Question about Denon DP-300F Turntable
Brand new Denon DP 300F turns extremely slowly.
I have a problem with a brand new one. At first everything was fine. Third disc, all of a sudden it turns extremely slowly. Like a minute per turn type of slow. It seems the motor is turning slowly. It is not a belt issue. Everything is brand new and clean. No grease or dirt or anything mechanical that seems to be in the way. Do you have any suggestion ?
  • Denon Master
  • 5,056 Answers
The turntable should be under warranty still so contact the makers and they should sort it out. Any tampering with it could void any warranty so don't let any unathoriesed person touch it.
Posted on Dec 15, 2014
3 Suggested Answers
maklean
  • 1665 Answers
SOURCE: belt fell off
There are two main types of phonograph turntable drives still being manufactured today, the belt-drive and direct-drive systems; the names are based upon the type of motor system found in each.
In a belt drive turntable the motor is located under and to the side of the platter and is connected to the platter by an elastomeric belt.
The design of the belt drive turntable allows the use of a less expensive motor than the direct-drive turntable. Also, the elastomeric belt absorbs motor vibrations which would otherwise be picked up by the stylus.
Posted on Jul 18, 2008
  • 66 Answers
SOURCE: platter turns slow
This turntable design has a direct drive system instead of belt drive (two types). If this unit has been in storage for some time, it has most likely been at hot or cold tempuratures - not good for any electronic/mechanical system.
My guess is that the direct drive motor needs to be rebuilt - internal friction is probably keeping it from operating at proper speed. Best to consult with a repair shop that can handle direct drive turntables - several on the internet, if you cannot find one locally.
BTW: You can find a manual for this at : http://www.vinylengine.com/library/denon/dp-45f.shtml
Best regards,
Andre
Posted on Sep 26, 2008
If like what you say the deck is brand new you should contact the service center. They will attend to the matter free of charge. Web address follows:
http://denon.custhelp.com/
Dec 13, 2014 | Denon DP-300F Turntable
Why has the Bluetooth stopped working suddenly, it is brand new it was working fine, and now we cannot pair anything to it
there were several links to this let me know if you need more help just watch the video.
Nov 13, 2014 | Denon AVR-900 Receiver
How to adjust dp-300f speed
Both the owner's and the service manuals for your turntable are available for download:
http://www.vinylengine.com/library/denon/dp-300f.shtml
You only need to register (free) with them.
May 28, 2014 | Denon DP-300F Turntable
Have a brand new Denon DP-300F turntable that worked fine for the first two recods. Now when I use it the records sound as if they are playing in slow motion. Could there be an issue with the belt eve
It could, but it could be caused by something stuck inside it, perhaps from the packing or some other bizarre thing connected with it being transported to your home.
Feb 27, 2014 | Audio Players & Recorders
Running VERY slowly
The thing to do is to check the belt first, then look at things like is there a build up of grease dirt anywhere. Clean up the platter make certain no grease or dirt is the works causing it to slow down.
See also that the motor that drives the belt can turn freely and very easy by hand.
Jan 25, 2014 | Denon DP-300F Turntable
New DP 300 f with uneven speed ?
then you need to turn the potmeter , but since it is new, return it...
Jan 13, 2014 | Denon DP-300F Turntable
Denon dp-29F won't turn
hit it with a hammer...............
or the other option is to switch off the unit at the wall, then switch it back on again.
Dec 06, 2013 | Denon DP-29F Turntable
In my DENON DP-300F tone arm don't come back after playing record. It just stays in the end of record? How can i fix it?
A lot of decks don't actually do that anyway. But if it previously did this then it's probably a mechanical problem. Removing the bottom of the turntable might show up the cause of the problem.
Dec 08, 2012 | Denon DP-300F Turntable
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
Denon DP-300F Turntable Logo
126 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
