Question about Thule 2000 Hyundai Elantra - Wagon, with factory roof rails - Base Rack System
Rear brake lights will not switch off - Thule 2000 Hyundai Elantra - Wagon, with factory roof rails - Base Rack System
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 66 Answers
Either the brake switch is sticking in the on position or the light is being fed power from a different circuit. To test the switch, find the connections on the brake pedal bracket under the dash and disconnect the wires. The brake lights should extinguish if the switch is stuck in the on position. To check for feeds from other circuits remove the fuses one by one until you identify the culprit. Start with the fuse for the brake lights first. I am guessing tjat with the ingnition turned off that the lights go out?
Posted on Dec 14, 2014
2005 Suzuki Boulevard C90 the rear brake light stays on
Hi, Michael before diagnosing any brake light issue always check the bulb and fuse first for integrity a brake light staying on is usually caused by the front brake light switch, which is mechanical, not disengaging. On early models moving the throttle control housing closer to the front brake master cylinder is the main fix. On late models, the switch gets tweaked and needs to be realigned. A brake light that does not come on when the brake lever is applied can be caused by a faulty switch or no continuity in the wiring at the switch. The rear brake light switch is hydraulic and it is extremely rare to malfunction in a closed circuit condition causing the brake light to stay on. Usually, rear brake light switch issues are caused by no brake pedal free play or a sticky rear master cylinder piston. A brake light that does not come on when the rear brake pedal is depressed can be caused by a faulty switch, air contamination in the brake line, or no continuity in the wiring at the switch.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Brake light will not turn off
Replace Motorcycle Rear Brake Light Switch
Suzuki VL1500 Service Manual
OEM parts for Suzuki
Suzuki Intruder VL1500B Owner Manual
Sep 11, 2017 | 2005 Suzuki Boulevard C90
Third eye works no rear signal or brake lights
The high mount brake light gets its own signal from the brake light switch (on the brake pedal). Or at least the wire leaving the brake light switch will splice, one wire to the high mount brake light, and the other for the rear brake lights is routed through the turn signal switch, and coordinated there with the turn signal wires to the rear brake lights. The brake wires and turn signal wires share the same wire, and same filament in the bulbs. It is kind of complicated, but brakes applied with no turn signal, brake light wire goes from brake light switch through the turn switch and out to the bulbs. If brakes applied with turning signal, non blinking brake light wire goes from turn switch to rear light, while the turning signal wire will go through the flasher relay, and then to the rear light to cause blinking.
I hope that makes sense. It appears the problem may be in the turn signal switch for both the turn signals and the rear brake lights.
Mar 14, 2015 | 2007 Dodge Ram 3500 Quad Cab Laramie
Brake light
Hi, Anonymous before diagnosing any brake light issue always check the bulb and fuse first for integrity a brake light staying on is usually caused by the front brake light switch, which is mechanical, not disengaging. On early models moving the throttle control housing closer to the front brake master cylinder is the main fix. On late models, the switch gets tweaked and needs to be realigned. A brake light that does not come on when the brake lever is applied can be caused by a faulty switch or no continuity in the wiring at the switch. The rear brake light switch is hydraulic and it is extremely rare to malfunction in a closed circuit condition causing the brake light to stay on. Usually, rear brake light switch issues are caused by no brake pedal free play or a sticky rear master cylinder piston. A brake light that does not come on when the rear brake pedal is depressed can be caused by a faulty switch, air contamination in the brake line, or no continuity in the wiring at the switch. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://forums.cycleworld.com/showthread.php?t=247836
http://www.starbikeforums.com/forums/48-road-star/3983-brake-light-fuse.html
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Sep 08, 2012 | 1998 Yamaha V Star Classic
Tail light and foot pedal brake light does not work but hand lever brake light works.
Probably a bulb/ rear brake switch combination. If your front brake switch is working, then half of the bulb is working. No taillight issue, probably a bulb. No rear brake light, probably the rear brake switch. Located on the lower right rear of the frame, behind the exhaust. Check for power on the orange/white wire at switch. If you have that then check for power on the other terminal of the switch while pushing on the pedal. The rear brake switch is hydraulically operated so you must have adequate pressure to activate it.
May 04, 2012 | Harley Davidson Harley-Davidson Motorcycle...
Rear brake light will not work when brake pedal is applied, both front and rear brakes run through same sensor front brake applies rear light, but rear brake pedal doesnt. where is the problem?
It sounds like the rear brake pressure switch is bad. The wires for the front brake light switch are wired in parallel to the this switch. Replace the pressure switch in the metal brake line coming from the rear brake master cylinder going to the rear brake caliper.
Good Luck
Steve
Aug 21, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Rear brake light does not work tail light does need to know were brake light switch is?
