Question about Kia 2007 Rondo LX
How to Pull out a 2.4l engine - Kia 2007 Rondo LX
  • 64 Answers
You should go to auto parts store and pick up a manual it's more than i can explain
Posted on Dec 14, 2014
Need a diagram or a video of how to do a power steering pressure line on a 2000 pontiac grand am 4 cyl 2,4l
Hi James:
The hose (or line) will be threaded on at each end. Just unscrew the couplings and install the replacement. Then top up the fluid.
Jan 13, 2016 | Pontiac Cars & Trucks
How to remove the transfer case in a 1999 dodge grand caravan
need to drop the cradle down leaving the engine and transmission suspended in the vehicle pull both half shafts disconnect shifter and wiring pull the exhaust pipe from front manifold to rear and and drop starter pull shield between engine and transmission and pull the three or four torque convertor bolts pull 18mm bell housing bolts and and trans mount tilt engine and trans to drivers side (support engine) and separate
Oct 30, 2015 | 1999 Dodge Grand Caravan
What are the settings to pull start it
Pull starting a machine of any kind is fairly simple.
make sure your ignition is in the on position and that all safety switches are set (brake, oil level, blades, neutral etc.)
-give the engine extra fuel by the throttle position just past full throttle called "choke" -pull the engine through slowly until you feel resistance -let the rope back into the engine -pull quickly on the rope (if the engine does not start on the first pull repeat the previous two steps ) Once the engine starts back the throttle down out of "choke mode"
Feb 10, 2011 | Garden
Dodge ram50 1992 swap 2,4L to 2,6L
Greetings!
Yes, the engine mounts and bell housings are the same.
The swap should be straight forward, however be sure to swap all the vaccum controls and emission system from the 2.6L.
Have fun!
Cheers, Jay
Apr 29, 2009 | 1992 Dodge Power Ram 50
1997 nissan frontier fuel filter location
If you engine is a 2.4 liter it's on the passenger side center of the engine compartment, the hoses from the fuel filter conncts to the throttle assembly . You may have to remove the air filter housing to see it. It is a round canister hoses held on with fuel line clamps. hope this helps
Apr 06, 2009 | 1998 Nissan Frontier
Dodge Caravan 2,4l 1997 timing belt change
you will need to change the belt tencioner aswell
if you havent don a cambelt before dont see youre local mechanic ok m8
Jan 03, 2009 | 1997 Dodge Grand Caravan
99 cavalier engine
I just changed a 2.4 in my 96. I pulled the whole thing because I coudn't get at the converter to flywheel bolts. After reading further, I saw information to pull the trans out through the drivers wheel well without the engine. They removed the starter to access the flywheel bolts to the converter.
I haven't tried it but it would make sense and it does make it a lot easier. Without the trans attached, you wouldn't need to remove the master cylinder or beat the sh-t out of the battery tray to get the think out.
Oct 24, 2008 | 1999 Chevrolet Cavalier
Kia 2007 Rondo LX Logo
Top Kia Heating & Cooling Experts
terry stevens
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Kia Heating and Cooling Expert? Answer questions, earn points and help others
