Question about Stihl Garden
Ghening the stihl avt011 chain
Can't find the tightening screw
  • Stihl Master
  • 1,169 Answers
If you still can't find after reviewing the follow manual it may be lost.
Instructions for chain adjustments are on pages 21 and 22.
Stihl 010, 011 Operators Manual
Posted on Dec 14, 2014
  • 211 Answers
SOURCE: cant find the screw to tighten chain on saw
Hi
You have to look from profile to the chain saw(clean it)
best regards savumihai71
Posted on Dec 10, 2008
  • 1388 Answers
SOURCE: stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Posted on Dec 21, 2008
rwvanlue
  • 486 Answers
SOURCE: how do i tighten the chain on a stihl 038av
Normally, a loose chain will enhance it's ability to jump off when trimming small branches.
When installing and/or adjusting a chain;
1) install the chain, bar, and cover, and install the cover nut loosely
2) support the 'nose' end of the bar with a block
3) tighten the chain until it touches the bottom of the bar,
and then tighen the adjuster 1/8 of a turn more.
*this will make the chain just a LITTLE snug
4) tighten the cover nut, and then by hand CAREFULLY rotate the chain.
If you cannot rotate by hand, it is too tight. re-adjsut
** This proceedure must be used on ANY brand chain saw.
Here is why.
If the bar nose is not lifted upon adjustment, when cutting,
the nose will move upward, the chain will have a 'droop' away
from the bar and appear to have loosened while cutting.
Any contact with a small branch will flip the chain off of the bar.
If you re-adjust it improperly, the same senerio will occur the next cut.
Posted on Nov 22, 2009
dontbother10
  • 2220 Answers
SOURCE: Loose chain
Hello David; good luck to you.
I went here and input model 107624-01, followed the directions and when possible selected the IPL. I found pn 108640-01, item 32, NLA @ Remington Power:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Part Number 108640-01 is available here $13.99 - the picture is a complete assembly (cover, bar nuts, spacers and tensioner assembly).
PartsFor.com
http://www.partsfor.com/
If me I would use the phone number provided, ensure it includes all illustrated parts, order with a credit card (recover your investment much easier), get the name of the service person helping me and the name of her/his supervisor.
Please re-accomplish my steps to ensure I made no mistake, I do err occasionally (I swear on a stack of UCMJs covers have been NLA for quite a while).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 25, 2010
  • 6468 Answers
SOURCE: Tension screw won't tighten the chain on a Stihl MS660
remove the cover and look to see if the tab is broken off
Posted on Apr 15, 2012
My stihl ms-180-c chain saw will not keep chain tight. you tighten chain rev. engine chain will just about come okk -tighten chain rev. engine same thing.
you have to use the tension screw to move the cutter bar to tighten the chain then you do up the bar mounting nut to keep it tight
May 12, 2017 | Stihl Garden
Tip
Chain loose on your chainsaw?
Chainsaw bars get loose all the time. This can create a dangerous situation.
Tightening the chain is done through the positioning of the bar. The further away from the drive gear it extends, the tighter the chain is.
The are usually two nuts holding the bar on. These need to be loosened slightly to allow the bar movement.
Depending on your model there may be a guard over them. Remove it.
Once the nuts are loose, locate the tensioning screw. It will be relatively small, located adjacent to and facing parallel to the bar.
This screw is attached to a metal lip that in turn is attached to the bar. The screw remains in one place while the lip moves up down.
Start spinning. Keep going until the chain is tight.
Tighten the Bar Nuts, replace the guard if necessary.
Now go slice some wood.
Best regards
Mike
Keywords: Chainsaw, chain, tighten, loose, poulan, stihl, how to,
on May 18, 2010 | Garden
How do I change a chain on a Stihl ms 210?
Take off the side cover at the base and loosen the tension screw. Blade should slip off. Make sure when you replace it, you do not tighten it too far.
Sep 20, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
I have a Stihl MS 290, runs great, but the chain keeps tightening it's self on it's own
That's an unusual problem, usually the opposite happens. After making sure the chain brake is off, loosen the two nuts that hold the bar. Be sure to hold the bar up when adjusting the tensioner screw and adjust until the chain is just snug, but not too tight. While still holding the bar up, tighten the two nuts firmly. Check to see that the chain can move freely by hand. Then start the saw and run the chain at speed with something in front of the nose to check for adequate lubrication. You should note a slight fine spray of oil on the object in front of the nose of the bar. Inadequate lubrication, a chain that is binding on the bar, or an overly tight chain can cause the bar to heat up and expand, further tightening the chain. A properly adjusted Stihl saw will use almost all of the chain oil in the reservoir for every tank of gas. Too much oil is better than too little. The oil feed may have to be adjusted for operating in temperature extremes. If operating in very hot conditions, be sure that the saw has not run out of chain oil. The oil feeds faster when hot.
Sep 19, 2014 | Stihl MS 290 Chain Saw include 20" 50cm...
Stihl chain saw quetions
sounds like you have been tightening the chain to tight
Sep 05, 2012 | Stihl Garden
Apr 14, 2012 | Stihl Models 064, 066, Ms640, Ms660
How do you tighen a chainsaw chain?
Depends on the chainsaw. On most Stihl saws there is a screw between the two bar locking bolts that you turn clockwise to tighten the chain. On other saws the screw is in front of the housing that the bar and chain come out of and face into the housing, parallel to the bar. Clockwise still tightens the chain.
In both cases you have to loosen the nuts on the guide bar studs and then adjust the tension adjustment screw.
For more info go to the manufacturer's web site and download the owners manual.
Oct 24, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
Clearance for stihl ms 250 ignition coil
Rotate the flywheel until the magnets are under the module, insert a thin business card into the pole gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the pole gaps don't close further. Hope this helps!
Dec 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I have a stihl chainsaw model #311y and I need to tighten the chain .Can you help me?
loosen bar nuts, with gloved hand push up on bar, and turn adjuster screw clockwise. on stihls it's either beside bar facing forward or between bar nuts.
Feb 05, 2010 | Standard Oregon Chainsaw Chain For Stihl...
Stihl chain saw
shut off the engine
pull out the hinged clip and loosen the wingnut
turn the adjusting wheel clockwise as far as stop. (on top of the adjustment wingnut).
tighten down the wingnut firmly by hand
fold down the hinger clip.
go to the following link, if you need the users manual.
http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
Apr 09, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
98 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
