Question about 1998 Chevy C1500 Truck Inside Door Handle for Classic Body Type Blu
How can I find a dorman quick disconnect fuel line that will fit my fuel pump
I can't find a line that will fit my middle line of fuel pump
    Champion:
    New Friend:
  • 215 Answers
Go to dealer and ask them , take a photo and go to some place like CARQUEST to buy it. A lot cheaper!!
Posted on Jan 13, 2015
How to purge fuel line 2013 xlc1200
It will purge itself while the fuel system is being activated.
If what you are asking is not to purge air from the line after it has been emptied of fuel and instead you want to drain the tank you could get a male quick disconnect fitting and insert it into the quick connect in place of the fuel injector fuel rail line with a piece of tubing as needed etc and then activate the fuel pump in isloation from the bike electrical system but it would be easier to get a vacuum fluid transfer pump or other type of appropriate pump and draw the fuel out through the filler openoing.
May 22, 2014 | Harley Davidson XL 1200 C Sportster Custom...
Removing fuel supply line
You must be talking about the fuel rail to the injectors. You would release fuel pressure from the line by disconnecting the pump fuse then running the engine until it quits and then turning engine over for a few seconds and then disconnect the quick connect fitting. Then disconnect the battery negative and replace the fuel pump fuse and then Then remove the horn and access the injectors and undo the fuel rail retaining fastener and release the fuel rial from the injectors.
For a carburetted model shut off the fuel shutoff valve and then disconnect the fuel line from the shutoff valve and then disconnect it from the carburetor.
May 20, 2014 | 2005 Harley Davidson FXDLI Dyna Glide Low...
Replacing fuel disconect2004 dyna low rider
Hi Anonymous, attatch fuel supply line to the quick disconnect fitting, insert supply line into tank, screw in fitting to tank, torque fitting to 220 to 225 inch lbs. or 18 ft lbs. attach remaining end of fuel supply line to fuel pump pressure regulator. Good luck
Dec 25, 2013 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
How do I remove fuel pump off 01 olds silhouette. Dropped the tank down already
2001 Oldsmobile Truck Silhouette 3.4L SFI 6cyl
Fuel Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Properly relieve the fuel system pressure.
  3. Drain and remove the fuel tank from the vehicle
  4. Remove or disconnect the following:
    Negative battery cable Quick-connect fittings at the fuel pump Fuel pump locking nut with a Fuel Pump Spanner Wrench J 39348 Fuel pump assembly from the fuel tank and discard the O-ring
To install:
  1. Install or connect the following:
    New O-ring on the fuel tank Fuel pump into the fuel tank making certain not to fold or twist the strainer and that it does not interfere with the full travel of the float arm Fuel pump locking nut with the scanner tool Quick-connect fittings at the fuel pump Fuel tank and fill the tank Negative battery cable
  2. Prime the fuel system as follows:
    1. Turn the ignition switch ON for two seconds.
    2. Turn the ignition switch OFF for 10 seconds.
    3. Turn the ignition switch ON and checks for leaks. Repair if necessary.
Fuel Pump/SenderRemoval & Installation
  3. Disconnect the negative battery cable.
  4. Drain the fuel tank into an approved container.
    WARNING Do not attempt to straighten any kinked nylon fuel lines. Replace any kinked nylon fuel feed or return pipes in order to prevent damage to the vehicle.
    WARNING Do not attempt to repair sections of nylon fuel pipes. If the nylon fuel pipes are damaged, replace the pipes.
  5. Raise the vehicle.
    Fig. Showing the fuel tank assembly and related components
  6. Disconnect the fuel supply pipe (5) quick-connect fitting.
  7. Disconnect the evaporative emission (EVAP) purge pipe (6) quick connect fitting at the EVAP canister.
  8. Loosen the fuel tank filler pipe hose clamp.
  9. Disconnect the fuel tank filler from the fuel tank.
  10. Disconnect the vapor recirculation pipe from the filler tube.
  11. Remove the fuel tank shield.
  12. With the aid of an assistant, support the fuel tank.
  13. Remove the fuel tank strap attaching bolts.
  14. Disconnect the fuel sender and the fuel tank pressure (FTP) sensor electrical connectors at the body pass through.
  15. Remove the fuel tank from the vehicle.
  16. Remove the fuel sender assembly (3).
    Fig. Identifying the fuel sender assembly
  17. Disconnect the fuel sender electrical connections (3).
  18. Clean all of the fuel pipe connections, all of the hose connections, and all of the areas surrounding the connections before disconnecting the connections in order to avoid possible contamination of the fuel system.
  19. Disconnect the fuel supply pipe quick-connect fitting (4) at the fuel sender assembly.
  20. Disconnect the evaporative emission (EVAP) pipe quick-connect fittings (5, 6) at the fuel sender assembly.
    CAUTION Do NOT use impact tools. Significant force will be required to release the lock ring. The use of a hammer and screwdriver is not recommended. Secure the fuel tank in order to prevent fuel tank rotation.
continue...
