Question about Halonet 98-03 DODGE DURANGO / 00-04 DODGE DAKOTA QUAD CAB POWER FRONT WINDOW REGULATOR
Replaced front brakes and now the pedal goes to the floor have bled the system and all that comes out is clean fluid brake pedal feels soft
Bleeding the entire system
    Habit-Forming:
    New Friend:
  • 24 Answers
I suspect master cylinder seal broke coincidentally.
(maybe not common but maybe not un-common either because of age of truck)
Do you want to save $50-$80 but invest labor, disconnect brake outlet pipe from M/Cylinder then plug with same thread bolt then push pedal, see if it's solid or soft.
if it's still soft, maybe leak from pipe, rubber hose or connector.
If you think it's time to change M/cylinder anyway, buy and replace M/cylinder (maybe $60) then see if it's still soft.
Don't forget to bleed air from M/cylinder when you change.
Posted on Dec 02, 2015
Brake pedal soft after changing pads and bleeding brakes
You will need to bleed the brake system. I would start with the rear brakes lines and work towards the front.You must have key off engine off when bleeding brakes, apply pressure on brake pedal 10 times and hold. The brake line is now ready to be open. Open and let the stream of fluid come out and close the line tight. Then release brake pedal once bleeder screw is close. This procedure must be repeated twice front and back. After, brakes have been bleed pump the brake pedal before putting in drive.
Note: Don't let the resevoir run low on brake fluid. This will cause air bubbles to accumulate on the brake system. Always top off before opening bleeder screw.
Nov 21, 2011 | 1992 Chevrolet Corsica
My 1997 chevy 1500 z71 brakes suddenly going all the way to the floor. Checked brake fluid and it was low. Could be wheel cylinder? Master cylinder? or ?
well, check the brake lines for leakage after adding brake fluid to the full mark. If the brake pedal goes all the way to the floor, it's likely there is a leak somewhere after the master cylinder. If the pedal gets hard after adding fluid, and pumping it several times with the car off, then the master cylinder is still ok.
If air has gotten into the master cylinder, it may have to be bled out on a bench, or using a scanner if that's the way your vehicle is.
Bleeding the Brake System (ABS) Auto Bleed Procedure NOTE: Perform a manual bleeding procedure. If the brake pedal height and firmness results are not achieved, perform the auto bleed procedure below.
NOTE: Perform this procedure when replacing the brake pressure modulator valve or electro-hydraulic control unit.
  1. Perform the manual brake bleeding procedure. Refer to Bleeding the Brake System (non-ABS).
  2. Check the master cylinder fluid level often to prevent running the system dry.
  3. Press the brake pedal firmly and run the Scan Tool Automated Bleed Procedure (for Gas engines) once, or the Function Test (for Diesel engines) four times. Make sure to release the brake pedal between each test.
  4. Perform the manual bleed procedure again. This should remove the remaining air from the brake system.
  5. Bleed the system as many times as needed to obtain the appropriate feel of the brake pedal.
Dec 18, 2010 | 1997 Chevrolet K1500
Replaced brake line, rotors and pads bled brakes all around and the brakes when the truck is off work but once i start the truck the brake pedal goes to the floor and have no brakes at...
Bench Bleed the M/C first, then do not let it run dry during system bleeding. Parts stores sell a kit that helps installed m/c bleeding.
