Question about Amana Heating & Cooling
How do I wire up a wireless programmable thermostat to an amana pthp (pth153g50axxx).also what type thermostat do I need
I looked on Internet for wireless programmable thermostat that are for a pthp and was unclear if they would work with my pthp .also if they work how do I wire it up
4 Suggested Answers
SOURCE: Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Posted on Aug 07, 2008
  • 3 Answers
SOURCE: Need wiring schematic
I had a standard schematic wiring diagram that can work in any kind of airconditioning unit.I will try to post that in this site.
Posted on May 10, 2009
  • 1033 Answers
SOURCE: I'm looking to replace my
Hello, there are many thermostats you can choose from that will work, honeywell makes great thermostats and i usually install theese for customers. Here is a link to thermostats you can choose from http://yourhome.honeywell.com/home/products/thermostats/
Posted on Jul 08, 2011
Initial setup power present but no lights are
Allot on the Honeywell digital, programmable thermostats need a 24 volt common wire to them, the old manual type thermostats, only need 2 wire, but the digital ones, need the common wire to run the lights and program.
They do make a digital, that will run on battery power only, so they require only 2 wires.
Have a great Day.
Sincerely,
Paul
Mar 23, 2010 | Honeywell Programmable Thermostat Heater
No Auxiliaty heat with new thermostat
The Vision Pro is a great t-stat and I have installed many of them with great results. I am wondering though if it is set up correctly. Did you go in and make sure that it is set for heat pump and for 2 stage heating? Look on the instructions how to get into the advance installer options. Go through that meanu and make sure that everything ig set correctly for your type of heating system and that it is set for 2 stage heating. From what you have here and I can tell the wiring should be okay that is why I think that it is in the t-stat programming.
Nov 15, 2009 | Honeywell Electronic Programmable...
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
May 01, 2009 | Heating & Cooling
Require room thermostat for ferroli combi boiler optimax 25c . I have a honeywell at the moment which stopped working. it has two wires coming into it from the boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Want to replace manual thermostat with programmable.
you can use a 5 wire heat pump thermostat.
Must be heatpump thermostat
red is 24 volt power
white is aux/emergency heat these usually will need to be jumped together
Green is fan
yellow is compressor contactor
blue is reversing valve
you just don't have a common so some thermostats will not work.
get one with batteries
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Greg
Aug 07, 2008 | Fedders AED24E7F Wall/Window Air...
Internet runs slow or freezes on my wired desktop when I use the internet on my wireless laptop.
Hi tech_newbie.... Need a little more info... how is your wireless connected.. ethernet /Usb... or true wireless... and vice versa for desktop. where is your wireless router situated... what times are you experiencing the slow connection!
In addition.. first try running a good Spyware/ adaware programme such as Spybot.. and alongside side another programme called... a-square.. and with AVG.. all of which are free... see links below..
http://www.safer-networking.org/en/download/index.html
http://free.grisoft.com/doc/2/
http://www.emsisoft.com/en/software/free/
Try this first.. they are all pretty good programmes when used in conjunction with each other, you;ll be surorised at what you find.... Get back to me if this does not eliminate your problem
Regards Faggly
Mar 19, 2008 | Computers & Internet
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
