2001 Pontiac Bonneville Logo
nate clem Posted on Dec 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHY IS MY VOLTAGE FLUCUATING CONSTANTLY FROM 9 VOLTS UP TO 15 VOLTS????
MY VOLTAGE FOR THE LAST WEEK HAS STARTED TO CONSTANTLY MOVE FROM VERY LOW VOLTAGE TO VERY HIGH VOLTAGE I WOULD SUSPECT A BAD METER AS MY GAS GAUGE HASNT WORKED SINCE I BOUGHT THE CAR A FEW YEARS AGO HOWEVER WHEN THE VOLTAGE DROPS VERY LOW THE CAR GETS A MISS AND ALL LIGHTS GO DIM I JUST RECENTLY REPLACED THE BATTERY WITH A BRAND NEW ONE AND HAD THE ALTERNATOR CHECKED AND IT TESTED GOOD THIS PROBLEMS STARTS AS SOON AS I START THE CAR UNTIL I CUT IT OFF IT NEVER STOPS GOING UP AND OR DOWN.... MY CHECK ENGINE LIGHT COMES ON NOW AS WELL AS MY SECURITY LIGHT I AM NOT SURE IF THIS HAS ANYTHING TO DO WITH IT BUT THOSE LIGHTS DO COME ON AND STAY ON AND OTHER TIMES ONLY ONE OR NONE I AM STUMPED IF YOU HAVE ANY IDEAS WHERE I SHOULD START I WOULD LOVE TO HEAR THEM AND THANKS FOR READING MY POST
Gil Shultz
Level 3:
  • Pontiac Master 3,464 Answers
  • Posted on Dec 14, 2014
Gil Shultz
Pontiac Master
Level 3:
Answers
3464
Questions
Helped
730795
Points
11104
It sounds like a loose cable that is vibration sensitive. I am not exactly following you but if it stops when the car is turned off then get the alternator and or regulator tested. Your battery should hold about 13.8v when running.
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Feb 18, 2009
SOURCE: Alternator or BCM problem ? Gauges drop
it is not the BCM, go to any Kragen or Autozone parts store, have them test the alt, the test is free
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 16, 2008
SOURCE: 1995 firebird formula v8 charging system
Once you get the idle issue fixed the charging rate should come up to spec, to be safe take the car to a Kragen auto parts store or other chain store like it, they will test the charging system for free, that will give you peice of mind about the alternator.
Anonymous
  • 382 Answers
  • Posted on Dec 22, 2009
SOURCE: 2003 Pontiac Grand AM will not start. Security light is NOT on.
sounds to me like you better find another dealer or possibly an auto electric dealer they should have done it right the first time
Bill Ries-Knight
  • 10 Answers
  • Posted on May 15, 2012
SOURCE: why won't new alternator charge battery when car is running
Many cars have a voltage regulator that is integral to the alternator. Check to be sure it is properly connected. One year later afternoon the day before the Turkey was to be cooked I replaced the Alternator. I drove 200 hundred miles and had the car die at the gate to my destination. I failed to properly connect the Voltage Regulator on the Alternator. Look in that direction for a bad wire, fuse, connector.
allobd2
  • 1207 Answers
  • Posted on Sep 21, 2012
SOURCE: new battery, car won't start
you should check the starter or ignotion, may be there have some problem on them.
__________
autel ms509
2004 Chevy Cavalier Problem
Check the voltage while trying to start it.
94 Jeep Cherokee TPS - back feed
You are still getting high or low voltage at tps? What is the voltage and do you have a unstable idle? Put you + lead on terminal 3 and - lead on terminal 1 turn ignition on and check voltage to be at approximately 5 volts. You can also back probe with it connected at center wire and ground probe to a good ground at engine. Turn ignition on it should read between 0.20 - 0.90 slowly manually open throttle it should rise all the way to 4.5 voltd at full open. If its bad change tps if no 5.0 volts from pcm on first test check connections at pcm. The center tps connector supply wire comes from pin 22 and connection 3 ( which is 5 volt supply ) comes from pin 6. You should be able to back probe pin 6 turn ignition on and have 5 volts. If not 5 v brain has problem.
The volt gauge reads 14 volts when the truck is running (2004 Chevy 2500 HD, 6 Liter) after I shut it off Voltage gauge reads 9 volts as low as the gauge goes. The starter acts like it is not getting...
