Question about Hitachi Drills
How do I install a bit in my hitachi h90se - Hitachi Drills
How do i fix oil leak in seals of jackhammer
by a service kit that are made for your model
I do you a suggestion how you can do it yourself if you have a burner to heat up the bolts because of loctite sealant i think you know something of forces on that parts ? because of the tools that are neccesary to service it .
Here is a suggestion of a brand that is maybe there or coming in your Country . thats why i do this suggestion by a dutch link .
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=H+90SE&newwindow=true
If you know the brand of your hammer ? sometimes bought secondhand and no modelname google it on 3 words powertools the brand service or choose pictures if you will see pictures where you can see your hammer but there are can be marketing technical differences by the models because a suggestion i made by Hitachi the H90 and H90SE are not compatible by service kit a part of spares can only be used.
The time you spend is meaningless if you only think its leaking oil. because there is a thin lubrication inside most jackhammers and if that's leaking ,the working hours are on it, for time wasted re prematurely burned grommets make high-priority work bolt seal the front of the machine at the stroke chisel the first rings oil seals as well as the size of the stroke bolt must be tight and smooth, as if only a little air leaks burned den all your new o-rings (ie be hard in the short term) by overheating, use lubricants, not just fat because of the high temperature internal structure and the thermal conductivity of the parts together.
Jan 13, 2015 | Hammering
I have a hitiachi DH38ye drill and it won't accept the Bosch spline bits. they go in ok but the chuck won't lock. The drill accepts the hammer bits fine but won't accept the drill bits
you have me stumped on this one. The tool you have is a spline shank hammer and it should accept all standard spline bits and also hammer iron that is made for these. Is it possible that the Bosch bit has a burr on the splines not allowing it to lock? I have checked the Hitachi site and found no reason it would not work. I will continue checking though.
Apr 23, 2011 | Hitachi Drills
I have LatitudeD510 and my disk makes lot of noise. Its on Windows7 and I think the disk is a Hitachi - HTS541040G9AT00
HI,
chances are that you simply do not have the resources to run windows 7. These are the basic (recommended minimum), for windows 7
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor.
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit).
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit).
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • 1 more GB of RAM & 15 GB more HDD space to run 7 in XP Mode.
These are the typical resources that come with your machine.
D510HI
  • Processor Pentium M 1.73 GHz
  • Ram Installed Size 512.0 MB
  • Technology DDR2 SDRAM
  • Hard Drive 40.0 GB
  • OS Provided Microsoft Windows XP Professional
It would probably be advisable to go back to XP
Good luck
Jan 07, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
Hitachi nail gun nr90ad leaks from trigger when air hose is connected
Orings, they have to be replaced every few years. Warranty does not cover them.
Any Hitachi service centre should stock them. Or find your model on Ebay:
http://shop.ebay.com/i.html?_nkw=hitachi+o-ring+kit&LH_IncludeSIF=1&_arm=1&_armi=0&_armm=20&_ruu=http://shop.ebay.com/i.html%3F_nkw%3Dhitachi%2Bo-ring%2Bkit%26_arr%3D1&_rdc=1
Hope this helps!
Thanks
Jan 20, 2010 | Hitachi Air Tools & Compressors
Jaws of my Hitachi 18V cordless drill are locked shut
Other than two quick squirts of WD40 and nice new chuck key?
Apr 07, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Keyless Chick will not Release - Hitachi DS18DMR
It's best not to use the drill power and your hand to try and release. Or tighten for that matter.
Set the drill down, and try using both hands on the clutch.
If that don't work, try using vise-grips or channel locks.
If that don't work, whip out of the WD-40 and let soak and then try again.
Jan 26, 2009 | Hitachi DS18DMR 18V 1/2" Driver Drill
Coloring Red
We call this the "red cloud" and nothing you do to the set will correct the problem. You have a defective light engine. We recently went through this so here's what you need to do. Call Hitachi's1.gif customer relations department at 800-654-7013 and tell them that you have a defective light engine. They will act like they've not heard of this but they have. They will give you the names of some certified dealers in your area. Once the tech comes to your home and confirms that it's a bad light engine, call Hitachi back and they will send a new light engine to the dealer. The dealer will call you to set up a day/time to come out and intstall.
Here's the deal, Hitachi will cover this expensive part (cost $1500) but it you're not under warranty, you will have to pay for the install. Our install was $400 but others on this site have paid around $200. Please do not let anyone tell you that you have to pay for this part. Deal directly with Hitachi. They have not recalled this part but they are replacing it for free..brand new and not refurbished. All you pay is the install. Also, deal only with customer relations and not customer service. The 800 # I listed is directly to Hitachi customer relations department. Good Luck!
Feb 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Problem on installation
Where you need to see your hitachi first is from within your bios. Windows will not see your drive if the bios does not. Recheck your connections. Clean the connections if needed with a clean cotton stick & a fine bit of alcohol by sliding left to right across the copper contacts.
Jan 11, 2008 | ASUS P5P800-VM Motherboard
Drills Logo
57 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
