How to program septre tv volume to twc remote. Twc said code 276, but didn't work
Called twc. They walked me through using code 276. It did not work. Twc said tv volume probably couldn't be programed.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Try an other code to Septre brand TV. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 14, 2014
5 Suggested Answers
Agent Jason
  • 78 Answers
SOURCE: Cable Remote
Hi hoff8434,
Insignia® has a remote control code web tool on their website at http://www.insignia-products.com/universalcontrolcodes.aspx. I input your information, but they do not have specific information for Time Warner remotes. For your model, it mentions you should try the codes listed with your remote for Orion, Emerson, Memorex, Sansui, Sylvania, and Zenith. Hopefully one of these codes will give you full or partial functionality.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jul 21, 2008
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
UberTechzor
  • 295 Answers
SOURCE: programming twc remote to sanyo tv
Hello Leon Love,
Welcome, and thank you for using FixYa!
To answer your question: Here is a list of Sanyo codes that I know of. I hope there is one here that can help you. It may not have been in your list.
SANYO004 013 049 108 110 180 209
Have a great day!
Posted on Dec 02, 2011
  • 2509 Answers
SOURCE: Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Posted on Nov 13, 2014
Samsung blue ray bd-p1500 no remote can't program on my twc/spectrum remote
Your twc/spectrum remote may not contain an applicable code.
Feb 12, 2017 | Samsung Televison & Video
What is code for Seiki TV?
that is because sony remote is not a universal and will only control the original sony which it was sold with
Feb 09, 2016 | Sony Televison & Video
Philips TWC RC122 remote control code for TV
this may help:
http://www.timewarnercable.com/en/support/program-your-remote/RC122.html
Oct 03, 2015 | Toshiba 19SL410U 19 LCD TV
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
You may have to try another programmable remote to search for and find a code that will control your Sceptre TV.
Dec 13, 2014 | Televison & Video
Westinghouse codes
I just bought a 40" Westinghouse at BestBuy and had the same problem. My TWC remote still had the code from my old analog Samsung. Fortunately I kept the code sheet from Time Warner and using the 3 digit method reprogrammed it. Westinghouse uses 4 dif codes on their LED-LCDs. Here are the 3 digit code nos. 076 276 435 001. I ran thru the first 3 and mine was 001. Whoever your provider is use their remote to do this and not the one that came with your set. I used that remote to make all the adjustments on my set to fine tune it, color, sound, etc.following the menu. Hope this helps.
Aug 18, 2014 | Westinghouse Electric LD-3255VX 32 in. TV
Remote code
I have a 37" Olevia Tv with a synergy V remote from twc. The codes that the manual said didn't work, however, if you do the press and hold technique, and hold for several minutes it will find the correct code (volume/on/off) will work. Good luck
Dec 16, 2007 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
