Question about Home
Im not getting any hot water through my shower.
  • 36 Answers
It is a good possibility that the pipe had closed off from residue buildup in the pipe.
Posted on Dec 14, 2014
  • 374 Answers
SOURCE: Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Posted on Oct 21, 2008
SOURCE: water in shower not very hot
It could be possible you require more water volume, so take off both panels on youur water heater and check what temp. they are at.
I know I discovered the hard way there are 2 heaters and 1 of mine was low,good luke.
Posted on Mar 27, 2009
  • 297 Answers
SOURCE: Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Posted on Jul 26, 2009
  • 35 Answers
SOURCE: Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Posted on Feb 23, 2010
heatman101
  • 43501 Answers
SOURCE: shower/tub combo hot water problem
There is a restriction in the faucet or the piping to the faucet on the hot wtaer side...this will be very hard to find and fix... The shower uses less water so it will get hot.... the tub spout allows more water flow so you cannot get the water more then warm...
Take the faucet apart and blow out all the passage ways with air... also run some water from the piping while the guts are out of the faucet, to flush the piping...
Hopefully this will fix you up...
Heatman101
Posted on Mar 04, 2010
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
Shower has a reduced flow of hot water.
Im not familiar with the combi boiler system but on must types of HW systems there is a small tap valve situated toward the top in the pipework.
Nov 13, 2011 | Home
No hot water comes out of shower just cold comes out even when turned to hot, sink 2 feet away has hot water
The problem more tha likely lies within the shower valve body. Possibly the shower head has an accumulation of deposits clogging up the holes but that would not affect the hot water supply only. You might try removing the shower head and turning on the hot water. If you get hot, immerse the head in Limeaway for a hour or two and replace it, or install a new head. If you still do not get hot water, the shower valve needs attention. The cartridge inside the valve body will likely need replacing or at the least cleaning (Limeaway), replacing rubber seals and use plenty of silicone grease before re-assembly.
Oct 26, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
Not too hot the water
Need to descale the heater coating by first treating with an acid and then neutralise with an alkali solution.
Apr 15, 2010 | Hansgrohe 27118821 Brushed Nickel...
No hot water
If you pull the trim off of the valve you will find the balancing caulk it is 1 inch diameter slotted screw. Unscew that and shake it or tap it on something until it rattles. then reinstall.
Feb 13, 2010 | Moen 3175 Legend One Handle Shower Faucet...
No hot water coming through the shower system, though hot water comes through the pipe without system attached
When you adjust the dial to mix the hot and cold for your desired liking, it goes into a mixing chamber before going to the shower head, im asumming your issue is within the mixing chamber.
Nov 05, 2009 | Hansgrohe Shower 26101 Pharo Prestige...
Home Logo
46 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
