Question about Sharp Office Equipment & Supplies
How to clear error code f2-64 in sharp ar5618 copier
I have change the toner cartridge
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Unplug it for a full minute from the power & the computer & replug & start again aft a min.
Posted on Dec 14, 2014
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 26 Answers
SOURCE: ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Posted on Feb 21, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 1297 Answers
SOURCE: SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Posted on Sep 01, 2009
  • 118 Answers
SOURCE: error code E000001-0003 canon clc2620n
it is a fusing/fixing error try this on the control panel press * with head 2&8 together *with head >copier>function>clear>err>ok turned off/on the machine hope this help
Posted on Oct 03, 2009
How to unlock toner cartridge in sharp copier Ar5618
open the front door then pull the toner cartridge
Jun 18, 2016 | Sharp Office Equipment & Supplies
AR5618S copier. What will correct an f2-40 error?
replace the toner drum cartridge with OEM using third party????
Jul 20, 2015 | Sharp Office Equipment & Supplies
How to clear error code f2 in ar5618 copier
Go to the Manufacturers web site and view FAQ's & or e-mail them.
Dec 13, 2014 | Office Equipment & Supplies
My machine model AR5618s error code 2 and F than
f2 mean toner chip disable.You should buy new one cartridge.There are easy to get only chip,please buy new chip and assemble this chip
Oct 20, 2013 | Office Equipment & Supplies
I have a Sharp AR-163 copier and it flashs U2 40. Does anyone know what the problem is?
Most commonly a toner cartridge issue. First try removing then reinstalling the toner cartridge and power off the machine. If this does not solve your issue then reset the error using the following:
Press these keys in sequence: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, press print, it will ask are you sure? press yes.
This will reset the code so you can see if the code comes back
If it does then you have to change the toner, it has a defective crum (counter chip) on the back of it
Oct 21, 2009 | Sharp AR 163 Copier
65 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
