Can you tell me the normal (factory) sound settings i.e equalizer, bass, treble, balancr, volume in videocaon 32" LCD tv
I changed the setting and i want bring it back to factory settings
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Do a factory reset to this TV. It will make all to factory settings.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Posted on Dec 14, 2014
SOURCE: how to restore Dynex LCD TV back to factory
http://www.avsforum.com/avs-vb/archive/index.php/t-1151994.html
this site has free directions to reset it
Posted on Apr 22, 2011
mjjdesigns
  • 98 Answers
SOURCE: Speakers Shot?
Technically, the television should protect itself from doing any damage, but sometimes that doesn't happen correctly.
When you say that they sound like the speakers are blown, can you describe that sound?
If it sounds like they're blown, they likely are.  It's probably about the same cost to repair the speakers (if out of warranty), than to buy an external amp and speakers.
Posted on Mar 19, 2009
  • 814 Answers
SOURCE: I plug in headphones, but sound still comes out of TV speakers
This information was found on the Dynex website: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) in the frequently asked question section on page 7. If the solution below dos not work for you. You can either go to the website by copying the web address and putting it in your address bar. Once there you can use the e-mail function to talk to customer support. You can also use the Dynex customer support telephone number 1-800-305-2204 between the hours of 7am and 12 am CST. Give them the model number of your television and the problem you are having with the use of the headphones. I hope this information helps you solve your problem. How do I get headphones to work with my TV? o Connect the headphone cable to the headphone jack on the side of your TV. o The sound will be heard through both the headphones and on the TV speakers. o Press Mute to hear sound only through the headphones. o Use the volume buttons on the remote to adjust the volume level. o You must remember to press mute again to hear sound through speakers. It will not automatically come on when you unplug the headphones.
Posted on Jun 06, 2009
SOURCE: Dell 32 inch LCD Tv volume and menue problems
I had the same problem with my tv.No sound! I finally figured it out. It was the speaker wires! Once I changed them to a slightly stronger speaker wire, it worked great! I have sound to my tv and I haven't had any problems since then.
Posted on Dec 16, 2009
SOURCE: My sharp aquos 32' LCD has a heavy green tint to
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Posted on Mar 15, 2010
Can you tell me the normal sound settings i.e equalizer, bass, treble, balance, volume
Usually there will be a "Reset to default settings" option.
Try it and see. All settings that you changed will be reverted back to original settings using this option.
Dec 13, 2014 | Televison & Video
42" LED42C45RQ need volume configuration
Hi Jennifer,
Settings of bass, treble and equalizer is a matter of personal choice. You can set them to your liking. Alternatively you can choose the sound mode ( like music, movie and theater ) of your choice. The balance setting off course must be in the middle or zero position so that both the speakers give equal amount of sound. In equalizer the extreme left column represents the low frequency sounds like the sound of drums. As you move rightwards the sounds go on becoming finer and finer and the extreme left column represents the fine sounds of the instruments like violin and sitar. Somewhere in the middle is there is human voice also. Play some music, try varying each column and see the effect. Good luck.
Jan 19, 2014 | RCA 42" LED42C45RQ Class LED 1080p 60Hz...
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
How to turn sound on phillips plasma 32 inch tv
Hello
I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
Oct 31, 2010 | Philips 32PT6441/37 32" TV
Wanted to adjust quality of sound, such as treble
Go in ur menu pick the audio go down pick the reset the tv set back to factory setting will get the
Mar 24, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
My sony erisson mobile ringing volume low how can increase
go to menu,ringtone settings,then go to ringtone volume and adjust it according to ur need,u can use side buttons for this also.
Dec 05, 2009 | Sony Ericsson w580i Cellular Phone
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
Televison & Video Logo
5,911 people viewed this question
Top Televison & Video Experts
Electro Med Services...
