Question about Playskool Toys
How do I reassemble a Playskool 06205 - Playskool Toys
How can I get an instruction manual for Playskool Kota dinosaur
Hasbro has the instructions and replacement parts for many of the Playskool toys on their support site, http://www.hasbro.com/site-map.cfm . The instructions for the Kota the Triceratops are available here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/61EED7975056900B10DED12F214D6B3E.pdf . The instructions for the Kota and Pals Ankylosaurus are here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/F235292B5056900B10B29E652C4640C1.pdf . However, they do not have any parts for the Kota and Pals set. You may find the leaf available in an internet auction.
I hope this helps.
May 01, 2014 | Hasbro Playskool Kota and Pals Monty T-rex...
How to hook up my playskool dance cam
The Playskool Dance Cam requires 4 AA batteries and has RCA video connector (yellow) and RCA stereo connectors (red and white)
Plug these into the RCA connectors on the TV of the same color
You will likely need to change the AV (audio video) input on the TV to RCA
The extra 1/8" audio cable is so you can play your own audio by connecting to cd player, ipod, radio, etc. this is optional does not need to be connected.
That's all that is needed you should see it on the TV screen.
Oct 06, 2012 | Playskool Dance Cam
Playskool rocktivitywalk n' roll rider assembly. Hubcaps snapped on before front fork panel, how can I get hubcaps off to install properly? Help!
You are going to have to pry them up with a screwdriver or other thin strong tool and see if you can see the tabs that lock it in place. Then take another screwdriver and push the tabs back to release them.
Good luck. If all else fails, scrap the hubcaps, you can use some Oops glue to put them back on if the tabs are broke.
Sep 30, 2012 | Playskool Toys
1988 Playskool Expres Train engine won't run. Light comes on but wheels won't turn. How can I repair it?
i recently restored a playskool express train that my son had, now for my grandson.
The on-off push switch is the yellow button in the smookestack also controlled by the yellow tab on the bottom (the on-off track can stop the train with the tab). If the light is on then perhaps the forward reverse switch (the yellow bar behind the cab needs to be pushed forward or backwards. In the middle might be off. I had to replace the motor, its a common sized DC motor 6V at 15000 RPM w/ 2mm shaft, for toys..
The bigger problem I had was that the battery cover was very finicky in how tight you closed it, and the rubber traction bands for the driving wheels were rotten. I replaced them with 1-5/16" ID x 1/8" O-rings. Still slips a little.
Dec 10, 2011 | Playskool Toys
Bought a Playskool Dance Cam at a yard sale and have no directions on how to use it
That's all that is needed you should see it on the TV screen. Further basic instructions will show on screen.
Sep 10, 2011 | Playskool Dance Cam
Where can I get replacement balls for theplayskool busy ball popp
Go to the hasbro playskool website, select the customer service tab, in the alpha list select b, scroll until you come to busy ball popper. once you click on it it will give you an option of an order form for Canada.
Feb 04, 2010 | Playskool Busy Ball Popper
Controller not working : helmet functions perfectly
1.) make sure the helmet is switched to "ON" not "Demo"
2.) if the toy stops working, try pressing the yellow button directly above the playskool logo on the helmet.
The toy uses a simple IR light to communicate between the controller and the helmet, and any controller will work with any helmet. Make sure the light and the receiver in the helmet (front, middle under the lip in line with the playskool logo) have an unobstructed view of one another.
Hope this helps.
Mar 25, 2009 | Hasbro Playskool Helmet Heroes Motorbike...
LOST ASSEMBLY DIRECTIONS FOR PLAYSKOOL ROSE PETAL COTTAGE
Instructions can be found @
http://www.hasbro.com/common/instruct/68601.pdf
You may be asked to download Adobe which is globally recognized as a leader in file readers. Feel safe downloading!
If any other problems...get back to me!
Feb 06, 2009 | Playskool Toys
Toys Logo
105 people viewed this question
Top Playskool Toys Experts
pawnpower
ray gallant
Tom Chichester
Are you a Playskool Toy Expert? Answer questions, earn points and help others
