How do I clean the heat exchangers on my Monitor 441
    New Friend:
  • 39 Answers
Outside or inside? Outside, blow off any dust. Inside, then you need to disassemble the unit. You need to talk to the people here: http://www.homerepairforum.com/forum/monitor-heaters/
There are many experts on Monitors there.
Posted on Dec 19, 2014
How do heat exchangers work?
The heat exchanger is a thin metallic component of a fossil-fueled furnace whose purpose is to transfer heat from the gas or oil buning on one side of the sealed chamber to the air passing across and coming in contact with the other side of the sealed chamber. By 'sealed' I mean the burning gasses do not come in contact with the air that circulates within the living space.
Mar 11, 2015 | Heating & Cooling
I need a operating manual for mpi 441 monitor heater
Here is a link for the M 441 owner\'s manual. http://www.monitorproducts.com/pdf/manuals/m441.pdf
Let me know if you need anything else.
Jan 17, 2011 | Heating & Cooling
My 441 monitor heater will ignite and then it burns for a little while then goes out and starts flashing.
sounds like your heater may be starving for fuel. check all your rubber hoses for cracks first and then continue troubleshooting from there.
Nov 27, 2010 | Reddy Kerosene Heater with Thermostat:...
My 441 model monitor heater kicks on but cuts off in about ten
Mine cut off also. I thought it was the wall plug. But as it turned out, I took the cover off the back, cleaned the filter (kinda like a blow dryer clogs in the back) and it is working fine now..... Hope that helps...
Karen
Jan 04, 2010 | Heating & Cooling
My Monitor 441 will not ignite?
Lane,
When you try to light the heater do you ever hear a thumping noise? If so, you have a fuel delivery problem. If you never heat the thumping noise you have a fuel pump or air safety switch problem. If it's been snowy you could have a covered flue pipe. This will cause the fuel pump not to come on. If your Monitor is your only source of heat I would be looking for a local repair guy that knows the Monitor heater.
Tom Hawkins
hawkins111@gci.net
Mar 03, 2009 | Heating & Cooling
I have a monitor 441 and it will not ignite! I cleaned the strainer, and the igniter is getting warm. But, no flame? help anyone??
Lane,
Do you hear a thumping noise on the lower right side of the unit just before it starts flashing the light bars? If so you have a fuel supply problem. If there is no thumping noise I would check the flue pipe on the outside to be sure it is clear. Lastly I would remove the copper fuel pipe from the burner and try to start the stove. If fuel comes out the pipe the pump is good. If fuel comes out I would stick a paper clip down the fuel nozzle about 3 inches, it could be blocked with carbon. If no fuel comes out the pipe, you will need to get a manual or a tech to help you out. The choices would now be fuel pump or main board, both of which are pricey so you don't want to make a mistake.
That being said, when was the last time you had the burner serviced? Mat, ring and all the gaskets involved? A Monitor 441 needs to be looked at about every 3 years to be sure you get through the heating season.
Good luck,
Tom Hawkins
hawkins111@gci.net
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
Operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Jan 09, 2008 | Heating & Cooling
Heating & Cooling Logo
187 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