Sep 29, 2010 | 2001 GMC Jimmy
I have no barkes i put all new lines on and no i bleed them starting whit right rear and still no
When you stand on the brakes does the pedal feel soft or hard? If soft the chances are you still have air in the system. Tighten (not too much just enough to prevent the escape of brake fluid) all the bleed nipples. Now make sure there is fluid to the maximum in the master brake reservoir. Stand on the brakes to extend all the slave pistons as far as they can go with the current situation. Starting with the the right back (as you correctly did originally) put your finger tip over the end of the nipple and undo it with an open ended spanner by only a quarter of a turn. Have a friend step on the brake pedal. When he has got to the bottom of travel push your finger hard on the nipple tip and tighten the nipple gently with e the spanner. Your friend can now release the brake pedal slowly. Again ask your friend to press on the pedal and then you undo the nipple a quarter of a turn to bleed of the fluid (and bubbles). When your friend reports that the pedal is on the floor, again tighten the bled nipple. Again your friend can only now release the brake pedal slowly. There will come a point when your friend will notice some resistance to the pedal before you slacken the bleed nipple to bleed the fluid. Keep bleeding this brake until a quarter of a pint of fluid has been pushed through and now tighten the bleed nipple firmly. Add fresh brake fluid to the brake reservoir under the hood. Now repeat this process with the back left wheel, then front right and then front left. The important thing is 1) ensure that the brake pedal is never lifted until the bleed nipple is tight otherwise air is sucked in through the nipple; having your finger tip on the end can help avoid this and 2) to ensure that the reservoir is always full of brake fluid so that only fluid can enter the system and not air 3) that you bleed plenty of fluid through the system, when you replace brake lines it is surprising just how many little pockets of air can hide in it. Good luck
May 12, 2010 | 2000 Chevrolet Blazer
Brake pedal on my 98 chevy s10 is soft
1988 chevy r 3500 1 ton changed out driver front brake caliper
brakes are soft peddle goes to the floor tried to bleed but no brake fluid will come please help
Apr 14, 2010 | 1988 Chevrolet C1500
While driving my 1994 Honda Accord the brakes went out. I can only get the car to stop if I press the brake pedal all the way down to the floor. When the car is shut off and I pump the brake pedal, I can...
There may be air in the lines. Bleed all your brakes starting at the farthest wheel from the resevoir, and finishing at the closest one. Try the pedal after its bled. If the pedal still feels soft or travels to the floor there may be a pinhole leak that may be spraying on the underbody of the car, or the seals in the master cylinder are gone filling the vacuum booster(if equipped). Air compresses more than oil so if bleeding works that may be the problem.
Feb 21, 2010 | 1994 Honda Accord
Install new brake pads and rotors all 4 wheels. Replaced front 2 calipers. Bled brakes. New clean fluid coming out. pedal is still soft and goes to floor. 200 Seebring.
Are you losing any Brake Fluid? Is it visible anywhere at the four wheels? Is it visible anywhere else?
The Master Cylinder may be defective. When you bled the Brakes did you maintain proper Brake Fluid Level in the Master Cylinder? If you didn't: and air entered into the Master Cylinder there maybe air within in the system in the Master Cylinder. You can bleed the Master Cylinder by removing the brake lines, adding more fluid, pumping the brakes, bleeding the air out of the system.
Are you losing Brake Fluid and can't find a noticeable leak? Then there is a good posibility that the rear seal in the Master Cylinder is leaking and the Fluid is going into the Brake Booster - which is the large wheel shaped drum located on the fire wall. In this case both the Brake Booster and the Master Cylinder will have to be removed and replaced. The Booster contains seals that Brake Fluid is very caustic to and will ruin these seals- causing future failures.
If no Brake Fluid is lost, no leak found: Check the Brake Booster Vacuum Advance. This should be connected to the outside of the Booster, attached to a hose, with the hose going to the engine. Check to see if this is working properly. Replace if needed.
Dec 31, 2009 | 2002 Chrysler Sebring
Replace brakes. now they go to the floor. bled air
When you fixed the brakes, did you take the lid off the master cylinder. I just wonder if you spilled out your brake fluid. The only reason the pedal should go to the floor is if the brake fluid is gone or the master cylinder is not working. Check the fuse. Check the brake fluid level. The pedal only goes to the floor if there is no back pressure in the lines between the master cylinder the lines to the brake pistion on the calipers. Please give me a good ratin and keep me informed.
Jul 07, 2009 | 1999 Cadillac DeVille
Halonet 98-03 DODGE DURANGO / 00-04 DODGE DAKOTA QUAD CAB POWER FRONT WINDOW REGULATOR Logo
802 people viewed this question
Top Halonet Scuba Diving & Snorkeling Experts
Tom Chichester
Bill Boyd
micky dee
Are you a Halonet Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