Your bike is equipped with two brake light switch, either of which should cause the brake light to come on when activated. The front brake light switch is in the right handlebar switch housing and it has an activation pin that sticks out of the switch housing towards the front brake lever. A tab on the front brake lever operates the switch. When the tab on the lever moves away from the switch housing, the pin comes out of the switch housing and turns on the brake light. The rear brake light switch is a pressure switch located in the metal brake line that comes out of the rear brake master cylinder and goes towards the rear brake. Just follow the metal from the rear master cylinder towards the rear brake and you'll find it.
Good Luck
Steve
Jun 15, 2011 | Harley Davidson FLHT Electra Glide...
I have a 2000 roadking. the brake light is not working but the tail light works. changed bulb there is power going to the brake light switch an u can hear the relay clicking when you hit the brakes. but if...
To begin with, there is no relay for the brake light. That thing you hear clicking is a circuit breaker. You probably have a short circuit between the rear brake light switch underneath the bike and the brake light itself. If the tail lights work, then you know what circuit is ok.
Look at your rear brake master cylinder. Find the metal line coming out of it going to the rear of the bike. In that line, under the bike, you'll find a pressure switch. This is the rear brake light switch. The front brake light switch is located in the right side handlebar switch housing. If neither switch works the brake light, odds are you have a short circuit in the wiring from the rear brake light switch to the rear brake light itself.
Good Luck
Steve
Feb 25, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
I have a 2007 Heritage Softtail. Brake light does not work. I checked the fuses and replaced the taillight. Still does not work.What next?
You have two brake light switches on your bike, a front brake light switch in the right handlebar switch housing and a rear brake light switch under the bike. To check for operation of either or both of the switches, remove the brake light lense and bulb. Turn the ignition switch on and have someone hold the front brake and depress the rear brake pedal at the same time while you check the contacts in the socket for power to each contact. One contact will be the brake light contact, the other is the tail light contact. If you have power to both, you bulb or the tail light ground is bad.
If you only have power to one contact, have the person helping you release both brakes. The contact for the tail light should remain hot as long as the ignition switch is on.
To find the rear brake light switch, find the metal brake line coming out of the rear brake master cylinder and going towards the rear of the bike. Follow this line until you come to a tee fitting with the rear brake light pressure switch screwed into it. Simply screw the switch out and replace it with a new one.
The front switch is more difficult as you have to disassemble the right handlebar switch housing, remove the throttle sleeve and open the housing up. Remove the screw holding the old switch and desolder the wires from the switch. Install the new switch and resolder the wires. Reassemble the throttle assembly and the switch housing taking care not to pinch any wires and making sure the throttle works smoothly.
Good Luck
steve
Jan 21, 2011 | 2004 Harley Davidson FLSTC - FLSTCI...
Rear brake light not working
The brake light is turned on and off by either of two switches on your bike. The front brake lever has a switch located in the right handlebar switch housing. When you squeeze the lever, a pad on the lever moves forward allowing the switch button to move forward making contact which in turn switches the brake light on.
The rear brake lever operates a plunger inside the rear brake master cylinder that pressurizes the rear brake and rear brake hose and line. The rear brake line has a tee fitting in it along it's run with a pressure switch in the tee. Once the pressure on the line gets high enough, the switch turns on the brake light.
If your rear brake light switch is not working, check to make sure the wires are on the prongs of the switch. If they are, replace the switch. It simply screws out and a new one screws in. Most of the time you don't have to bleed the brakes as long as you don't move the rear brake pedal with the switch out. Check the rear brake for proper operation prior to riding the bike.
Good Luck
Steve
Jun 17, 2010 | 2008 Harley Davidson FLHRC Road King...
Rear brake light not workiing
There are two brake light switches. One is in the right handlebar switch housing. This is front brake light switch and is a simple push button type switch actuated by the front brake lever.
The other switch is a pressure switch and it is located in a Tee usually somewhere under the bike near the rear of the transmission. Follow the metal tube coming out of the rear of the master cylinder. It will go back towards the rear brake. Somewhere in that line there will be a tee with the pressure switch in it. If you jumper across this switch, the brake light should work. If it does work when you do this but not work when you depress the rear brake signal, replace the rear brake light switch.
Good luck
Steve
May 26, 2010 | 2000 Harley Davidson FLHRCI Road King...
Thule 2000 Hyundai Elantra - Wagon, with factory roof rails - Base Rack System Logo
64 people viewed this question
Top Thule Cycling Experts
Audrey Messer
Audrey Messer
Andrew Crawshaw
Level 1 Expert
dante
Are you a Thule Cycling Expert? Answer questions, earn points and help others
