Question about Dryers
What are the white, blue and black wires for on
What are the white, blue and black wires for on the Tview T1508IR-BK swivel?
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 26 Answers
Power ground video hopefully that helps out. You need a compatible radio also that support video
Posted on Dec 18, 2014
SOURCE: wiring
Blue & black to black, white to white, & green to ground on light.
Posted on Jul 03, 2008
Tech Jenkins
  • 359 Answers
SOURCE: where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Posted on Nov 15, 2008
  • 52 Answers
SOURCE: Sidewinder Fan Works but not the Light
As you were assembling the wire from the fan motor to the house wiring, there should have been two wires labled. One would have been labeled "FAN" and the other "LIGHT". To properly attach the wires, (be sure the power is off) twist the thin labeled black (FAN) and blue (LIGHT) wires together. Now attach those two twisted wires to the black house wiring with one of the supplied wiring cap. Finally attach the thin white wire to the white house wire with supplied wiring cap. Your fan is now ready for operation. If you had performed all these steps when you first assembled the fan, then the thin black wire going to the fan has come loose. Should your ceiling fan still not run after all that, then it's time to return it where you bought it because either the pull chain switch is defective or the manufacturer produced a defective piece of merchandise. If you found any of my suggestions to be helpfull, please rate my solution. Thanks D. Lange
Posted on Apr 24, 2009
csmock132
  • 4669 Answers
SOURCE: Hampton Bay Wiring?
You have two switches right? One for the light and one for the fan? White should be neutral. Green should be ground. Black should be hot from one switch and red should be hot from the other. Hook black to black and blue to red. If you wire blue and black together then one switch will turn on the fan and the light at the same time.
Posted on Jun 05, 2009
  • 34 Answers
SOURCE: lost the instructions. Where does the blue wire go
DO NOT CONNECT THE BLUE WIRE UNLESS YOU HAVE A LIGHT ON THE FAN. CONNECT IT TO THE NUTRAL WIRE OTHERWISE. IE WHITE.....
Posted on Jan 24, 2010
Wiring diagram for hunter remote part 98480-02
I don't know what remote you have but try this;
Bk to Bk
Wh to Wh
Black w/wh stripe to red
Black to house black
White to house white.
fanman9952@aol.com
Sep 08, 2014 | Hunter Dryers
Wiring hunter fan model 27185 060
ceiling to receiver: BK to Bk
Wh to Wh
Fan to receiver: Bk to Bk
Blue to blue ( could be black w/ white stripe)
Wh to Wh
Green to ground
Sep 02, 2014 | Dryers
Four wires from ceiling. red, black, white and ground-hampton bay w/remote has three wires. green,white, black. how to proceed?
Bk -BK
WH - WH
Gr - Gr
The red wire should be capped off. If this doesn't work, switch the red & black wires.
Aug 31, 2014 | Dryers
How wiring a new ceiling fan in a 1995 mobile home that is controled by a wall switch and controls 2 fans
Should be Bk &Blue(wirenut togerher) - bk, white - Wh, Green - green
Aug 28, 2014 | Dryers
What causes a Tview T244IR-BK not to power on when all fuses are good and where to buy replacement parts
That worries me when the fuses dont`t blow,otherwise I would have told you you made the wrong connections or did not ground enough. You can find fuses in any hardware stores and if your purchase is recent, have it replaced or get your money back. I suspect something wrong with the item. Or go to place where they are specialized in installing DVD monitors in cars; they`d tell you if it`s blown up or not. My TView monitor is really blown up and I am trying to find out if it can be fixed. My warranty has expired and I am kind of stucked.
Sylvain, Blainville, Canada
Aug 08, 2014 | Tview T244ir 24" Black TFT Wide Screen Car...
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Wiring motion sensor light
Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
Nov 06, 2008 | Electronics - Others
Wiring
hi im new to this forum but i did a little research and this is what It should be (according to Chrysler)
Left Rear
BR/LB -
BR/YL +
Right Rear
DB/BK -
DB/WT +
BR=Brown
LB=Light Blue
YL=Yellow
DB=Dark Blue
BK=Black
WT=White
May 24, 2008 | Car Audio & Video
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
