphical User Interface (GUI).
Using the CLI to configure a switch
1. Connect a terminal or PC to the Terminal Port (ASYN0).
Using the supplied RS-232 DB9 serial straight-through cable, connect your
terminal or PC to the RS-232 Terminal Port:
• For the AT-8624T/2M and AT-8624PoE, the RS-232 Terminal Port is on
the front panel.
• For the AT-8648T/2SP, the RS-232 Terminal Port is on the back panel.
2. Set the communication parameters.
Set the communication parameters on your terminal or terminal emulation
program to:
• Bit rate: 9600
• Data bits: 8
• Parity: None
• Stop bits: 1
• Flow control: None
3. Log in.
After the switch has booted, the login prompt appears. If the login prompt
does not appear, press [Enter] two or three times.
When the switch boots for the first time it automatically creates an
account with manager privileges. The account has the login name manager
and the password is friend.
At the login prompt, enter the login name and password:
Login: manager
Password: friend
The switch’s command prompt appears. Now use the CLI to configure the
switch.
Using the GUI to configure the AT-8624T/2M switch
This section describes how to establish a connection to the AT-8624T/2M switch
through the GUI so you can configure it before installing it in your LAN.
1. Select a PC to use and identify its subnet.
You can browse to the switch from any PC that is running a supported
operating system with a supported browser installed. JavaScript must be
enabled. If you are using a toolbar or plug-in on your browser to block popups,
disable it while using the GUI. The GUI displays detailed configuration
options and information in pop-up windows.
2. Connect the PC to the switch.
Use an Ethernet cable to connect an Ethernet card on the PC to any one of
the switch ports.
You can browse to the router through any VLAN, as long as you give that
VLAN an IP address. These instructions assume you are using vlan1. All
switch ports belong to vlan1 by default.
3. Access the switch’s command line interface.
Access the CLI from the PC, as described in the previous section, “Using
the CLI to configure a switch”.
Installation & Safety Guide 13
4. Enable IP.
enable ip
5. Assign the vlan1 interface an IP address in the same subnet as the
PC.
add ip interface=vlan1 ip=ipaddress mask=mask
6. Save the configuration and set the switch to use it on bootup.
create config=your-name.cfg
set config=your-name.cfg
7. On the PC’s web browser, bypass the HTTP proxy server, if
necessary.
8. Point your web browser at IP address for vlan1.
9. At the login prompt, enter the user name and password.
User Name: manager <the default>
Password: friend
The System Status page is displayed. Select options from the sidebar menu
to configure and manage the switch.
For context-sensitive online help, click the Help button at the top of the
sidebar menu or on any pop-up page
I hope this helps you out
podum
Sep 01, 2008 | Computers & Internet
Adding a PC to the network
Make sure your network card on the computer is enabled and properly installed. Also try replacing the cable with one that is known to be good. I hope this helps. Good luck.
Nov 05, 2007 | SMC TigerSwitch 6508TT
Computers & Internet Logo
151 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