14 volts is close (14.5-14.8 volts is required
and 9 when shut down indicates a bad battery
have it load tested and then have the alternator tested for rectifier pack operation
there should be 14.5 volts DC at the battery when running or it is not charging the battery
if you have 14 volts AC replace the alternator with a serviceable unit
Bcm problem?
This sounds like a you are having a voltage problem. Have the charging system checked. A bad battery or poor alternator output can cause this. When voltage starts dropping below about 9 volts all kinds of crazy electrical things can happen and they can be anything and anywhere.
1helpful
2002 chevy cavalier battery shows 12.30 volts at rest. Once the car is started the voltage drops to between 10 and 9 volts. The voltage differential between bolt on the rear of the alternator and the...
Verify that BOTH your positive battery cable AND your negative battery cable have good clean connections at both ends. Make sure that the part where the negative battery cable bolts too on the body of the car is free of rust and a good solid connection. After confirming good connections, then verify that the alternator is charging at between 13.5 and 14 volts when the engine rpm is raised to near 2000 rpm. Check that the battery voltage stays above 10 volts when the starter is cranking and turning the engine over. Once all these things are met, then the system is in good condition. If the battery voltage is too low after a sufficient amount of recharge time, then the battery is probably bad. If the Alternator voltage is too low once you verify a good battery, then the alternator is probably bad.
In march tuck wouldn't start mechanic replaced alternator truck ran good, battery light stayed on had test done at O'reillies Last week drove to Port Aurthur & on the way back gauges stopped...
You need to get a digtal voltage meter (about $15) and check it out yourself-readings at the battery should be 12.5 volts after sitting overnight. Once you start it, the readings at the battery terminals should go up to almost 15 volts when first started, then gradually drop down to around 14.2 volts-I would bet either your battery is bad, or your battery is bad and your alternator has failed trying to supply power to a bad battery-either way, your mechanic should not have allowed the battery light to stay on after changing out the alternator without finding out what was wrong-he did not fix it.
1999 Dodge Caravan Air Conditioning flucuating
Sounds like system is low on refrigerant and needs to be checked for leaks - could be anywhere on one of these.
All lights Flashing On
A low voltage issue will cause all these symptoms. You should have the alternator checked as well as the battery. Good Luck
Speed sensor low voltage
lets do this ck voltage with voltmeter at battery post on the back of you alternator. you have to have at least 12.35 volt at least. most likely around 14.-16.. but 12.35 min. any lower replace.
hope2help
2helpful
2000 Ford Ranger
TEST B: BATTERY VOLTAGE OUT OF RANGE - DTC B1676
1. Check if vehicle has been jump started within past 2 weeks. If vehicle has been jump started, ABS is
okay. If vehicle has not been jump started, go to next step.
2. Using DVOM, measure voltage between positive and negative battery terminals. If voltage is 9-19 volts,
go to next step. If voltage is not 9-19 volts, diagnose charging system. See appropriate GENERATORS
article in STARTING & CHARGING SYSTEMS.
3. Turn ignition off. Disconnect 25-pin ABS control module. Install EEC-IV 60-pin Breakout Box (014-
00322). Turn ignition on. Measure voltage between breakout box terminal No. 20 and ground. If voltage
is more than 10 volts, go to next step. If voltage is less than 10 volts, repair Light Blue/Pink wire between
ABS control module and instrument panel fuse panel.
4. Turn ignition off. Measure voltage between breakout box terminal No. 25 and ground. If voltage is
greater than 10 volts, go to next step. If voltage is less than 10 volts, repair Red wire between ABS
control module and power distribution box/engine compartment fuse box.
5. Measure voltage between breakout box terminal No. 9 and ground. If voltage is greater than 10 volts, go
to next step. If voltage is less than 10 volts, repair Yellow/Light Green wire between ABS control module
6. Measure resistance between breakout box terminal No. 8 and ground. Also, measure resistance between
breakout box terminal No. 24 and ground. If both resistance measurements are less than 5 ohms, replace
ABS control module and repeat self-test. If either resistance measurement is greater than 5 ohms, repair
suspect Black wire between ABS control module and ground distribution.
NOTE: DTC B1676 will set if vehicle has been jump started.
2000 Ford Ranger
2000-01 BRAKES Anti-Lock - 4WAL - Explorer, Ranger & Mountaineer
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
