Question about Kenmore Washing Machines
Where do I find the serial number on a Kenmore grill?
It is still in the box I have looked at the back and under the lid and found nothing where do they mark the serial number?
  • 32 Answers
Some clever manufacturers put it on the packaging.
Posted on Dec 14, 2014
SOURCE: kenmore elite washer lid removal?
how do i remove the washing machine the top
Posted on Nov 04, 2008
JR JR
  • 116 Answers
SOURCE: washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Posted on Nov 30, 2008
lsteward68
  • 331 Answers
SOURCE: looking for belt for kenmore toploader washer model 82881100 serial C09724811 stock # 28811
did you try repair clinic .com
it should be here. http://www.repairclinic.com/Kenmore-Washing-Machine-Parts?s=b6a11c203
Posted on Jun 01, 2009
  • 1218 Answers
SOURCE: Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Posted on Mar 01, 2010
jsrock516
  • 5911 Answers
SOURCE: How do you check the lid switch on a Kenmore
The lid switch on this model is located under the operator console adjacent to the left lid hinge. You will need to follow these steps to troubleshoot:
1. UNPLUG the washer before servicing.
2. Using a putty knife, insert under the front two corners of the operator console and push straight back to depress and release the retaining clips.
3. With the clips released, the console will lift up, exposing all the internal components.
4. Locate the lid switch and unplug the connector.
5. Using a multi-meter, on the Rx1 resistance scale, connect the meter leads across the terminals of the LID SWITCH. The lid switch is activated by an actuator rod on the left lid hinge. As the lid opens and closes, you should see the resistance change between infinity and a short, if the lid switch is working properly.
NOTE: If the lid switch is functioning, you should also hear it "click" as you open and close the lid. In some cases a simple adjustment to the actuator rod (by bending it slightly) is all that is needed.
6. An alternate method is to jumper across the terminals of the connecter plug end that goes to the TIMER and by-pass the switch. Make sure the jumper does not come in contact with a metal surface, so insulate if necessary.
7. Plug washer back in and op test. If the washer works normally, with the switch by-passed, then you may have a defective lid switch, or need to adjust the actuator.
Replacement parts, if required, can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The lid switch is listed as item number 11 under the "Top and Cabinet Parts" section. A good view of the retaining clips for the operator console is under the "Control Panel Parts" section as item 8.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Apr 05, 2011
I have a piano made by Laffargue piano co ewyork. The serial number is 70805. The piano has Seaverns written on it. Can you tell me the age of my piano please?
(1905)!! Please Read On How To Tell How Old Your Piano Is !! I Learned This From Grandma !!
Piano serial numbers usually have five to seven digits, but may have fewer or more, depending on the manufacturer and age of your piano. Serial numbers may also include a letter as well.
Here are the TOP FIVE places to locate the serial number of your spinet, console, or upright piano:
Serial number locations are found:
1) On the piano's cast iron plate. After lifting up the lid, look along the top front area of the plate. The serial number may be to the right or the left, or in the middle.
2) Under the opened lid on the ledge, stamped on a little plaque, to the right or to the left.
3) Stamped on the back of the piano; near the top of the wood frame.
4) Printed on one of the hammers, found on either end of the piano (newer or imported pianos).
5) Printed on one the keys - behind the nameboard, inside the piano (newer or imported pianos)
Aug 25, 2017 | The Music
I HAVE 1996 ACCURA TL 2.5 I NEED THE CODE FOR THE RADIO THE SERIAL NUMBER OF THE CAR RADIO IS 94A103119
Code is at 3 places in your car, hopefully one is still there . look in orig. book, front or back s/b written. second in glove box, a white sticker. never there!
best bet it under cover of fuse box in front under hood passenger side (R) has relays for ABS, should be a sticker under lid. usually still there. otherwise pull radio and get serial # . good luck.
Dec 18, 2011 | 1996 Acura TL Series
How do i remove my old lid switch and put in a new one
this video will show ya exactly how to replace the lid switch.The number ya have though isnt the model number i can be found under the lid toward the back just above where the water enters the tub order the exact part# by going to searspartsdirect.com to find the part# then you could either order it directly from sears ora local parts dist. that could be found by a quick look in your local phone book or a google seach for parts dist. in your area watch this video.......http://www.youtube.com/embed/MFsvLiuTniU" frameborder="0" allowfullscreen>
Jul 13, 2011 | Kenmore 24032\24036 Top Load Washer
Find serial and model number
Normally on top load machines open the lid and look toward the back hinge area inside the lid. It is usually on the back there. It may also be posted on a white sticker on the back of the machine.
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I'm trying to find out how old my mothers wash machine is. The model numbers in 2270
The date of manufacture is determined by the SERIAL NUMBER on the appliance. Since Kenmore washers are manufactured by Whirlpool, the following link explains how to determine how old your washer is:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The serial number will be listed on a nameplate along with the model number along the wash tub rim under the lid. The second DIGIT in the serial number identifies the YEAR it was manufactured. The first set of NUMBERS following that digit represent the WEEK it was manufactured (52 weeks in a year).
If you need help determining the date, please post back with your serial number so I can assist you. I hope you find this information helpful.
Mar 29, 2010 | Kenmore Washing Machines
Kenmore model 8662100 heavy duty what year is it and is there still parts available for it?
Please post back with your COMPLETE serial number (usually located along the wash tub rim under the lid) to include any letter designations. This determines when the appliance was manufactured. The model number you provided crosses to a dryer. If this is a dryer, the serial number will be find along the door opening. Please confirm your model number as well. The number should begin with a "110" prefix. You listed this as a kenmore heavy duty...and listed it under washing machines. If this is a washer, I will need a more accurate model number (if possible) to be able to determine part sources for you.
Jun 29, 2009 | Washing Machines
Honda CRV 2005 asking for radio code
hi!
well check for the radio code as in following steps:
1:Under the Hood of the Car is a Fuse-Box. (Different Fuse-Box than Inside the Car) This Fuse-Box has a Lid. Under this Lid is the Radio Code. Therefore, lift the Lid off Completely and the Code is underside of this Lid.
Look in your glove box for a white sticker with black numbers on it. The sticker will be about 1 1/2 inches long and 1/2 in wide. There should be 5 digits on it. These 5 wonderful numbers are your radio code. Put the code in through the preset buttons on the radio. You'll hear a beep and the radio will come back to life. (though you'll have to reprogram all your presets)
2. Ok, there's a sticker there, but there's more than 5 numbers on it! What do I do with that? Don't worry, that's the serial number for the audio unit. Call a dealer, tell them what happened and that you have the serial number and they can get the code for you for free. Write the code down and stick it in the glove box. Follow the steps in #1 above.
3. There's no sticker in my glove box, what now smart guy? Don't panic if you don't find a sticker, there are other places it's put sometimes. Check your sunglass holder (applicable models), the center console, even under the arm rest. I've even seen them under the cover of the under-hood fuse box. Check all these places and hope that u will find ur radio code!! good luck!
Dec 28, 2008 | Car Audio & Video
Washer fills with water, then stops
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
