Question about Hoover Washing Machines
My Hoover Galaxy is not filling up,only the Hot water tap works.
Tried turning off and leaving for awhile. Tried the different water levels and diffrent loads.
Sounds like the cold water intake valve has failed and will need replaced
its solinoid coil is prob open circuit
Posted on Dec 14, 2014
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
Fisher
several reasons --tap not turned on---- solenoid that controls the water valve is burnt out--- and the water level control is registering full all the time.. Check that the tap has not been turned of---check that the little filter in the hose at the tap end is not blocked---change hot to cold hoses and see if hot water solenoid works. disconnect small tube to level controller and see if it opens the water solenoids.
Jun 23, 2013 | Washing Machines
Washer not working. Showing code HF or FH
On my hoover 200m (top loader) I had a similar problem. I turned off the machine & unplugged it. Closed water taps both hot & cold. Manually emptied machine with large cup. Undid bottom outlet hose by unclipping.The residual water will come out! I undid the 3 screws on the control panel. Tilted the control panel forward. The water level is manual control using a diagaphram pressure control to set water level. This had a hose. I disconnected both ends and used a bicycle pump to blow air thorough it. Underneath I disconnected where the hose goes into machine (clips) and also blew air from the top to check it was clear. After reconnecting everything the machine now does not stop filling and does not overflow anymore. Hope this helps.
Mar 08, 2013 | Washing Machines
Hoover 705 , overfills and fllods laundry can it be fixed
Jul 28, 2012 | Hoover HTC243 Top Load Washer
Hoover nextra HNL662 will not fill ,door lock will come on ,but unit will not fill
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 11, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Cold water filling is very slow despite good water pressure and taps fully turned on
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2011 | Hoover Washing Machines
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
Water won't cut off when filling... Hoover Galaxy A6834
Hi Steveb6723 ,Just read your posting.Now here is a little test I need you to preform so I can tell if the problem is your water valves or your pressure switch system.Now 1st turn it to a normal cycle and only select the cold fill.Pull the knob out so it starts to fill.Now turn the machine off at the power point,Does the water stop filling straight away?If it does select hot fill and pull the knob.When it starts filling on hot water turn the power off again and see if the water
stops straight away.Please reply and tell me if the hot or cold water continued to flow when the power was off.Looking forward to your reply.
Jun 24, 2010 | Washing Machines
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
