Question about Hardware & Accessories
How to set the floodlight to stop coming on every 30 seconds model #0458111,0458112
Cut power for ten minutes
MicrowaveSvc
  • 9085 Answers
SOURCE: Clock will run down to 1 second of the minute and microwave will stop
The surge probably didn't cause this. This common error indicates a problem in the convection damper circuit. It may be a defective damper switch, damper motor, or a jammed damper door. I have attached a drawing of a typical damper system. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Posted on Sep 22, 2007
SOURCE: my 441 model monitor heater kicks on but cuts off in about ten
Mine cut off also. I thought it was the wall plug. But as it turned out, I took the cover off the back, cleaned the filter (kinda like a blow dryer clogs in the back) and it is working fine now..... Hope that helps...
Karen
Posted on Jan 04, 2010
SOURCE: no picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Posted on Mar 23, 2010
milkburp
  • 416 Answers
SOURCE: I lose my picture it
You need a lamp. This is a common symptom. I hope this helps. I have a tutorial on the function and failure of lamps, check it out if you like. It explains why your TV is doing this. I hope this was helpful.
Posted on Apr 13, 2010
bobicehouse
  • 1524 Answers
SOURCE: COMPRESSOR RUNS FOR TEN MINUTES STOPS AND WILL NOT COME BACK ON
Check amperage while unit is running.
Posted on May 08, 2010
Front loader. Why does it run for about 30 seconds, then stops, beeps, and displays code e64?
Good Morning friend, thank you for your post!
I see that your Frigidaire frontload washer runs for 30 seconds, then stops, and produces an error code "E64". It appears that might be an invalid error code. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. If you continue to receive the error code or a new error code please reply back. I would like to assist you further. -Matt
Jun 04, 2015 | Frigidaire Washing Machines
Frigidaire stove model #FGGF3054MF OVEN GOES OFF IN ABOUT TWENTY MINUTES AND 2.30 COMES ON THE DISPLAY
Good Afternoon friend, thank you for your post!
I see that you are having some difficulty with your Frigidaire range displaying a 2:30 and cutting off. This sounds like a wiring issue or a control panel problem within your range. I would recommend performing a reset and you can do that by disconnecting power to your range by flipping the household circuit breaker and leaving it off for roughly ten minutes. If that does not help to resolve the issue I would suggest having a professional technician come out and accurately diagnosis your range. Best of luck! -Matt
Feb 13, 2015 | Frigidaire Kitchen Ranges
My car starts and the securiy light comes on why?
Usually a broken wire in the column. There are several wires there, depending on whether you have passlock II or passlock III. They just break. Luckily yours broke while the car was running, which sets the security into default mode. Otherwise you wouldn't get the car started. If you decide to fix it or have it fixed, you will have to do a relearn for the security. Takes 30 minutes. Put a charger on the battery, Turn the key on (Don't try to start it) for ten minutes off for 30 seconds, on for ten, off for 30, on for ten off for 30, then start the engine. At any time the voltages drops too low or you accidently hit the starter and it trys to start, you will have to start all over.
Aug 08, 2014 | 2005 Chevrolet Monte Carlo
Lenovo R60i wont turn on, indicator lights come on, but go off when power button pressed
It sounds to me like your battery is critically dead and needs recharging very very badly.
Aug 01, 2014 | Lenovo Computers & Internet
I think my timer is not working ,I set time is 30min. hit start and it is running for approximately 30 seconds then machine stops right hand side (all indication flashs
Good morning friend, I appreciate your post!
I understand that your Frigidaire washer will start but after 30 seconds it will cut off and all your indicator lights will flash. It could possibly be a miscommunication with the board I would try to reset your appliance, you can do this by unplugging the power cord or flipping the household circuit breaker for ten minutes. Could you comment back I would like to verify if that helped? I look forward to your response. -Matt
Jul 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
My bosch innowave stops after like 30 seconds...power just cuts off and food doesnt get warm
Hi There,
Unplug your microwave for ten minutes, plug it back in, and test it on a cup of water. If the problem persists, you'll have to take it in for servicing or buy a new microwave. I don't recommend continuing use if it's turning off on it's own, that usually means a bad power supply and can result in curcuit damage.
Jun 06, 2012 | Bosch Microwave Ovens
No picture, status light flashes yellow
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Hardware & Accessories Logo
143 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
