Question about Whirlpool GU2400XTP Built-in Dishwasher
The center white plastic center piece with arms fell off. Where does it attach and how?
Clear enough .
    Problem Solver:
There should be a white type screw that goes in the middle and scews into the middle
Posted on Dec 14, 2014
Frigidaire gallery dishwasher top arm fell off
Reva Daniel, I have actually had this happen to my Frigidaire Pro Series d/w. We have put some tall stemware in the upper rack and this was blocking the rotation of the top arm it actually unscrewed the nut that holds it on. So here is how I have fixed it.
1. Locate the 3 pieces (the nut), (the arm) and (the white plastic connecting piece). the white piece is very small it will most likely be on the very bottom of the dishwasher.2. The small white plastic piece sits inside of the nut and protrudes through the nut and snaps into the arm.3. take the 3 assembled pieces and tighten back on to the top of the wash tub. be patient when tightening this ,it is easy to cross thread. That is all there is to it. if some of the parts are damaged go to partselect.com Be sure you have your model # (its on the inside right side just as you open the door.)
Hope this Helps Joe ConnollySealsonetops@gmail.com
Nov 22, 2011 | Frigidaire Dishwashers
I shipped my brother PE 770 embroidery machine purchased sept of 2010, to a lady who perchased it on ebay. Had used only once. Everything worked fine.I shipped in the original formed styrofoam box. I...
This is a link to the manual for this machine. Do you see a picture in the manual of the parts you are describing? Reply with a part number and I will do my best to help.
Here is the manual link
Thank you
Feb 26, 2011 | Vacuums
Piece of plastic fell off brake pedal rear brake light stays on sometimes
the piece of plastic that fell off may be from brake light switch. it is located in back of brake pedal arm, on the top. the switch may just need a little adjustment or replaced. have a good day !!
Dec 17, 2010 | Honda Civic Cars & Trucks
Ther top spray arm fell off the dishwasher
THERE IS PROBABLY A BIG PLASTIC NUT THAT IS STILL SCREWED ON THE UPPER TUB.THIS WILL UNSCREW AND WILL COME AS ONE PIECE IN A KIT.
Mar 01, 2010 | Frigidaire Dishwashers
The top water spinner arm fell off, how to get it
This just happened to me. The spinner arm fell off. It left behind two pieces of plastic attached to the roof of the machine: a grey sunburst shape, and within that, a white circle with two prongs. It looks like the spinner arm should snap onto the white circle with prongs . . . but you can't just press it back on, because there is no resistance on the other side and the white circle just becomes displaced instead of snapping together.
But the good news is that the grey sunburst screws on and off! Unscrew it until it comes free from the roof of your machine. Now snap the white circle and the spinner arm together, with the grey sunburst between them. Give it a test spin to make sure it's all together and working, and then screw the whole assembly back onto the roof of your dishwasher.
Apologies for the lack of pictures . . . this must sound crazy to anyone who's not looking at what I'm looking at--but it worked!
Feb 25, 2010 | Frigidaire PLD2855RFC Dishwasher
It fell off
If you are unable to put it back on while the nut is still attached to the inside of the dryer, reach in and unscrew the upper arm nut. Remove it, reattach the arm to the white plastic piece and reattach the entire assembly by screwing the nut back onto the inside of the dishwasher. Very simple to do and doesn't take much strength at all. In fact, I'm usually the one that has to do it at our house, not my husband, because I can reach in and do it without removing the top rack where as he would have to remove the top rack because his arms are too big.
Oct 07, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Part 1544681 has come off. Cannot reattach.
I have had the same problem twice. After paying for a replacement part and waiting for it to arrive once, i decided to try fixing it myself and came up with a fix that works realy well dispite the manufactures bad design. I used a small "Butterfly" bolt.23345fe.jpg Grind down the wings so they will rest only on the inside rim and allow the part to spin. Cut the bolt to the proper langth. Drill a through the middle of the larg part and use the bolt to hold it all together. Water can still pass around the bolt. Hope this helps.
Aug 29, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Long thin plastic piece fell out of Lexmark Z33
Google your printer, try pcappliancerepair.com. This item goes from one side of your printer to the other, passing through the cartridges holder. Look for the places it attaches. You may have to move the cartridge holder to the center to install the plastic.
May 01, 2009 | Lexmark JetPrinter Color Z33 InkJet
REPLACIND DRIVER SIDE WINDOW REGULATOR
Pull out window crank and door handle, remove panel, remove plastic Nylon that's between metal and panel, crank the window down enough to see the arm and the part that connects with glass. Make sure the metal part inside the door that comes from an arm and attaches to glass is clean, from broken glass and the gap that attaches to window is clean,bend the new glass to make it fit inside the opening slide down the new glass from the top using opening guides, grave it from both sides standing in between and make land on top center of the part that graves the glass, put automotive glass silicone on center of that part,just at where graves the glass, let dry, put the plastic back the door panel the window crank with the "U" shaped lock washer and the door handle, I hope I was clear
Jan 21, 2009 | 2004 Chevrolet Silverado 2500HD
Whirlpool GU2400XTP Built-in Dishwasher Logo
67 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
