Question about Cooktops
Brandt HNH 25 BIE hob locked, how do I unlock it?
Happened while using it - timer lights came on and beeped - so I turned all power off.
My edesa hob keeps beeping and won't unlock?
did you try turning the power off for 5 minites to reset the computer.?
Jul 01, 2017 | Cooktops
BAUMATIC GECE6005Induction cooktop will not unlock so how do I get it off lock
Baumatic GECE6005 manual page 18
To disable the safety lock feature, you should press the safety lock button for a couple of seconds. The "L0" symbol will disappear from the timer display and you are then able to use the hob in normal operation.
Sep 08, 2016 | Baumatic Cooktops
Child lock turn off
For the Candy CH642B cooktop:
LOCKING BUTTON OPERATION
The locking function prevents the children from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on.
To lock the hob :
- Press the on/off button
- Press simultaneously " - " button and " + " button of the front right zone (CH 633 front left zone), and then press again on the " + " button of this zone.
When the hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds.
To unlock the hob :
- Press the on/off button. The locking indicator " L " is displayed on all zones.
- Press simultaneously the " - " button and the " + " button of the front right zone (CH 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Dec 05, 2015 | Cooktops
I have just moved into a new apartment in France, and we have a 2 ring touch screen hob. There are no instructions or booklets but it says "Schott ceran brandt" on it. It works, as I've worked out how to...
i presume that you have a induction cook top. if so not all pots and pans will work on them. i have never had one but i do know this could be your type of problem. do some research on what pans to use on a induction stove.
Jul 02, 2017 | Cooktops
How to un lock
My hob unlocks with that I turn on the hob and the the L appears, then I hold down the lock button until it disappears then I push the STOP/GO button.
Jan 22, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob.
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Indicators
the 'L' means locked - to unlock turn on hob, hold down front right hand side plate control and minus botton to unlock - see manuals for further details
Sep 22, 2008 | Baumatic 23 in. B10 Electric Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Cooktops Logo
94 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
