Question about Gestetner Office Equipment & Supplies
My machine is Gestetner dsm 725 I have a functional prolem sc672 please I want to know the reason
    Champion:
  • Gestetner Expert
  • 208 Answers
Unplug machine. Remove connectors to the hard drive. Does it boot up now? Yes, then replace the hard drive. No? Then the controller board is defective.
Posted on Dec 14, 2014
4 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: how do you install an ethernet card on a gestetner DSM645 copier/
Are you trying to install an ethernet or "NIC" card in order to turn the machine into a printer? If so then you need more than a nic card. You would also need a ROM chip, Print controller, Hard Disk Drive and the buttons for the control panel.
If you are just replacing a NIC and expanding the memory then that is possible but the instructions to do so would be more than could be typed up here.
Posted on Jan 16, 2010
  • 903 Answers
SOURCE: Faxing with Gestetner DSm 635 sp Copier
There is a fax module that you can purchase to be able to fax from the copier. If it is already installed, you will see two phone jacks on the rear side of the machine. One will be labeled "Line" and one will be labeled "Tel" -- if you plug a phone cord from the jack in the wall to the jack labeled "Line," your copier is all ready to fax.
On the operation panel, there should be a button on the left labeled "Fax" under the buttons labeled "Copier" and "Document Server" -- press that button to get to the fax screen.
Hope that helps!
Posted on Jul 18, 2010
  • 44 Answers
SOURCE: how do I make gray
Once in service mode (CLEAR MODES KEY, 107, HOLD CLEAR STOP KEY) enter sp 2902-003, enter test pattern#16 and press start. press copy window and select paper size, press start key twice to start test print. press sp mode to return to sp mode display. Hope this helps
Posted on Jul 17, 2011
I have Gestetner DSm 615 but it does not show where to insert Ethernet card
Hi ya,
k, not sure if you have all drivers n stuff so maybe you'll get what you need from here, click or copy link, hope this helps, n g'luck, paul. http://support.ricoh.com/bb/html/dr_ut_e/nrg/model/x2015_18/x2015_18en.htm
Jun 17, 2016 | Gestetner Dsm 615
How to solve code 390 in dsm 620
Plz change the developer machine working fine
Feb 19, 2015 | Gestetner Dsm 615 616 618 620 716 721...
How do I fix the broblem of functional error sc672
Yes, disconnect the HDD. If it boots the HDD is defective. If it does not boot, then you have a bad controller board.
Dec 13, 2014 | Gestetner DSm725 All-In-One Laser Printer
My dsm 725 screen not responding to touches. any way to reset?
Bad touch screen. Easy to replace with a phillips screwdriver.
Part number:
H3106173
Aug 26, 2013 | Gestetner DSm725 All-In-One Laser Printer
Could you please send me the keys code for dsm 645 copier
On the display the message came up to call for service with the code SC546what can I do to fix it myself. the machine is not working for printing. machine is ricoh modle SDm645
Jan 22, 2013 | Gestetner DSm645 Digital Imaging System
I have Gestetner DSM 730 and it give me an error of serial no: k8654300136, so the problem
how can I reset one copy Gestetner DSM 730 if screnn touch does not afiche we do not even know the code up above.
Feb 11, 2012 | Gestetner DSm730 Black and White Copier
How do I make gray scale copies on the Gestetner DSM 725
Jul 15, 2011 | Gestetner Office Equipment & Supplies
My gestetner copier dsm 616 use to show sc 322 code
That code refers to a Laser problem.
It could be toner dirty and only need to vacuum it. But you have to know how to get in the Laser unit.
If you do not have that knowledge i advise you to call your technical support.
Jun 29, 2011 | Gestetner - DSM-616 COPIER Copier
At first when machine get ready then i place the original in ADF and set start the copy get out and message (please wait) appear on display and machine hung up then i removed NVram and Sdram and sc 672...
This code is related to a bad communications between the controller and the operation panel.
Could have the following causes:
- Controller installed incorrectly
- Operation panel harness disconnected or defective.
- Controller board defective.
(also check the jumper on the MBU fax unit. It must be set at the ON position)
I give this answer for the SC672 assuming that you know why you remove the NVram...
Apr 11, 2011 | Gestetner DSM 651 Copier
Hope that helps!
Feb 05, 2010 | Gestetner DSm635sp Digital Imaging System
66 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