Jun 23, 2010 | 2002 Oldsmobile Silhouette
How do you change a fuel filter on a 97 dodge stratus
Fig. 7 Fuel Lines At Fuel Pump Module 42402626 NOTE: The fuel filter mounts to the frame above the rear of the fuel tank. The inlet and outlet tubes are permanently attached to the filter.
REMOVAL
  1. Release fuel system pressure.
  2. From inside trunk, disconnect fuel pump module wiring jumper from main body harness.
    • The 4 pin connector is located under the trunk mat on the left side of trunk near the base of the shock tower.
    • Locate body grommet for jumper near base of rear seat. Push grommet out and feed jumper completely through hole in body.
  1. Remove fuel cap slowly to release tank pressure.
  2. With vehicle on a hoist, drain fuel from tank. Support fuel tank with a support such as a transmission jack stand.
  3. Position a fuel approved container, with a capacity of at least 16 gallons, under the drain plug located on the bottom left edge of the tank.
  4. Remove drain plug and allow fuel to drain. WARNING: Drain plug must be installed at this time as there will be 1 to 2 gallons of fuel left in the tank .
  5. When tank is no longer draining, install drain plug. Tighten plug to 32 in lb .
  6. Remove driver's side fuel tank strap.
    • Loosen, do not remove, passenger side fuel tank strap allowing fuel tank fill neck to touch rear suspension cross-member.
WARNING: Wrap shop towels around hoses to catch any gasoline spillage .
  1. Disconnect fuel lines from fuel pump module Fig. 7 . These are quick connect fittings.
  2. Disconnect fuel supply line from the fuel brake module.
Fig. 8 Fuel Filter 42402627
  1. Remove fuel filter Fig. 8 .
NOTE: The fuel supply (to filter) tube, return tube (to pump module) are permanently attached to the fuel filter.
  • The ends of the fuel supply and return tubes have different size quick-connect fittings.
  • The larger quick-connect fitting connects to the large nipple (supply side) on the fuel pump module.
  • The smaller quick-connect fitting attaches to the small nipple (return side) on the fuel pump module.
Apply a light coating of clean 30 weight engine oil to the fuel filter nipples. Install fuel tubes.
  1. Install fuel tank, filter and tank straps. Torque tank strap bolts to 23 Nm (250 in lbs) . Make sure pump module harness grommet is installed in body as tank is raised into position.
  2. Lower vehicle and connect pump module connector.
  3. Fill tank with fuel.
  4. Connect negative cable to auxiliary jumper terminal.
Dec 11, 2009 | 1997 Dodge Stratus
REPLACEMENT of a fuel filter on a 1997
The fuel filter (1) is mounted next to the fuel pump module (2), on top of the fuel tank (3)
The fuel delivery system uses quick-connect fittings. The fuel filter mounts to the top of the fuel tank.
  1. Properly relieve the fuel system pressure.
  2. Disconnect the negative battery cable.
  3. Raise and safely support the vehicle.
  4. Place a drain pan underneath the fuel filter to catch any spilling fuel that will result from disconnecting the fuel lines.
It may be necessary to support the weight of the fuel tank with a block of wood and a floor jack. Once this is accomplished, loosen, but do not remove, the fuel tank strap bolts. Allow the fuel tank to lower just enough to access the fuel line fittings at the fuel pump module.
Disengage the fuel line quick-connect fittings from the fuel pump module
Be sure to place a drain pan underneath the filter line fittings to catch all fuel spillage
Locate the fuel filter in its mounting on top of the fuel tank. Detach the quick-connect fittings from the chassis fuel supply tube and fuel pump module by squeezing the quick-connect fitting retainer tabs together and pulling the fitting assembly away from the fuel line nipple. The retainer will remain on the fuel tube.
Using a 10mm socket, remove the fuel filter mounting bolt ...
... then remove the fuel filter from the top of the fuel tank
  1. Remove the fuel filter mounting bolt and remove the fuel filter from the fuel tank.
To install:
  1. Install the fuel filter on the top of the fuel tank and tighten the mounting bolt.
  2. The fuel supply tube (to chassis fuel line), return tube (to pump module) and fuel supply (to fuel filter) tube are permanently attached to the fuel filter. The quick-connect fitting ends of the fuel supply and return tubes are of different sizes.
  3. Apply a light coating of 30W engine oil to the nipples of the fuel filter.
  4. Push the quick-connect fitting over the fuel line until the retainer seats and clicks into place. Be sure the retainer tabs have locked into the case of the fitting.
  5. If necessary, raise the fuel tank and tighten the fuel tank strap bolts.
  6. Lower the vehicle. Start the engine and check for leaks.
Nov 30, 2009 | 1997 Chrysler Town & Country
How to replace fuel pump on chevy malibu 2000
First you should check your trunk. some newer chevy's have an access pannel uner the trunk liner inside the trunk. you remove the liner, remove the bolts and panel, and the pump is right there. it may take some effort to get it wiggled through, but trust me, it will fit. you must remove the fuel lines and wire harness first, then remove the lock ring completely before attempting to pull the pump through the access hole. if that fails then you need to drop you fuel tank to access the pump. there are instructions for removal and installation of the tank below.
