How to clear error code f2 in ar5618 copier
How do i clear the f2 error code after replacing new toner cartridge
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Go to the Manufacturers web site and view FAQ's & or e-mail them.
Posted on Dec 14, 2014
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
checkitright
  • 1362 Answers
SOURCE: error f2 in copier ar 5127
F2:
00:TONER SENSOR
02:TONER SUPPLY PROBLEM
04:WRONG COUNTRY,WRONG CARTRIDGE,DRUM
05:DRUM PROBLEM,WRONG CARTRIDGE
39:PROCESS UNIT THERMISTOR PROBLEMS
58:PROCESS HUMIDITY SENSOR PROBLEM
Posted on Sep 26, 2008
SOURCE: REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Posted on Oct 09, 2008
  • 26 Answers
SOURCE: ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Posted on Feb 21, 2009
Sharp Tech
  • 63 Answers
SOURCE: Error code f2-04 after changing to new toner
F2 04
  • Identification error
  • Model error
  • Type error
  • Destination error
  • Data abnormality
  • Misc error
It is always recommended to use OEM toner. The toner you need if AR-310NT
Posted on Oct 12, 2009
How do i clear f2-73 after using program 88-6 how can i revers it back to normal
F2-73 refers to an improper yellow toner cartridge detected in your machine. The fault usually lies with the small chip installed on the rear of the toner cartridge.
The first thing to try is turning the machine off & then back on using the main switch inside the front door. The switch is located in the bottom left corner.
If that fails then you will have to replace the yellow toner cartridge.
If after replacing the cartridge, the error code re-occurs then you may have a toner motor supply problem. In my experience, replacing the relevant toner cartridge resolves the error code.
Hope this helps.
Dave.
Mar 07, 2016 | Sharp Office Equipment & Supplies
AR5618S copier. What will correct an f2-40 error?
replace the toner drum cartridge with OEM using third party????
Jul 20, 2015 | Sharp Office Equipment & Supplies
How to clear error code f2-64 in sharp ar5618 copier
Unplug it for a full minute from the power & the computer & replug & start again aft a min.
Dec 13, 2014 | Sharp Office Equipment & Supplies
My machine model AR5618s error code 2 and F than 64 what solution?
According to the service manual
F2-64
Content
Toner supply abnormality
Detail
When toner near end is detected with the toner supply time of 50% or less.
When the toner supply time exceeds 300%.
Cause
ATC sensor abnormality
Check and remedy
Replace the toner cartridge.
Replace the developing unit
Aug 24, 2014 | Office Equipment & Supplies
f2 mean toner chip disable.You should buy new one cartridge.There are easy to get only chip,please buy new chip and assemble this chip
Oct 20, 2013 | Office Equipment & Supplies
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
May 23, 2008 | Sharp AR-M237 Copier
jasbo
jasbo
