Question about Audiovox Vehicle Parts & Accessories
I just replace the battery of my remote audiovox car alarm and it didnt work anymore
Replace new battery to the remote audiovox car alarm system
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
jpk528
  • 95 Answers
SOURCE: prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Posted on Feb 16, 2009
  • 33 Answers
SOURCE: How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Posted on Jun 20, 2009
  • 24 Answers
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Posted on Nov 04, 2009
  • 11 Answers
SOURCE: Audiovox Pursuit Pro keyfob reprogram
if thats the picture of the transmitter to program it you have to : turn the ignition to on position. press and release the programming switch 3 times... press and hold,for 3 seconds, the buttonof the transu wish to add until the parking lights flash. this would mean the transmitter has been learned. repeat step 3 for each transmitter... turn the ignition off to exit the program mode..
do not let 15 seconds pass between steps.
Posted on Jul 26, 2010
My car alarm key remote is not working. alarm not responding to remote. is remote broken
This might sound stupid, but have you tried first replacing battery in remote, this could cause this instantly, just like a TV remote. First try that. Hope that solves it right away.
May 15, 2011 | APS787 Prestige Remote Start and Security...
Why alarm only works when close to car
Poor range can be caused by a number of things. Has this problem only been occurring recently? If yes, try replacing the battery in the remote transmitter since a weak battery can be a problem. If this is a new install, bring it back to the installer to have them check it. Other possible causes can be improperly positioned antenna, the alarm brain installed too close to an electronic control unit, the alarm brain mounted to a large ground plane or a defective alarm brain.
Oct 22, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I am not sure if my AudioVox APS95BT2 2-Button Code Learning Remote is the reason my car wont start. Yesterday, the remote stopped locking the car and then today my car wouldnt start and I am not sure...
If the remote is not working, then disarm the alarm manually. Turn the ignition on and press and release the valet switch one time. You should hear two chirps from the alarm. Start the car. If the car starts then replace the remote battery. If the vehicle fails to start after disarming the alarm then there could several other issues. Does the vehicle attempt to start, i.e. clicking from the starter, motor tries to turn over, etc.? Does the car battery have the power to start the car?
Sep 22, 2010 | Car APS95BT2 2-Button Code Learning...
No remote for alarm
until you get a working remote, you should unplug that alarm
Dec 14, 2009 | Prestige Remote Start
Alarm remote dropped in water alarm enabled on car..no entry
open your remote soak the circuit board in 90% rubbing alcohol then blow dry on medium heat it should work as good as new
Apr 01, 2009 | Prestige 2 Button Remote Security System...
Instruction Manual
I just had a new motor put in my car 01 concorde and now the remote starter wont work but the alarm does
Feb 07, 2009 | Car XR9000 Two-Way Confirming Remote Start...
Trying to replace the remotes for my car alarm
it is possible, you need to find an audiovox retailer first. then you MUST know the model number of your specific alarm. then retailer or installer can find you new compatible remotes, but you or them will have to find manual for your model to get your alarm"brain" to properly "learn" the new remotes. it is always a very specific procedure, not universal to all alarms.
Jan 14, 2009 | Audiovox Vehicle Parts & Accessories
Audiovox car alrm
what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
Sep 11, 2008 | Audiovox Car Audio & Video
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