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Drain the fuel tank, using a hand-operated pump device to drain as much fuel through the filler tube as possible.
0900c1528026905d.jpg Fig. View of fuel tank mounting
0900c1528026905e.jpg Fig. The fuel filler pipe is attached to the body with a bracket and retaining bolt
0900c1528026905f.jpg Fig. The fuel filler pipe is attach to the tank by a hose clamp
  1. Raise and safely support the vehicle.
  2. Unfasten the muffler hanger bolts.
  3. Remove the rubber exhaust hangers, then allow the exhaust system to rest on the rear axle.
  4. Disconnect the hoses from the fuel tank sender. Grasp the filter and one nylon fuel connection line fitting. Twist the quick-connect fitting 1 / 4 turn in each direction to loosen any dirt within the fitting. Repeat for the other fitting. Using compressed air, blow out the dirt from the quick-connect fittings at the end of the fuel filter.
  5. Detach the quick-connect fittings by pulling the release tabs back on the fuel line quick connector and pulling apart.
  6. Disconnect the hoses at the tank from the filler, vent and vapor pipes.
  7. With the help of an assistant, support the fuel tank, then disconnect the two tank retaining straps and carefully lower the tank.
  8. Detach the fuel sender electrical connector.
  9. Unplug the fuel pressure sensor connector.
  10. Remove the fuel tank from the vehicle.
To install:
  1. If the tank is being replaced, perform the following:
    1. Remove the sound insulators.
    2. Remove the modular fuel pump/sender assembly, as outlined earlier in this section.
    3. Inspect all connectors for dirt and burrs. Clean or replace, as required. Inspect the fuel line O-rings for cuts, nicks, swelling and/or distortion and replace as necessary.
    4. Install the fuel sender assembly to the new tank, as outlined earlier in this section.
    5. Install the sound insulators.
  2. With the help of an assistant, raise the fuel tank to the vehicle and attach the fuel sender connector and, if equipped, the fuel pressure sensor connector.
  3. Raise the fuel tank into position then fasten the retaining straps. Tighten the retaining bolts to 26 ft. lbs. (35 Nm).
  4. Connect the hoses to the filler, vent and vapor pipes.
  5. Attach the nylon fuel feed and return connecting line quick-connect fittings to the fuel sender, as follows:
    1. Apply a few drops of clean engine oil to the male connector tube ends.
    2. Push the connectors together to cause the retaining tabs/fingers to snap into place.
    3. Once installed, pull on both ends of each connection to be sure they are secure.
  6. Install the rubber exhaust hangers.
  7. Install the muffler hanger bolts, then tighten to 11 ft. lbs. (15 Nm).
  8. Attach the fuel tank sender electrical connector.
  9. Carefully lower the vehicle.
  10. Refill the fuel tank, then connect the negative battery cable.
  11. Turn the ignition to the ON position for two seconds, then turn it to the OFF position for ten seconds. Turn again to the ON position and check for fuel leaks.
Nov 04, 2009 | 2000 Chevrolet Malibu
2004 KIA TROUBLE WITH START UP AFTER FILLING UP WITH GAS
The fuel filter may be at the end of it life time and need to be replace. I believe the fuel filter is under the battery bolted to the frame rail. Its a cylinder shape with a fuel line on both end with quick connect fittings. IN the fuse box, remove the fuse to the fuel pump or the fuel pump relay with the engine running, this will depressurize the fuel line. The fuel line on the filter are quick connect fittings, depress the tab's on the fuel line and push towards the filter and the line should just pop off. If you find it to hard to depress the tabs, use a pair of pliers. But be careful not to damage the fuel line. Install the new filter, place fuse or relay back in for the fuel pump. start the engine and look for leaks. If the check engine light came on, disconnect the battery to clear the light, but make sure the radio is turned off before you disconnect the battery for 5 min. Reconnect and everything should be good to go. Hope this helps. keep me posted.
Jun 05, 2009 | 1999 Kia Sportage
Fuel filter to tank quick disconnect broken
Here is a quick solution. Go to Napa Auto Parts with your line size. Take the piece you broke off so they can match the line size. They sell pieces that are about 18 inches long so you can splice it in. These pieces range in price from about 16 to 22 dollars. Other parts stores don't carry this fuel line. They will want to sell you the whole line at a cost of hundreds of dollars. Napa will be able to accomodate your request as I know because I get these pieces from them often.
Good luck. Let me know how it goes. Just read the directions on the package. You need to heat the line up to in stall.
Feb 26, 2009 | 1996 Ford Taurus
1998 Chevy C1500 Truck Inside Door Handle for Classic Body Type Blu Logo
52 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
geo marin
terry stevens
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
