Question about Hitachi Drills
How do I install a bit in my hitachi demotion hammer h90se
Everything
Why cant i get my drill bit in my hammer drill?
the end either pulls out or pushes in to insert and remove drill bit
Dec 16, 2015 | Hitachi DH50MR Jackhammer
How do i fix oil leak in seals of jackhammer
by a service kit that are made for your model
I do you a suggestion how you can do it yourself if you have a burner to heat up the bolts because of loctite sealant i think you know something of forces on that parts ? because of the tools that are neccesary to service it .
Here is a suggestion of a brand that is maybe there or coming in your Country . thats why i do this suggestion by a dutch link .
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=H+90SE&newwindow=true
If you know the brand of your hammer ? sometimes bought secondhand and no modelname google it on 3 words powertools the brand service or choose pictures if you will see pictures where you can see your hammer but there are can be marketing technical differences by the models because a suggestion i made by Hitachi the H90 and H90SE are not compatible by service kit a part of spares can only be used.
The time you spend is meaningless if you only think its leaking oil. because there is a thin lubrication inside most jackhammers and if that's leaking ,the working hours are on it, for time wasted re prematurely burned grommets make high-priority work bolt seal the front of the machine at the stroke chisel the first rings oil seals as well as the size of the stroke bolt must be tight and smooth, as if only a little air leaks burned den all your new o-rings (ie be hard in the short term) by overheating, use lubricants, not just fat because of the high temperature internal structure and the thermal conductivity of the parts together.
Jan 13, 2015 | Hammering
Can't get bit out of hitachi h65
A vise is a must (do a safety goggles) hard steel on hard steel can deliver hot splinters at this job, put it the chisel with the machine fixed cross in a vice place the chisel lock on the machine open and slam a fist hammer slowly machine of the tool down.
Jun 07, 2014 | Hitachi H45MR 12lb. SDS Max Chipping...
What kind of oil can I use in my hitachi H65?
Hitachi hammers use 30wt non detergent oil. But you can use lighter oil in cold climate. If too much oil accumulates in hammer, it may just come out bit retainer or build-up inside gun. Oil enters the hammer by wick process, of wick is missing oil will enter too quickly. If your brand label is glued on, you may have a hitachi copy from china (most hitachi labels are rivited on). China hammers may use different oil.
Jul 29, 2011 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
I have a hitiachi DH38ye drill and it won't accept the Bosch spline bits. they go in ok but the chuck won't lock. The drill accepts the hammer bits fine but won't accept the drill bits
you have me stumped on this one. The tool you have is a spline shank hammer and it should accept all standard spline bits and also hammer iron that is made for these. Is it possible that the Bosch bit has a burr on the splines not allowing it to lock? I have checked the Hitachi site and found no reason it would not work. I will continue checking though.
Apr 23, 2011 | Hitachi Drills
I have a Hitachi demo hammer modle # H 65 When I frist was using it the bit had oil on it. When I got done using it I cleand it all up.When I went to use it again there wasent any oil on the bit after I...
Demo hammers do not oil/grease the bit. The grease in the tool is to lubricate and cool the parts in there doing the hammering. The bit should have grease on the end going into the hammer to make it work in the tool better and make it easier to take out when you are done. You have to put the grease on the bit yourself.
Feb 02, 2011 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Can u tell me is it better to use diamand core bit using hammer action or rotary only
Diamond core bit works great on either setting, you will get faster results on the hammer action though
Jan 02, 2010 | Hitachi Dv18dl 18v Hxp 3.0 Ah Hammer Drill
I own a hd50spk hitachi...what drill bits are universal across the brands?
there are 2 main types of hammer drill bits, standard and SDS.
standard bits go in a regular style chuck hammer drill
SDS bits have 2 grooves and 2 elongated holes on the shaft which snap into the chuck
I'm not sure which type you have, but to answer, the 2 types are universal within their types
Jan 01, 2010 | Drills
Jaws of my Hitachi 18V cordless drill are locked shut
Other than two quick squirts of WD40 and nice new chuck key?
Apr 07, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Drills Logo
57 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
